Version 3.0.0-a3 is released
Re: Version 3.0.0-a3 is released
DeFlanko wrote:Can i install this over my 2.6.5 install, in a separate folder?
Check the "Upgrade Notes" section in the main post :) Basically yes you can but a backup of the configuration folder is recommended.
Wolfgan
Post by Wolfgan »
Lately I noticed that UMS detects several clients as having low speed (ie 6MB/s) and then when browsing the media library all files (avi, mp4, mkv) are offered as Transcoded by default instead of serving them untouched as before. Is that intended?
If yes, any way to disable this behavior and avoid this auto transcoding?
Thanks! Wolf
Wolfgan
Post by Wolfgan »
Wolfgan wrote:Lately I noticed that UMS detects several clients as having low speed (ie 6MB/s) and then when browsing the media library all files (avi, mp4, mkv) are offered as Transcoded by default instead of serving them untouched as before. Is that intended?
Thanks! Wolf
Reading the changelogs I noticed that 3.0.0-a1 introduced a feature "Transcoding quality automatically adjusts for content and network speed by default, allowing wireless users an easier experience"
As my client is detected as being low speed, I think UMS try to "optimize" the experience when is really not needed. How can I disable it?
Do I have to change the "Automatic" settings in the Transcoding-General options tab to any value? (ie 0, none or something like it?)
Thx, Wolf.
Wolfgan
Post by Wolfgan »
Thanks! Wolf
Thx, Wolf.
Looking at the code I found the logic for this behavior is probably at FFMpegVIdeo.java (https://github.com/UniversalMediaServer ... Video.java) but it doesn-t seem to contain any disabling logic, or disabling selection of auto quality transcoding (so a wrong assumption of speed triggers a ton of trancoding issues for me w/o being able to shut off this feature)
Do anyone care to add a Disabled option in the pull down menus for auto quality?
Thx, Wolf
@Wolfgan: UMS does not use its automatic detection of network speed to control transcoding quality. It only relies on your settings. Specifically the Maximum Bandwidth setting on the General Configuration tab and the Transcoding Quality setting on the Transcoding Settings tab.
Wolfgan
Post by Wolfgan »
SubJunk wrote:@Wolfgan: UMS does not use its automatic detection of network speed to control transcoding quality. It only relies on your settings. Specifically the Maximum Bandwidth setting on the General Configuration tab and the Transcoding Quality setting on the Transcoding Settings tab.
Thanks Subjunk. Definitely something weird is happening on my setup. Same UMS and renderers conf, a1 works like a charm offering everything OK (ie serving most of the files to my WDTV w/o transcoding, and supported formats on PS3 as expected), but a3 offer every file to be transcoded (aside for many entries if not all show as duplicates, and content cannot be rendered on the PS3).
I'll conduct some tests and compare log files, will feedback the community if I pinpoint the issues.
Thanks!
Casper
Post by Casper »
a2 & a3 are giving me an error with PMSEncoder 1.6.3 plugin (worked previously with a1 and 2.6.5).
08-08 18:23:41  Exception in thread "main" java.lang.VerifyError: class com.chocolatey.pmsencoder.PMSEncoder overrides final method launchTranscode.(Ljava/lang/String;Lnet/pms/dlna/DLNAResource;Lnet/pms/dlna/DLNAMediaInfo;Lnet/pms/io/OutputParams;)Lnet/pms/io/ProcessWrapper;
08-08 18:23:41  	at java.lang.ClassLoader.defineClass1(Native Method)
08-08 18:23:41  	at java.lang.ClassLoader.defineClass(Unknown Source)
08-08 18:23:41  	at java.security.SecureClassLoader.defineClass(Unknown Source)
08-08 18:23:41  	at java.net.URLClassLoader.defineClass(Unknown Source)
08-08 18:23:41  	at java.net.URLClassLoader.access$100(Unknown Source)
08-08 18:23:41  	at java.net.URLClassLoader$1.run(Unknown Source)
08-08 18:23:41  	at java.security.AccessController.doPrivileged(Native Method)
08-08 18:23:41  	at java.net.URLClassLoader.findClass(Unknown Source)
08-08 18:23:41  	at java.lang.ClassLoader.loadClass(Unknown Source)
08-08 18:23:41  	at java.lang.Class.getDeclaredConstructors0(Native Method)
08-08 18:23:41  	at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
08-08 18:23:41  	at java.lang.Class.getConstructor0(Unknown Source)
08-08 18:23:41  	at java.lang.Class.newInstance0(Unknown Source)
08-08 18:23:41  	at java.lang.Class.newInstance(Unknown Source)
08-08 18:23:41  	at net.pms.external.ExternalFactory.instantiateEarlyListeners(ExternalFactory.java:419)
08-08 18:23:41  	at net.pms.external.ExternalFactory.lookup(ExternalFactory.java:399)
08-08 18:23:41  	at net.pms.PMS.init(PMS.java:665)
08-08 18:23:41  	at net.pms.PMS.createInstance(PMS.java:1040)
08-08 18:23:41  	at net.pms.PMS.main(PMS.java:1136)
infidel
Post by infidel »
Casper wrote:a2 & a3 are giving me an error with PMSEncoder 1.6.3 plugin (worked previously with a1 and 2.6.5).
This is one of the many breaking changes introduced in a2 (via PMS source code), so plugins need to be updated.
Thanks for reporting that, Casper. That's one reason why we have kept the 3.0 branch in alpha. It's getting there though :)
Casper
Post by Casper »
No worries, I stopped using PMSEncoder and have no need for it. But I'm getting an exception with FFmpeg Web with a2 & a3. MEncoder Web works but isn't scaling right on Panasonic renderer (zoomed 2x).
INFO  2013-08-13 15:33:59.204 [New I/O worker #6] Starting transcode/remux of TED: Alastair Parvin: Architecture for the people by the people - Alastair Parvin (2013)
TRACE 2013-08-13 15:33:59.205 [New I/O worker #6] Looking for an audio track with lang: eng
TRACE 2013-08-13 15:33:59.206 [New I/O worker #6] Looking for an audio track with lang: fre
TRACE 2013-08-13 15:33:59.206 [New I/O worker #6] Looking for an audio track with lang: jpn
TRACE 2013-08-13 15:33:59.206 [New I/O worker #6] Looking for an audio track with lang: ger
TRACE 2013-08-13 15:33:59.206 [New I/O worker #6] Looking for an audio track with lang: und
DEBUG 2013-08-13 15:33:59.207 [New I/O worker #6] Caught exception
java.lang.IndexOutOfBoundsException: Index: 0, Size: 0
	at java.util.ArrayList.rangeCheck(Unknown Source) ~[na:1.7.0_05]
	at java.util.ArrayList.get(Unknown Source) ~[na:1.7.0_05]
	at net.pms.encoders.Player.setAudioOutputParameters(Player.java:248) ~[ums.jar:3.0.0-a2]
	at net.pms.encoders.Player.setAudioAndSubs(Player.java:209) ~[ums.jar:3.0.0-a2]
	at net.pms.encoders.FFmpegWebVideo.launchTranscode(FFmpegWebVideo.java:127) ~[ums.jar:3.0.0-a2]
	at net.pms.dlna.DLNAResource.getInputStream(DLNAResource.java:2152) ~[ums.jar:3.0.0-a2]
	at net.pms.network.RequestV2.answer(RequestV2.java:337) ~[ums.jar:3.0.0-a2]
	at net.pms.network.RequestHandlerV2.writeResponse(RequestHandlerV2.java:295) ~[ums.jar:3.0.0-a2]
	at net.pms.network.RequestHandlerV2.messageReceived(RequestHandlerV2.java:253) ~[ums.jar:3.0.0-a2]
	at org.jboss.netty.handler.stream.ChunkedWriteHandler.handleUpstream(ChunkedWriteHandler.java:142) ~[ums.jar:3.0.0-a2]
	at org.jboss.netty.handler.codec.http.HttpChunkAggregator.messageReceived(HttpChunkAggregator.java:145) ~[ums.jar:3.0.0-a2]
	at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:296) ~[ums.jar:3.0.0-a2]
	at org.jboss.netty.handler.codec.frame.FrameDecoder.unfoldAndFireMessageReceived(FrameDecoder.java:459) ~[ums.jar:3.0.0-a2]
	at org.jboss.netty.handler.codec.replay.ReplayingDecoder.callDecode(ReplayingDecoder.java:536) ~[ums.jar:3.0.0-a2]
	at org.jboss.netty.handler.codec.replay.ReplayingDecoder.messageReceived(ReplayingDecoder.java:435) ~[ums.jar:3.0.0-a2]
	at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:268) ~[ums.jar:3.0.0-a2]
	at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:255) ~[ums.jar:3.0.0-a2]
	at org.jboss.netty.channel.socket.nio.NioWorker.read(NioWorker.java:88) ~[ums.jar:3.0.0-a2]
	at org.jboss.netty.channel.socket.nio.AbstractNioWorker.process(AbstractNioWorker.java:109) ~[ums.jar:3.0.0-a2]
	at org.jboss.netty.channel.socket.nio.AbstractNioSelector.run(AbstractNioSelector.java:312) ~[ums.jar:3.0.0-a2]
	at org.jboss.netty.channel.socket.nio.AbstractNioWorker.run(AbstractNioWorker.java:90) ~[ums.jar:3.0.0-a2]
	at org.jboss.netty.channel.socket.nio.NioWorker.run(NioWorker.java:178) ~[ums.jar:3.0.0-a2]
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [na:1.7.0_05]
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [na:1.7.0_05]
	at java.lang.Thread.run(Unknown Source) [na:1.7.0_05]
I also noticed a little GUI bug; despite UMS.conf having audio_channels=2, the GUI is starting with the default value of 6.
