samsung evolution kit breaks playback
Help. I've got two Samsung 55" smart TVs. Both read stuff via UMS until... I upgraded one with the samsung evolution kit. The other works as always, but the upgraded one will open a show and then just sit there at a frozen frame. I'm no expert in UMS and haven't (I think) tweaked anything. Any help appreciated. Thanks.
07-14 19:50:21 Starting Universal Media Server 2.6.4
07-14 19:50:21 Based on PS3 Media Server by shagrath, copyright 2008-2013
07-14 19:50:21 http://www.universalmediaserver.com
07-14 19:50:21
07-14 19:50:21 Build: 18e2f325e (2013-05-10)
07-14 19:50:21 Java: 1.6.0_51-Apple Inc.
07-14 19:50:21 OS: Mac OS X 64-bit 10.8.4
07-14 19:50:21 Encoding: UTF-8
07-14 19:50:21 Memory: 758 MB
07-14 19:50:21
07-14 19:50:21 Working directory: /Applications/Universal Media Server.app/Contents/Resources/Java
07-14 19:50:21 Temp directory: /var/folders/92/4q7h81z92wq396mwzy1hdmfh0000gn/T/universalmediaserver
07-14 19:50:21 Logging config file: /Applications/Universal Media Server.app/Contents/Resources/Java/logback.xml
07-14 19:50:21 debug.log: /Applications/Universal Media Server.app/Contents/Resources/Java/debug.log
07-14 19:50:21
07-14 19:50:21 Profile directory: /Users/xxx/Library/Application Support/UMS
07-14 19:50:21 Profile path: /Users/xxx/Library/Application Support/UMS/UMS.conf
07-14 19:50:21 Profile permissions: rw
07-14 19:50:21 Profile name: xxx.lan
07-14 19:50:21
07-14 19:50:21 Loading MediaInfo library
07-14 19:50:21 Loaded MediaInfoLib - v0.7.58
07-14 19:50:21 Loading renderer configurations from /Applications/Universal Media Server.app/Contents/Resources/Java/renderers
07-14 19:50:21 Loading configuration file: AirPlayer.conf
07-14 19:50:21 Loading configuration file: Android.conf
07-14 19:50:21 Loading configuration file: BlackBerryPlayBook-KalemSoftMP.conf
07-14 19:50:21 Loading configuration file: Bravia4500.conf
07-14 19:50:21 Loading configuration file: Bravia5500.conf
07-14 19:50:21 Loading configuration file: BraviaEX.conf
07-14 19:50:21 Loading configuration file: BraviaEX620.conf
07-14 19:50:21 Loading configuration file: BraviaHX.conf
07-14 19:50:21 Loading configuration file: DirecTVHR.conf
07-14 19:50:21 Loading configuration file: DLinkDSM510.conf
07-14 19:50:21 Loading configuration file: FreeboxHD.conf
07-14 19:50:21 Loading configuration file: FreecomMusicPal.conf
07-14 19:50:21 Loading configuration file: iPad-iPhone.conf
07-14 19:50:21 Loading configuration file: Kuro.conf
07-14 19:50:21 Loading configuration file: LGST600.conf
07-14 19:50:21 Loading configuration file: N900.conf
07-14 19:50:21 Loading configuration file: NetgearNeoTV.conf
07-14 19:50:21 Loading configuration file: OnkyoTX-NR717.conf
07-14 19:50:21 Loading configuration file: OPPOBDP83.conf
07-14 19:50:21 Loading configuration file: OPPOBDP93.conf
07-14 19:50:21 Loading configuration file: Panasonic.conf
07-14 19:50:21 Loading configuration file: Philips.conf
07-14 19:50:21 Loading configuration file: PhilipsPFL.conf
07-14 19:50:21 Loading configuration file: PopcornHour.conf
07-14 19:50:21 Loading configuration file: PS3.conf
07-14 19:50:21 Loading configuration file: Realtek.conf
07-14 19:50:21 Loading configuration file: Samsung-SMT-G7400.conf
07-14 19:50:21 Loading configuration file: SamsungAllShare.conf
07-14 19:50:21 Loading configuration file: SamsungWiseLink.conf
07-14 19:50:21 Loading configuration file: SharpAquos.conf
07-14 19:50:21 Loading configuration file: Showtime3.conf
07-14 19:50:21 Loading configuration file: Showtime4.conf
07-14 19:50:21 Loading configuration file: SMP-N100.conf
07-14 19:50:21 Loading configuration file: SonyBluray.conf
07-14 19:50:21 Loading configuration file: SonyHomeTheatreSystem.conf
07-14 19:50:21 Loading configuration file: Streamium.conf
07-14 19:50:21 Loading configuration file: TelstraTbox.conf
07-14 19:50:21 Loading configuration file: VideoWebTV.conf
07-14 19:50:21 Loading configuration file: VizioSmartTV.conf
07-14 19:50:21 Loading configuration file: WDTVLive.conf
07-14 19:50:21 Loading configuration file: WMP.conf
07-14 19:50:21 Loading configuration file: XBMC.conf
07-14 19:50:21 Loading configuration file: XBOX360.conf
07-14 19:50:21 Loading configuration file: YamahaRXA1010.conf
07-14 19:50:21 Loading configuration file: YamahaRXV3900.conf
07-14 19:50:21 Loading configuration file: YamahaRXV671.conf
07-14 19:50:21 Please wait while we check the MPlayer font cache, this can take a minute or so.
07-14 19:50:21 Finished checking the MPlayer font cache.
07-14 19:50:21 Searching for plugins in /Applications/Universal Media Server.app/Contents/Resources/Java/plugins
07-14 19:50:21 Found plugin: net.pms.movieinfo.MovieInfo
07-14 19:50:21 Registering transcoding engine: FFmpeg Audio
07-14 19:50:21 Registering transcoding engine: MEncoder
07-14 19:50:21 Registering transcoding engine: MPlayer Audio
07-14 19:50:21 Registering transcoding engine: FFmpeg Web Video
07-14 19:50:21 Registering transcoding engine: MEncoder Web
07-14 19:50:21 Registering transcoding engine: MPlayer Video Dump
07-14 19:50:21 Registering transcoding engine: MPlayer Web
07-14 19:50:21 Registering transcoding engine: tsMuxeR
07-14 19:50:21 Registering transcoding engine: Audio High Fidelity
07-14 19:50:21 Registering transcoding engine: VLC Audio Streaming
07-14 19:50:21 Registering transcoding engine: VLC Video Streaming
07-14 19:50:21 Registering transcoding engine: dcraw Thumbnailer
07-14 19:50:21 Using address /192.168.1.64 found on network interface: name:en0 (en0)
07-14 19:50:21 Created socket: /192.168.1.64:5001
07-14 19:50:21 Starting DLNA Server on host 192.168.1.64 and port 5001...
07-14 19:50:21 Using the following UUID configured in UMS.conf: 3d5251e4-9963-47e4-b6f3-20455bcf2962
07-14 19:50:21 No IP filter specified, access granted to /192.168.1.254
07-14 19:50:21 Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Thomson_http-lib/r0.1
07-14 19:50:21 The server is now available for renderers to find
07-14 20:10:59 No IP filter specified, access granted to /192.168.1.71
07-14 20:17:05 No IP filter specified, access granted to /192.168.1.64
07-14 20:17:05 Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_8_4) AppleWebKit/536.30.1 (KHTML, like Gecko) Version/6.0.5 Safari/536.30.1, DNT: 1, Referer: http://192.168.1.254/cgi/b/lan/?be=0&l0=4&l1=-1
07-14 20:18:22 No IP filter specified, access granted to /192.168.1.85
07-14 20:18:22 Another renderer like Samsung AllShare was found!
07-14 20:18:22 Checking IP: 192.168.1.85 for Samsung AllShare
07-14 20:18:23 Renderer Samsung AllShare found on this address: 192.168.1.85 <*********************************** THE OLD, WORKING TV
07-14 20:18:26 No IP filter specified, access granted to /192.168.1.186
07-14 20:18:28 Another renderer like Samsung AllShare was found!
07-14 20:18:28 Checking IP: 192.168.1.186 for Samsung AllShare
07-14 20:18:28 Renderer Samsung AllShare found on this address: 192.168.1.186 <*********************************** THE UPDATED TV
07-14 20:22:57 Checking shared folder: /Volumes/4000 video etc/[video master]
07-14 20:24:03 Starting transcode/remux of House MD - 6x02 - Epic Fail.m4v
07-14 20:24:09 Started playing House MD - 6x02 - Epic Fail.m4v on your Samsung AllShare <*********************************** FAILS ON UPGRADED TV
07-14 21:18:13 Stopped playing House MD - 6x02 - Epic Fail.m4v on your Samsung AllShare
07-14 21:32:01 Started playing Californication.S02E01.720p.HDTV.x264-2HD.avi on your Samsung AllShare <*********************************** WORKS ON OLD TV
07-14 21:33:12 Stopped playing Californication.S02E01.720p.HDTV.x264-2HD.avi on your Samsung AllShare
07-14 19:50:21
07-14 19:50:21
07-14 19:50:21
07-14 19:50:21
