2 nic's ?
2 nic's ?
Quick one;
While using 2 nics and choosing which one to use, well, that's sorted so that I can make sure
to ONLY bind it towards one network.
But, is it possible to make UMS to service 2 networks at the same time over 2 different nics ?
Haven't found how to if that is possible. Specifying which IP, etc, yes, but not this "opposite" need.
Thanks,
Thanks,
Re: 2 nic's ?
Hi I think you should take a look at the FAQ:
http://www.universalmediaserver.com/faq/#Setup2
Re: 2 nic's ?
Thanks...
Im actually doing that part allready, got 2 different UMS servicing "full" and "kids-only" on different ports/UID, etc through the CONF option.
More wondering whether one single instance of UMS could be active/seen on both NIC's at once,
otherwise, my setup would end up being 4 instances !!...
THanks again,
THanks again,
Re: 2 nic's ?
Well I'm not the expert developer here, but I have the impression that one instance of UMS can only listen on one NIC.
Maybe one of the experts could give their opinion?
- Optimus_prime
Re: 2 nic's ?
Well i'm no expert but i've never had one instance of UMS working on 2 nic's at once. You can use two separate instances of UMS but you may run into other problems by doing that.
