[Solved] UMS 2.6.5 and 3.0.0 A5 giving mencoder -1073741819
PeterK
Post by PeterK »
Hello
if I skip to the first half of movie it is ok, when I skip to second half I see:
Universal Media Server\win32\mencoder.exe has a return code of -1073741819! Maybe an error occurred... check the log file
I tried 2.6.5 and 3.0.0 A5 both do this. Sometimes, video is starter but no sound, sometimes black screen but UMS is filling buffer.
Can this be damaged .mkv? On computer of course seeking is working.
Let me know if you need more details...
PeterK
Re: UMS 2.6.5 and 3.0.0 A5 giving mencoder -1073741819
Post by PeterK »
Ok this was solved when I used MPlayerMEncoder-SB52.zip.
Strange that mencoder.exe included with UMS claim to be also SB52 release but size is different.
Re: [Solved] UMS 2.6.5 and 3.0.0 A5 giving mencoder -1073741
The one that comes with UMS is SB52-UMS, which is a build I made for UMS.
Can you try putting SB52-UMS back to try to reproduce the problem? It's strange that that would fix it
