MP4 just stop playing.
Sitman
Post by Sitman »
Hi all,
I have a problem where MP4 files just stop streaming to my TV after some time. Maybe 45 mins or an hour. It only happens with MP4s. AVIs can stream forever.
Now this has happened on Windows 7 and 8. I have nothing special. 64 bit OS. 32bit Java, Tried UMS 2.x and and currently running 3.0 a6.
I've stopped OS sleeping. Created a power scheme to never turn off anything. Tried playing from the # sub folders with different engines. My wireless router is fine.
I can convert an MP4 to AVI and it plays in full. I've raised my memory for java to be 1536mb and that makes no difference.
There are no errors I can see.3
What is it about MP4s!!!
(54.9 KiB) Downloaded 745 times
DeFlanko
Contact:
Re: MP4 just stop playing.
Post by DeFlanko »
Log files help :)
Sitman
Post by Sitman »
DeFlanko wrote:Log files help :)
Attached as requested. Sorry I missed them off the original. These are after the MP4 stopped playing.
(246.82 KiB) Downloaded 807 times
Sitman
Post by Sitman »
Can anyone see any reason MP4s stop playing?
DeFlanko
Contact:
Post by DeFlanko »
So is your TV... a Samsung TV?
and is it showing up in UMS as:
Matched media renderer "Samsung WiseLink" based on address /192.168.1.102
TRACE 2013-10-05 20:25:15.629 [New I/O worker #4] Received on socket: CONTENT-LENGTH: 633
TRACE 2013-10-05 20:25:15.629 [New I/O worker #4] Received on socket: CONTENT-TYPE: text/xml;charset="utf-8"
TRACE 2013-10-05 20:25:15.629 [New I/O worker #4] Received on socket: HOST: 192.168.1.100:5001
TRACE 2013-10-05 20:25:15.629 [New I/O worker #4] Received on socket: SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"
TRACE 2013-10-05 20:25:15.629 [New I/O worker #4] Received on socket: USER-AGENT: DLNADOC/1.50
TRACE 2013-10-05 20:25:15.629 [New I/O worker #4] Recognized media renderer: Samsung WiseLink
If so i think that might be why, youll have to find out what your user-agent of your TV is, and create a new CONF for your TV model number. You can use the Samsung CONF's that Optimus Made or maybe he can assist you =)
Optimus_prime
Post by Optimus_prime »
Ok, what kind of Device (Samsung) are you using. MP4's work ok on my TV but yours maybe different.
Sitman
Post by Sitman »
Optimus_prime wrote:Ok, what kind of Device (Samsung) are you using. MP4's work ok on my TV but yours maybe different.
Hi guys and thanks for your help.
My TV is a Samsung PS50B650 Plasma. It is detected by UMS on the status tab as a Samsung WiseLink even when Default Renderer is set to Unknown renderer.
The TV is set to factory default except the brightness / back light / contrast etc.
I'll search for your config in the mean time.
Thanks again.
Below is a cut down log.
INFO 2013-10-11 20:34:27.069 [main] Starting Universal Media Server 3.0.0-b1
INFO 2013-10-11 20:34:27.069 [main] Based on PS3 Media Server by shagrath, copyright 2008-2013
INFO 2013-10-11 20:34:27.069 [main] http://www.universalmediaserver.com
INFO 2013-10-11 20:34:27.069 [main] Build: 9c86e5226 (2013-10-09)
INFO 2013-10-11 20:34:27.069 [main] Java: Java HotSpot(TM) Client VM 1.7.0_40 32-bit by Oracle Corporation
INFO 2013-10-11 20:34:27.069 [main] OS: Windows 8 64-bit 6.2
INFO 2013-10-11 20:34:27.069 [main] Encoding: UTF-8
INFO 2013-10-11 20:34:27.069 [main] Memory: 742 MB
INFO 2013-10-11 20:34:28.679 [main] Loading renderer configurations from C:\Program Files (x86)\Universal Media Server\renderers
INFO 2013-10-11 20:34:28.679 [main] Loaded configuration for renderer: AirPlayer
INFO 2013-10-11 20:34:28.679 [main] Loaded configuration for renderer: Android
INFO 2013-10-11 20:34:28.679 [main] Loaded configuration for renderer: KalemSoft Media Player
INFO 2013-10-11 20:34:28.679 [main] Loaded configuration for renderer: Sony Bravia 4500
INFO 2013-10-11 20:34:28.679 [main] Loaded configuration for renderer: Sony Bravia 5500
INFO 2013-10-11 20:34:28.679 [main] Loaded configuration for renderer: Sony Bravia EX
INFO 2013-10-11 20:34:28.679 [main] Loaded configuration for renderer: Sony Bravia EX620
INFO 2013-10-11 20:34:28.694 [main] Loaded configuration for renderer: Sony Bravia HX
INFO 2013-10-11 20:34:28.694 [main] Loaded configuration for renderer: Sony Bravia W6/W8/W9
INFO 2013-10-11 20:34:28.694 [main] Loaded configuration for renderer: DirecTV HR
INFO 2013-10-11 20:34:28.694 [main] Loaded configuration for renderer: D-Link DSM-510
INFO 2013-10-11 20:34:28.694 [main] Loaded configuration for renderer: Freebox HD
INFO 2013-10-11 20:34:28.694 [main] Loaded configuration for renderer: Freecom MusicPal
INFO 2013-10-11 20:34:28.694 [main] Loaded configuration for renderer: iPad / iPhone
INFO 2013-10-11 20:34:28.694 [main] Loaded configuration for renderer: Pioneer Kuro
INFO 2013-10-11 20:34:28.694 [main] Loaded configuration for renderer: LG Smart TV Upgrader
INFO 2013-10-11 20:34:28.694 [main] Loaded configuration for renderer: Nokia N900
INFO 2013-10-11 20:34:28.710 [main] Loaded configuration for renderer: Netgear NeoTV
INFO 2013-10-11 20:34:28.710 [main] Loaded configuration for renderer: Onkyo TX-NR717
INFO 2013-10-11 20:34:28.710 [main] Loaded configuration for renderer: OPPO BDP-83
INFO 2013-10-11 20:34:28.710 [main] Loaded configuration for renderer: OPPO BDP-93
INFO 2013-10-11 20:34:28.710 [main] Loaded configuration for renderer: Panasonic TV
INFO 2013-10-11 20:34:28.710 [main] Loaded configuration for renderer: Philips Aurea
INFO 2013-10-11 20:34:28.710 [main] Loaded configuration for renderer: Philips TV
INFO 2013-10-11 20:34:28.710 [main] Loaded configuration for renderer: Popcorn Hour
INFO 2013-10-11 20:34:28.710 [main] Loaded configuration for renderer: PlayStation 3
INFO 2013-10-11 20:34:28.710 [main] Loaded configuration for renderer: Realtek
INFO 2013-10-11 20:34:28.726 [main] Loaded configuration for renderer: Samsung SMT-G7400
INFO 2013-10-11 20:34:28.726 [main] Loaded configuration for renderer: Samsung D7000
INFO 2013-10-11 20:34:28.726 [main] Loaded configuration for renderer: Samsung AllShare
INFO 2013-10-11 20:34:28.726 [main] Loaded configuration for renderer: Samsung Galaxy S3
INFO 2013-10-11 20:34:28.726 [main] Loaded configuration for renderer: Samsung WiseLink
INFO 2013-10-11 20:34:28.726 [main] Loaded configuration for renderer: Sharp Aquos
INFO 2013-10-11 20:34:28.726 [main] Loaded configuration for renderer: Showtime 3
INFO 2013-10-11 20:34:28.726 [main] Loaded configuration for renderer: Showtime 4
INFO 2013-10-11 20:34:28.726 [main] Loaded configuration for renderer: Sony SMP-N100
INFO 2013-10-11 20:34:28.726 [main] Loaded configuration for renderer: Sony Blu-ray
INFO 2013-10-11 20:34:28.741 [main] Loaded configuration for renderer: Sony Home Theatre System
INFO 2013-10-11 20:34:28.741 [main] Loaded configuration for renderer: Streamium
INFO 2013-10-11 20:34:28.741 [main] Loaded configuration for renderer: Telstra T-Box
INFO 2013-10-11 20:34:28.741 [main] Loaded configuration for renderer: VideoWeb TV
INFO 2013-10-11 20:34:28.741 [main] Loaded configuration for renderer: Vizio Smart TV
INFO 2013-10-11 20:34:28.741 [main] Loaded configuration for renderer: WD TV Live
INFO 2013-10-11 20:34:28.741 [main] Loaded configuration for renderer: WMP
INFO 2013-10-11 20:34:28.741 [main] Loaded configuration for renderer: XBMC
INFO 2013-10-11 20:34:28.741 [main] Loaded configuration for renderer: Xbox 360
INFO 2013-10-11 20:34:28.741 [main] Loaded configuration for renderer: Yamaha RX-A1010
INFO 2013-10-11 20:34:28.741 [main] Loaded configuration for renderer: Yamaha RX-V3900
INFO 2013-10-11 20:34:28.741 [main] Loaded configuration for renderer: Yamaha RX-V671
INFO 2013-10-11 20:34:29.358 [pool-6-thread-1] Checking IP: 192.168.1.102 for Samsung WiseLink
DEBUG 2013-10-11 20:34:29.374 [New I/O worker #1] HTTP User-Agent: SamsungWiselinkPro/1.0
INFO 2013-10-11 20:34:29.374 [pool-6-thread-1] Renderer Samsung WiseLink found on this address: tv.lan (192.168.1.102)
Optimus_prime
Well if it's being recognizing it as a wiselink then that can't be helped. The renderer profile for wiselink isn't very good and can't play most things. But you should be able to transcode into a format the tv see's. I'll have a look at the config for Wiselink and see what i can do
Sitman
Post by Sitman »
Optimus_prime wrote: I'll have a look at the config for Wiselink and see what i can do
Thank you very much for your help.
