Mac High Sierra problems
Re: Mac High Sierra problems
None of this should be affected by an upgrade to 6.8.0.
It's good to hear that you found one that's working. We should probably make sure to "remember" which one is the good one.
Miklos
Post by Miklos »
Just incase anyone else may want to try out these Marantz configs from Sami32, it will be helpful to know how to 'change' the file name from 'txt' to just 'conf'. As usual, Apple haven't made it that easy for us Mac users.
After much searching around, I found out that the only proven way to change the file name was to identify the file - then select 'Get Info' from the FILE menu - and in the 'Name & Extension' drop-down window remove '.txt' from the end of the file name.
Hope it helps :-)
NA6005 config.png (53.29 KiB) Viewed 4846 times
Or just do it the simple way: Open a terminal, "cd" to the folder with the file and use "mv <oldname> <newname>" ;)
