More than One Folder for Alternative Subtitles
Madoka
Post by Madoka »
Would it be possible to list more than one folder in the Alternative Subtitles field? MPC-HC allows several, separated by a semi-colon. As one can list more than one folder in the shared folders setting, I was hoping this would be possible.
This is because I usually have videos burned on DVD. In the past, I had used a subfolder on the DVD to hold the subtitles, permitted by MPC. I have this folder currently listed in the Alternative Folder field, and it works great. However, sometimes new subtitles come out which then can't be put on that disc obviously. I have to copy the file back on disc, or manually change the Alternative Folder field. I would like to be able to create a folder on my hard drive and have UMS scan that folder too. This way I can use any subtitle when ever it comes out.
Thanks for reading.
