[Solved] Played Status not working properly since I installed latest version
messiestobjects
Post by messiestobjects »
UMS is not marking files as played since I installed latest version. Has anyone else seen this? I believe I have all settings correct:
Re: Played Status not working properly since I installed latest version
I fixed a bug recently that might fix this, if you let me know which operating system you use I can attach a test version for you
messiestobjects
Cool thanks! I'm on Windows 10 Pro.
Here it is. If it still doesn't work please post logs http://www.universalmediaserver.com/upl ... 01b94f.exe
Igorsch
Post by Igorsch »
Same problem here. Windows 8.1 x64. Can I use the same link to .exe to fix it?
Thanks.
Yes please try it and let me know if it works Igorsch
messiestobjects
That seems to have worked! I tested it on one file; I played it to the end, restarted the renderer, and it marked it as played. Thanks a ton. :D
Great, thanks!
Igorsch
Post by Igorsch »
SubJunk wrote: Sun Apr 08, 2018 7:38 pm Yes please try it and let me know if it works Igorsch
The link above does the job! The problem is solved on Windows 8.1 x64. Thanks!
Re: [Solved] Played Status not working properly since I installed latest version
Thanks, Igorsch!
