Version 7.0.1 released
General:
This release improves folder scanning speed, memory use, support for Roku devices, fixes bugs and more!
Changes since 7.0.0:
  • General:
    • Improved thumbnail support
    • Improved folder scanning speed
    • Reduced memory use during folder scanning
    • Fixed fully played feature on clean installs
    • Fixed tsMuxeR FFmpeg support
    • Updated UMS.conf with changes from 7.0.0
  • Languages:
    • Updated German, Italian, Norwegian, Russian and Swedish translations via Crowdin
  • Renderers:
    • Added support for Roku TV (NSP 8)
    • Improved support for Roku 3
Compatibility notes:
johng
Re: Version 7.0.1 released
Post by johng »
I downloaded the MacOS 7.0.1 release but the application itself appears to be damaged.
JG
Rara
Post by Rara »
same under Windows, application does not start
Rara
Post by Rara »
7.0 RC 2 runs like a charm.
Update to 7.0 or 7.0.1 not possible.
I just installed 7.0.1 on Windows and it ran no problem so it must be some more specific bug. Can you post logs?
squadjot
Post by squadjot »
Just a quick fyi, when i press "download latest update" button in 7.0 i just get the "No update avail"-msg
Dosageko
Post by Dosageko »
same hide / true variable Problem on 7.01
example:
unchecked! Checkbox "hide recently played" is writing "show_recently_played_folder = false" in ums.conf
same for at least some other checkboxes on the gui
it looks like some hide / show variable definations got mixed reversed
Windows Edition
That must be happening for a non-English language? You can help us fix it in Crowdin
johng
Post by johng »
So this is what happens when I download the disk image for MacOS
Image downloads and mounts OK
When I try to open UMS this comes up:
"Universal Media Server" is damaged and can't be opened. You should eject the disk image.
"Universal Media Server" is on the disk image "UMS-7.0.1.dmg". Safari downloaded this image today at 8.03am from github.com
