OS Mojave error & solution(macos - "APP can't be opened. You should move it to trash.)
i found a solution to this error
open terminal type : sudo spctl --master-disable
the app will bypass the restriction and allow you to open it
- Screenshot 2018-10-10 at 23.56.13.jpg (114.65 KiB) Viewed 9016 times
