High Sierra Web Interface
valib
Re: High Sierra Web Interface
Post by valib »
Hi windhillwebs. From your log I see that your PC is not powerful enough to transcode on the fly. To be able to transcode the FFmpeg transcoding speed must be higher than 1 but your is 0,7 on average.
You can try to limit the maximum bitrate. Now you have default value
maximum_bitrate = 90
but the estimated bitrate for your WDTVLiveHub is about 30 Mb/s. Try to use automatic maximum bandwidth.
Hi windhillwebs, thanks for your post. We have a change coming up that will increase transcoding speed for the web interface a lot.
If you're interested you can follow the issue for it on our tracker https://github.com/UniversalMediaServer ... ssues/1578
