No GUI.....
sonor
No GUI.....
Post by sonor »
debug.log
(9.78 KiB) Downloaded 444 times
Hello my system is 10.6.8 and UMS 3.0.0 - tv Sharp Aquos....
the server runs so completely well, but I can not make adjustments....
No GUI ? Where is it?
Can you help me?
Optimus_prime
Re: No GUI.....
Post by Optimus_prime »
OK, no Gui but the server is running. What version of Java are you running
sonor
Re: No GUI.....
Post by sonor »
not so easy to find out.....
Terminal say:
java -version
java version "1.6.0_65"
Java(TM) SE Runtime Environment (build 1.6.0_65-b14-462-10M4609)
Java HotSpot(TM) 64-Bit Server VM (build 20.65-b04-462, mixed mode)
