UMS 7.6.0 - WD TV Live - MKV
since the update from 7.5.0 to 7.6.0 some of my MKV files make problems. They can't be played of unkown reasons.
I use UMS since 7.3.0 and this problem is only since 7.6.0. All versions before played (all) the MKV's which make now problems.
And i reinstalled older versions to be 100% sure.
Bye, Peter
Bye, Peter
Re: UMS 7.6.0 - WD TV Live - MKV
Should i really make in my case a LOG-File?
Sure ,that is the best thing to do .
Hello Community,
here is the log file.
I restarted UMS 7.6.0 in Trace Mode and then i switched on the WD TV Live and tried to start a MKV file which is not playable anymore since 7.6.0 (7.5.0 and all older versions were fine)
Thanks in advance!
Thanks in advance!
I tested right now: UMS 7.6.1
... and the error is still there. Some MKV's are not playable which played before 7.6.0...
