Double files MPEG
Cinemaction
Double files MPEG
Post by Cinemaction »
Hi everyone,
I'm an beginner of UMS, I usually play video format : x-matroska. It work really well.
But when I play One video, the video duplicate into a format : mpeg with size 0,00 and when I try to play it, the name of the file is the same of the original it's say " continuing video : "name of my video" but nothing appear..
My question is : How can I remove all the double files ?
Thank's for answer
I'm using Mac book pro on a Smart TV samsung 2018
Cinemaction
Re: Double files MPEG
no one ?
If you read the text in red above you might have more luck.
