Version 3.1.2 is released
General:
This release fixes video compatibility bugs, improves stability when using the resume feature, has minor GUI improvements and other bug fixes.
Changes since 3.1.1:
  • General:
    • Added tooltips to more options
    • Changed the appearance of tooltips
    • Removed the ability to set both FFmpeg muxing options at the same time in the GUI
    • Minor GUI improvements
    • Made the resume feature more stable
    • Fixed video compatibility bugs
    • Fixed FFmpeg on Linux systems which do not have FFmpeg installed
Upgrade Notes:
For 3.0.0-b1 and newer:
No action necessary.
For all versions below 3.0.0-b1:
D-Kalck
Re: Version 3.1.2 is released
Post by D-Kalck »
The duration is still not fixed on PS3.
D-Kalck wrote:The duration is still not fixed on PS3.
linky
D-Kalck
Post by D-Kalck »
So here is the log :
TRACE 2013-11-25 14:26:02.968 [New I/O server boss #34] Creating new pipeline
TRACE 2013-11-25 14:26:02.968 [New I/O worker #33] Opened request handler on socket /192.168.10.30:50534
TRACE 2013-11-25 14:26:02.969 [New I/O worker #33] Request: HTTP/1.0 : HEAD : get/0$4$5$5$33/Castle.S05E12.FRENCH.720p.WEB-DL.H264-MiND.mkv
TRACE 2013-11-25 14:26:02.969 [New I/O worker #33] Matched media renderer "PlayStation 3" based on address /192.168.10.30
TRACE 2013-11-25 14:26:02.969 [New I/O worker #33] Received on socket: Accept-Encoding: identity
TRACE 2013-11-25 14:26:02.969 [New I/O worker #33] Received on socket: Cache-Control: no-cache
TRACE 2013-11-25 14:26:02.969 [New I/O worker #33] Received on socket: Connection: close
TRACE 2013-11-25 14:26:02.969 [New I/O worker #33] Received on socket: Host: 192.168.10.10:5001
TRACE 2013-11-25 14:26:02.969 [New I/O worker #33] Received on socket: User-Agent: PLAYSTATION 3
TRACE 2013-11-25 14:26:02.969 [New I/O worker #33] Recognized media renderer: PlayStation 3
TRACE 2013-11-25 14:26:02.969 [New I/O worker #33] HTTP: get/0$4$5$5$33/Castle.S05E12.FRENCH.720p.WEB-DL.H264-MiND.mkv / 0-0
TRACE 2013-11-25 14:26:02.969 [New I/O worker #33] discover 0 refresh forced: false
TRACE 2013-11-25 14:26:02.969 [New I/O worker #33] discover 0$4 refresh forced: false
TRACE 2013-11-25 14:26:02.969 [New I/O worker #33] discover 0$4$5 refresh forced: false
TRACE 2013-11-25 14:26:02.969 [New I/O worker #33] discover 0$4$5$5 refresh forced: false
TRACE 2013-11-25 14:26:02.969 [New I/O worker #33] Asked stream chunk : TimeRange [start=null, end=null] of Castle.S05E12.FRENCH.720p.WEB-DL.H264-MiND.mkv and player MEncoder
DEBUG 2013-11-25 14:26:02.970 [New I/O worker #33] Starting transcode/remux of Castle.S05E12.FRENCH.720p.WEB-DL.H264-MiND.mkv with media info: container: mkv, bitrate: 4475246, size: 1388436070, video codec: h264, duration: 00:41:21,00, width: 1280, height: 720, frame rate: 25.000, thumb size : 8205, muxing mode: null, mime type: video/x-matroska
	Audio track id: 0, lang: fr, flavor: castle.s05e12.french.720p.web-dl.h264-mind, audio codec: AC3, sample frequency:48000, number of channels: 2, bits per sample: 16
TRACE 2013-11-25 14:26:02.970 [New I/O worker #33] Looking for an audio track with lang: fre
TRACE 2013-11-25 14:26:02.970 [New I/O worker #33] Matched audio track: id: 0, lang: fr, flavor: castle.s05e12.french.720p.web-dl.h264-mind, audio codec: AC3, sample frequency:48000, number of channels: 2, bits per sample: 16
TRACE 2013-11-25 14:26:02.970 [New I/O worker #33] Searching for a match for: fr with fr and off
TRACE 2013-11-25 14:26:02.970 [New I/O worker #33]  Disabled the subtitles: id: 0, type: UNKNOWN, flavor: null, lang: off, externalFileCharacterSet: null
DEBUG 2013-11-25 14:26:02.972 [New I/O worker #33] Starting "D:\Image & Video (x86)\Universal Media Server\win32\ffmpeg.exe" -i "F:\Castle\Saison 5\Castle.S05E12.FRENCH.720p.WEB-DL.H264-MiND.mkv" -vframes 1 -c:v copy -f h264 -bsf h264_mp4toannexb -an -y pipe:
TRACE 2013-11-25 14:26:02.974 [New I/O worker #33] Successfully initialized buffer to 1 048 576 bytes.
DEBUG 2013-11-25 14:26:02.974 [New I/O worker #33] Attaching thread: ffmpeg.exe-34
DEBUG 2013-11-25 14:26:02.996 [Thread-160] ffmpeg version N-53724-g716dbc7 Copyright (c) 2000-2013 the FFmpeg developers
DEBUG 2013-11-25 14:26:02.996 [Thread-160]   built on May 31 2013 23:33:02 with gcc 4.8.0 (GCC)
DEBUG 2013-11-25 14:26:02.996 [Thread-160]   configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetype --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib
DEBUG 2013-11-25 14:26:02.996 [Thread-160]   libavutil      52. 34.100 / 52. 34.100
DEBUG 2013-11-25 14:26:02.996 [Thread-160]   libavcodec     55. 12.102 / 55. 12.102
DEBUG 2013-11-25 14:26:02.996 [Thread-160]   libavformat    55.  8.102 / 55.  8.102
DEBUG 2013-11-25 14:26:02.996 [Thread-160]   libavdevice    55.  2.100 / 55.  2.100
DEBUG 2013-11-25 14:26:02.996 [Thread-160]   libavfilter     3. 73.100 /  3. 73.100
DEBUG 2013-11-25 14:26:02.996 [Thread-160]   libswscale      2.  3.100 /  2.  3.100
DEBUG 2013-11-25 14:26:02.996 [Thread-160]   libswresample   0. 17.102 /  0. 17.102
DEBUG 2013-11-25 14:26:02.996 [Thread-160]   libpostproc    52.  3.100 / 52.  3.100
DEBUG 2013-11-25 14:26:03.020 [Thread-160] Input #0, matroska,webm, from 'F:\Castle\Saison 5\Castle.S05E12.FRENCH.720p.WEB-DL.H264-MiND.mkv':
DEBUG 2013-11-25 14:26:03.020 [Thread-160]   Metadata:
DEBUG 2013-11-25 14:26:03.020 [Thread-160]     title           : Castle.S05E12.FRENCH.720p.WEB-DL.H264-MiND
DEBUG 2013-11-25 14:26:03.021 [Thread-160]     creation_time   : 2013-09-09 06:20:59
DEBUG 2013-11-25 14:26:03.021 [Thread-160]   Duration: 00:41:21.98, start: 0.000000, bitrate: 4475 kb/s
DEBUG 2013-11-25 14:26:03.021 [Thread-160]     Stream #0:0(fre): Video: h264 (High), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 25 fps, 25 tbr, 1k tbn, 2k tbc (default)
DEBUG 2013-11-25 14:26:03.021 [Thread-160]     Metadata:
DEBUG 2013-11-25 14:26:03.021 [Thread-160]       title           : Castle.S05E12.FRENCH.720p.WEB-DL.H264-MiND
DEBUG 2013-11-25 14:26:03.021 [Thread-160]     Stream #0:1(fre): Audio: ac3, 48000 Hz, stereo, fltp, 192 kb/s (default)
DEBUG 2013-11-25 14:26:03.022 [Thread-160] Output #0, h264, to 'pipe:':
DEBUG 2013-11-25 14:26:03.022 [Thread-160]   Metadata:
DEBUG 2013-11-25 14:26:03.022 [Thread-160]     title           : Castle.S05E12.FRENCH.720p.WEB-DL.H264-MiND
DEBUG 2013-11-25 14:26:03.022 [Thread-160]     encoder         : Lavf55.8.102
DEBUG 2013-11-25 14:26:03.022 [Thread-160]     Stream #0:0(fre): Video: h264, yuv420p, 1280x720 [SAR 1:1 DAR 16:9], q=2-31, 25 fps, 90k tbn, 1k tbc (default)
DEBUG 2013-11-25 14:26:03.023 [Thread-160] Stream mapping:
DEBUG 2013-11-25 14:26:03.023 [Thread-160]   Stream #0:0 -> #0:0 (copy)
DEBUG 2013-11-25 14:26:03.023 [Thread-160] Press [q] to stop, [?] for help
DEBUG 2013-11-25 14:26:03.023 [Thread-160] frame=    1 fps=0.0 q=-1.0 Lsize=       3kB time=00:00:00.-3 bitrate=N/A
DEBUG 2013-11-25 14:26:03.023 [Thread-160] video:3kB audio:0kB subtitle:0 global headers:0kB muxing overhead 2.710945%
TRACE 2013-11-25 14:26:03.025 [New I/O worker #33] EOF
TRACE 2013-11-25 14:26:03.025 [New I/O worker #33] Ready to Stop: true
TRACE 2013-11-25 14:26:03.025 [New I/O worker #33] Format "mpegts" failed to match supported line f:mpegps     v:mpeg1|mpeg2|mp4|h264   a:ac3|lpcm           m:video/mpeg
TRACE 2013-11-25 14:26:03.026 [New I/O worker #33] Matched support line f:mpegts     v:mpeg1|mpeg2|mp4|h264   a:ac3|lpcm|mpa       m:video/mpeg
TRACE 2013-11-25 14:26:03.029 [New I/O worker #33] Searching for a match for: fr with fr and off
TRACE 2013-11-25 14:26:03.029 [New I/O worker #33]  Disabled the subtitles: id: 0, type: UNKNOWN, flavor: null, lang: off, externalFileCharacterSet: null
DEBUG 2013-11-25 14:26:03.030 [New I/O worker #33] Creating pipe \\.\pipe\1385385963030ffmpegvideo
DEBUG 2013-11-25 14:26:03.031 [New I/O worker #33] Creating pipe \\.\pipe\1385385963030videoout
DEBUG 2013-11-25 14:26:03.031 [Thread-164] Waiting for pipe connection \\.\pipe\1385385963030ffmpegvideo
DEBUG 2013-11-25 14:26:03.031 [Thread-165] Waiting for pipe connection \\.\pipe\1385385963030videoout
DEBUG 2013-11-25 14:26:03.031 [New I/O worker #33] Creating pipe \\.\pipe\1385385963031ffmpegaudio01
DEBUG 2013-11-25 14:26:03.031 [New I/O worker #33] Creating pipe \\.\pipe\1385385963031audioout
TRACE 2013-11-25 14:26:03.031 [New I/O worker #33] Matched support line f:mpegps     v:mpeg1|mpeg2|mp4|h264   a:ac3|lpcm           m:video/mpeg
DEBUG 2013-11-25 14:26:03.032 [Thread-169] Waiting for pipe connection \\.\pipe\1385385963031audioout
DEBUG 2013-11-25 14:26:03.032 [Thread-168] Waiting for pipe connection \\.\pipe\1385385963031ffmpegaudio01
TRACE 2013-11-25 14:26:03.032 [New I/O worker #33] Matched support line f:mpegps     v:mpeg1|mpeg2|mp4|h264   a:ac3|lpcm           m:video/mpeg
DEBUG 2013-11-25 14:26:03.032 [New I/O worker #33] Creating pipe \\.\pipe\1385385963032tsmuxerout.ts
DEBUG 2013-11-25 14:26:03.033 [Thread-171] Waiting for pipe connection \\.\pipe\1385385963032tsmuxerout.ts
DEBUG 2013-11-25 14:26:03.133 [mencoder.exe-35] Starting "D:\Image & Video (x86)\Universal Media Server\win32\mencoder.exe" -ss 0 "F:\Castle\Saison 5\Castle.S05E12.FRENCH.720p.WEB-DL.H264-MiND.mkv" -quiet -quiet -really-quiet -msglevel statusline=2 -ovc copy -nosound -mc 0 -noskip -of rawvideo -o \\.\pipe\1385385963030ffmpegvideo
TRACE 2013-11-25 14:26:03.134 [mencoder.exe-35] Successfully initialized buffer to 1 048 576 bytes.
DEBUG 2013-11-25 14:26:03.134 [mencoder.exe-35] Attaching thread: mencoder.exe-35
DEBUG 2013-11-25 14:26:03.172 [Thread-164] Result of \\.\pipe\1385385963030ffmpegvideo : true
DEBUG 2013-11-25 14:26:03.233 [mencoder.exe-36] Starting "D:\Image & Video (x86)\Universal Media Server\win32\mencoder.exe" -ss 0 "F:\Castle\Saison 5\Castle.S05E12.FRENCH.720p.WEB-DL.H264-MiND.mkv" -quiet -quiet -really-quiet -msglevel statusline=2 -channels 2 -ovc copy -of rawaudio -mc 0 -noskip -oac copy -fafmttag 0x2000 -lavcopts acodec=ac3:abitrate=448 -af lavcresample=48000 -srate 48000 -quiet -quiet -o \\.\pipe\1385385963031ffmpegaudio01
TRACE 2013-11-25 14:26:03.235 [mencoder.exe-36] Successfully initialized buffer to 1 048 576 bytes.
DEBUG 2013-11-25 14:26:03.235 [mencoder.exe-36] Attaching thread: mencoder.exe-36
DEBUG 2013-11-25 14:26:03.278 [Thread-168] Result of \\.\pipe\1385385963031ffmpegaudio01 : true
DEBUG 2013-11-25 14:26:03.333 [New I/O worker #33] External input stream instance is null... sounds not good, waiting 500ms
DEBUG 2013-11-25 14:26:03.333 [tsMuxeR-new.exe-37] Starting "D:\Image & Video (x86)\Universal Media Server\win32\tsMuxeR-new.exe" C:\Users\D-Kalck\AppData\Local\Temp\universalmediaserver\pms-tsmuxer.meta \\.\pipe\1385385963032tsmuxerout.ts
DEBUG 2013-11-25 14:26:03.334 [tsMuxeR-new.exe-37] Reading pipe: \\.\pipe\1385385963032tsmuxerout.ts
TRACE 2013-11-25 14:26:03.337 [tsMuxeR-new.exe-37] Successfully initialized buffer to 52 428 800 bytes.
DEBUG 2013-11-25 14:26:03.337 [tsMuxeR-new.exe-37] Attaching thread: tsMuxeR-new.exe-37
TRACE 2013-11-25 14:26:03.337 [Timer-37] buffered: 0 bytes / inputs: 0
DEBUG 2013-11-25 14:26:03.374 [Thread-182] Network Optix tsMuxeR.  Version 2.2.3(b). www.networkoptix.com
DEBUG 2013-11-25 14:26:03.575 [Thread-169] Forced reconnection of \\.\pipe\1385385963031audioout with result : true
DEBUG 2013-11-25 14:26:03.575 [Thread-165] Forced reconnection of \\.\pipe\1385385963030videoout with result : true
DEBUG 2013-11-25 14:26:03.575 [Thread-169] Result of \\.\pipe\1385385963031audioout : true
DEBUG 2013-11-25 14:26:03.575 [Thread-165] Result of \\.\pipe\1385385963030videoout : true
DEBUG 2013-11-25 14:26:03.576 [Thread-182] Decoding H264 stream (track 1): Profile: [email protected]  Resolution: 1280:720p  Frame rate: not found
DEBUG 2013-11-25 14:26:03.576 [Thread-182] Change H264 level from 3.1 to 4.1
DEBUG 2013-11-25 14:26:03.576 [Thread-182] H.264 stream doesn't contain fps field. Muxing fps=25
DEBUG 2013-11-25 14:26:03.579 [Thread-171] Result of \\.\pipe\1385385963032tsmuxerout.ts : true
DEBUG 2013-11-25 14:26:03.580 [Thread-182] 100.0% complete
DEBUG 2013-11-25 14:26:03.580 [Thread-182] H264 bitstream changed: insert nal unit delimiters
DEBUG 2013-11-25 14:26:03.580 [Thread-182] Decoding AC3 stream (track 2): Bitrate: 192Kbps Sample Rate: 48KHz Channels: 2
TRACE 2013-11-25 14:26:03.833 [New I/O worker #33] Matched support line f:mpegps     v:mpeg1|mpeg2|mp4|h264   a:ac3|lpcm           m:video/mpeg
TRACE 2013-11-25 14:26:03.833 [New I/O worker #33] Ready to Stop: true
INFO  2013-11-25 14:26:03.833 [StartPlaying Event] Started playing Castle.S05E12.FRENCH.720p.WEB-DL.H264-MiND.mkv on your PlayStation 3
DEBUG 2013-11-25 14:26:03.833 [StartPlaying Event] The full filename of which is: F:\Castle\Saison 5\Castle.S05E12.FRENCH.720p.WEB-DL.H264-MiND.mkv and the address of the renderer is: 192.168.10.30
TRACE 2013-11-25 14:26:03.833 [New I/O worker #33] Sent to socket: Accept-Ranges: bytes
TRACE 2013-11-25 14:26:03.834 [New I/O worker #33] Sent to socket: Connection: keep-alive
TRACE 2013-11-25 14:26:03.834 [New I/O worker #33] Sent to socket: Content-Type: video/mpeg
TRACE 2013-11-25 14:26:03.834 [New I/O worker #33] Sent to socket: Server: Windows_7-amd64-6.1, UPnP/1.0, UMS/3.1.2
TRACE 2013-11-25 14:26:03.837 [New I/O server boss #34] Creating new pipeline
TRACE 2013-11-25 14:26:03.838 [New I/O worker #18] Opened request handler on socket /192.168.10.30:50533
TRACE 2013-11-25 14:26:03.838 [New I/O worker #18] Request: HTTP/1.0 : GET : get/0$4$5$5$33/Castle.S05E12.FRENCH.720p.WEB-DL.H264-MiND.mkv
TRACE 2013-11-25 14:26:03.838 [New I/O worker #18] Matched media renderer "PlayStation 3" based on address /192.168.10.30
TRACE 2013-11-25 14:26:03.838 [New I/O worker #18] Received on socket: Accept-Encoding: identity
TRACE 2013-11-25 14:26:03.838 [New I/O worker #18] Received on socket: Cache-Control: no-cache
TRACE 2013-11-25 14:26:03.838 [New I/O worker #18] Received on socket: Connection: close
TRACE 2013-11-25 14:26:03.838 [New I/O worker #18] Received on socket: Host: 192.168.10.10:5001
TRACE 2013-11-25 14:26:03.838 [New I/O worker #18] Received on socket: User-Agent: PLAYSTATION 3
TRACE 2013-11-25 14:26:03.838 [New I/O worker #18] Recognized media renderer: PlayStation 3
TRACE 2013-11-25 14:26:03.838 [New I/O worker #18] HTTP: get/0$4$5$5$33/Castle.S05E12.FRENCH.720p.WEB-DL.H264-MiND.mkv / 0-0
TRACE 2013-11-25 14:26:03.838 [New I/O worker #18] discover 0 refresh forced: false
TRACE 2013-11-25 14:26:03.838 [New I/O worker #18] discover 0$4 refresh forced: false
TRACE 2013-11-25 14:26:03.838 [New I/O worker #18] discover 0$4$5 refresh forced: false
TRACE 2013-11-25 14:26:03.838 [New I/O worker #18] discover 0$4$5$5 refresh forced: false
TRACE 2013-11-25 14:26:03.838 [New I/O worker #18] Asked stream chunk : TimeRange [start=null, end=null] of Castle.S05E12.FRENCH.720p.WEB-DL.H264-MiND.mkv and player MEncoder
TRACE 2013-11-25 14:26:03.838 [New I/O worker #18] Ready to Stop: false
TRACE 2013-11-25 14:26:03.839 [New I/O worker #18] Matched support line f:mpegps     v:mpeg1|mpeg2|mp4|h264   a:ac3|lpcm           m:video/mpeg
TRACE 2013-11-25 14:26:03.839 [New I/O worker #18] Sent to socket: Accept-Ranges: bytes
TRACE 2013-11-25 14:26:03.839 [New I/O worker #18] Sent to socket: Connection: keep-alive
TRACE 2013-11-25 14:26:03.839 [New I/O worker #18] Sent to socket: Content-Type: video/mpeg
TRACE 2013-11-25 14:26:03.839 [New I/O worker #18] Sent to socket: Server: Windows_7-amd64-6.1, UPnP/1.0, UMS/3.1.2
TRACE 2013-11-25 14:26:03.843 [New I/O worker #18] Ready to Stop: true
TRACE 2013-11-25 14:26:03.845 [New I/O server boss #34] Creating new pipeline
TRACE 2013-11-25 14:26:03.845 [New I/O worker #19] Opened request handler on socket /192.168.10.30:50532
TRACE 2013-11-25 14:26:03.845 [New I/O worker #19] Request: HTTP/1.1 : GET : get/0$4$5$5$33/Castle.S05E12.FRENCH.720p.WEB-DL.H264-MiND.mkv
TRACE 2013-11-25 14:26:03.845 [New I/O worker #19] Matched media renderer "PlayStation 3" based on address /192.168.10.30
TRACE 2013-11-25 14:26:03.845 [New I/O worker #19] Received on socket: Accept-Encoding: identity
TRACE 2013-11-25 14:26:03.845 [New I/O worker #19] Received on socket: Connection: Keep-Alive
TRACE 2013-11-25 14:26:03.845 [New I/O worker #19] Received on socket: Host: 192.168.10.10:5001
TRACE 2013-11-25 14:26:03.845 [New I/O worker #19] Received on socket: TimeSeekRange.dlna.org: npt=0.000-
TRACE 2013-11-25 14:26:03.845 [New I/O worker #19] Received on socket: transferMode.dlna.org: Streaming
TRACE 2013-11-25 14:26:03.845 [New I/O worker #19] Received on socket: User-Agent: PLAYSTATION 3
TRACE 2013-11-25 14:26:03.845 [New I/O worker #19] Received on socket: X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment"; mn="PLAYSTATION 3"; mv="1.0";
TRACE 2013-11-25 14:26:03.845 [New I/O worker #19] Recognized media renderer: PlayStation 3
TRACE 2013-11-25 14:26:03.845 [New I/O worker #19] HTTP: get/0$4$5$5$33/Castle.S05E12.FRENCH.720p.WEB-DL.H264-MiND.mkv / 0-0
TRACE 2013-11-25 14:26:03.846 [New I/O worker #19] discover 0 refresh forced: false
TRACE 2013-11-25 14:26:03.846 [New I/O worker #19] discover 0$4 refresh forced: false
TRACE 2013-11-25 14:26:03.846 [New I/O worker #19] discover 0$4$5 refresh forced: false
TRACE 2013-11-25 14:26:03.846 [New I/O worker #19] discover 0$4$5$5 refresh forced: false
TRACE 2013-11-25 14:26:03.846 [New I/O worker #19] Asked stream chunk : TimeRange [start=0.0, end=null] of Castle.S05E12.FRENCH.720p.WEB-DL.H264-MiND.mkv and player MEncoder
TRACE 2013-11-25 14:26:03.846 [New I/O worker #19] Ready to Stop: false
TRACE 2013-11-25 14:26:03.846 [New I/O worker #19] Matched support line f:mpegps     v:mpeg1|mpeg2|mp4|h264   a:ac3|lpcm           m:video/mpeg
TRACE 2013-11-25 14:26:03.847 [New I/O worker #19] Sent to socket: Accept-Ranges: bytes
TRACE 2013-11-25 14:26:03.847 [New I/O worker #19] Sent to socket: Connection: keep-alive
TRACE 2013-11-25 14:26:03.847 [New I/O worker #19] Sent to socket: Content-Type: video/mpeg
TRACE 2013-11-25 14:26:03.847 [New I/O worker #19] Sent to socket: Server: Windows_7-amd64-6.1, UPnP/1.0, UMS/3.1.2
TRACE 2013-11-25 14:26:03.847 [New I/O worker #19] Sent to socket: TimeSeekRange.dlna.org: npt=00:00:00.00-00:41:21,00/00:41:21,00
TRACE 2013-11-25 14:26:03.847 [New I/O worker #19] Sent to socket: TransferMode.DLNA.ORG: Streaming
TRACE 2013-11-25 14:26:03.847 [New I/O worker #19] Sent to socket: X-Seek-Range: npt=00:00:00.00-00:41:21,00/00:41:21,00
DEBUG 2013-11-25 14:26:03.858 [Thread-182] 100.0% complete
TRACE 2013-11-25 14:26:04.101 [Thread-180] Successfully grown buffer from 52 428 800 bytes to 104 857 600 bytes.
DEBUG 2013-11-25 14:26:04.109 [Thread-182] 100.0% complete
DEBUG 2013-11-25 14:26:04.360 [Thread-182] 100.0% complete
TRACE 2013-11-25 14:26:05.337 [Timer-37] buffered: 85 254 815 bytes / inputs: 1
DEBUG 2013-11-25 14:26:05.526 [Buffered IO End Checker] Stopping process: ffmpeg.exe-34
TRACE 2013-11-25 14:26:05.526 [Buffered IO End Checker] Destroying buffer
TRACE 2013-11-25 14:26:05.741 [New I/O worker #19] Ready to Stop: true
TRACE 2013-11-25 14:26:05.742 [New I/O server boss #34] Creating new pipeline
TRACE 2013-11-25 14:26:05.742 [New I/O worker #20] Opened request handler on socket /192.168.10.30:50531
TRACE 2013-11-25 14:26:05.742 [New I/O worker #20] Request: HTTP/1.1 : GET : get/0$4$5$5$33/Castle.S05E12.FRENCH.720p.WEB-DL.H264-MiND.mkv
TRACE 2013-11-25 14:26:05.742 [New I/O worker #20] Matched media renderer "PlayStation 3" based on address /192.168.10.30
TRACE 2013-11-25 14:26:05.742 [New I/O worker #20] Received on socket: Accept-Encoding: identity
TRACE 2013-11-25 14:26:05.742 [New I/O worker #20] Received on socket: Connection: Keep-Alive
TRACE 2013-11-25 14:26:05.742 [New I/O worker #20] Received on socket: Host: 192.168.10.10:5001
TRACE 2013-11-25 14:26:05.742 [New I/O worker #20] Received on socket: TimeSeekRange.dlna.org: npt=0.000-
TRACE 2013-11-25 14:26:05.742 [New I/O worker #20] Received on socket: transferMode.dlna.org: Streaming
TRACE 2013-11-25 14:26:05.742 [New I/O worker #20] Received on socket: User-Agent: PLAYSTATION 3
TRACE 2013-11-25 14:26:05.742 [New I/O worker #20] Received on socket: X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment"; mn="PLAYSTATION 3"; mv="1.0";
TRACE 2013-11-25 14:26:05.742 [New I/O worker #20] Recognized media renderer: PlayStation 3
TRACE 2013-11-25 14:26:05.742 [New I/O worker #20] HTTP: get/0$4$5$5$33/Castle.S05E12.FRENCH.720p.WEB-DL.H264-MiND.mkv / 0-0
TRACE 2013-11-25 14:26:05.743 [New I/O worker #20] discover 0 refresh forced: false
TRACE 2013-11-25 14:26:05.743 [New I/O worker #20] discover 0$4 refresh forced: false
TRACE 2013-11-25 14:26:05.743 [New I/O worker #20] discover 0$4$5 refresh forced: false
TRACE 2013-11-25 14:26:05.743 [New I/O worker #20] discover 0$4$5$5 refresh forced: false
TRACE 2013-11-25 14:26:05.743 [New I/O worker #20] Asked stream chunk : TimeRange [start=0.0, end=null] of Castle.S05E12.FRENCH.720p.WEB-DL.H264-MiND.mkv and player MEncoder
TRACE 2013-11-25 14:26:05.743 [New I/O worker #20] Ready to Stop: false
TRACE 2013-11-25 14:26:05.743 [New I/O worker #20] Matched support line f:mpegps     v:mpeg1|mpeg2|mp4|h264   a:ac3|lpcm           m:video/mpeg
TRACE 2013-11-25 14:26:05.744 [New I/O worker #20] Sent to socket: Accept-Ranges: bytes
TRACE 2013-11-25 14:26:05.744 [New I/O worker #20] Sent to socket: Connection: keep-alive
TRACE 2013-11-25 14:26:05.744 [New I/O worker #20] Sent to socket: Content-Type: video/mpeg
TRACE 2013-11-25 14:26:05.744 [New I/O worker #20] Sent to socket: Server: Windows_7-amd64-6.1, UPnP/1.0, UMS/3.1.2
TRACE 2013-11-25 14:26:05.744 [New I/O worker #20] Sent to socket: TimeSeekRange.dlna.org: npt=00:00:00.00-00:41:21,00/00:41:21,00
TRACE 2013-11-25 14:26:05.744 [New I/O worker #20] Sent to socket: TransferMode.DLNA.ORG: Streaming
TRACE 2013-11-25 14:26:05.744 [New I/O worker #20] Sent to socket: X-Seek-Range: npt=00:00:00.00-00:41:21,00/00:41:21,00
DEBUG 2013-11-25 14:26:05.867 [Thread-182] 100.0% complete
DEBUG 2013-11-25 14:26:06.375 [Thread-182] 100.0% complete
TRACE 2013-11-25 14:26:07.337 [Timer-37] buffered: 84 545 855 bytes / inputs: 1
DEBUG 2013-11-25 14:26:07.885 [Thread-182] 100.0% complete
TRACE 2013-11-25 14:26:09.337 [Timer-37] buffered: 84 866 495 bytes / inputs: 1
DEBUG 2013-11-25 14:26:09.889 [Thread-182] 100.0% complete
TRACE 2013-11-25 14:26:11.337 [Timer-37] buffered: 84 581 215 bytes / inputs: 1
TRACE 2013-11-25 14:26:13.337 [Timer-37] buffered: 84 619 839 bytes / inputs: 1
DEBUG 2013-11-25 14:26:13.389 [Thread-182] 100.0% complete
TRACE 2013-11-25 14:26:13.503 [UPNPHelper] Receiving a M-SEARCH from [192.168.10.10:52100]
TRACE 2013-11-25 14:26:13.546 [UPNPHelper] Receiving a M-SEARCH from [192.168.10.10:52100]
TRACE 2013-11-25 14:26:13.546 [UPNPHelper] Sending this reply [192.168.10.10:52100]: HTTP/1.1 200 OK<CRLF>CACHE-CONTROL: max-age=1200<CRLF>DATE: Mon, 25 Nov 2013 13:26:13 GMT<CRLF>LOCATION: http://192.168.10.10:5001/description/fetch<CRLF>SERVER: Windows_7-amd64-6.1, UPnP/1.0, UMS/3.1.2<CRLF>ST: urn:schemas-upnp-org:device:MediaServer:1<CRLF>EXT: <CRLF>USN: uuid:cf939cd0-d1e8-47a1-8ed9-223ec5ba8dae::urn:schemas-upnp-org:device:MediaServer:1<CRLF>Content-Length: 0<CRLF><CRLF>
TRACE 2013-11-25 14:26:13.587 [UPNPHelper] Receiving a M-SEARCH from [192.168.10.10:52100]
TRACE 2013-11-25 14:26:13.627 [UPNPHelper] Receiving a M-SEARCH from [192.168.10.10:52100]
TRACE 2013-11-25 14:26:13.667 [UPNPHelper] Receiving a M-SEARCH from [192.168.10.10:52100]
TRACE 2013-11-25 14:26:13.667 [UPNPHelper] Sending this reply [192.168.10.10:52100]: HTTP/1.1 200 OK<CRLF>CACHE-CONTROL: max-age=1200<CRLF>DATE: Mon, 25 Nov 2013 13:26:13 GMT<CRLF>LOCATION: http://192.168.10.10:5001/description/fetch<CRLF>SERVER: Windows_7-amd64-6.1, UPnP/1.0, UMS/3.1.2<CRLF>ST: urn:schemas-upnp-org:device:MediaServer:1<CRLF>EXT: <CRLF>USN: uuid:cf939cd0-d1e8-47a1-8ed9-223ec5ba8dae::urn:schemas-upnp-org:device:MediaServer:1<CRLF>Content-Length: 0<CRLF><CRLF>
TRACE 2013-11-25 14:26:13.707 [UPNPHelper] Receiving a M-SEARCH from [192.168.10.10:52100]
TRACE 2013-11-25 14:26:15.338 [Timer-37] buffered: 84 809 119 bytes / inputs: 1
DEBUG 2013-11-25 14:26:16.390 [Thread-182] 100.0% complete
TRACE 2013-11-25 14:26:17.338 [Timer-37] buffered: 84 839 263 bytes / inputs: 1
TRACE 2013-11-25 14:26:19.338 [Timer-37] buffered: 85 156 127 bytes / inputs: 1
DEBUG 2013-11-25 14:26:20.890 [Thread-182] 100.0% complete
TRACE 2013-11-25 14:26:21.338 [Timer-37] buffered: 84 755 007 bytes / inputs: 1
TRACE 2013-11-25 14:26:23.338 [Timer-37] buffered: 84 629 791 bytes / inputs: 1
Wolfgan
Post by Wolfgan »
Thanks for the new release. Will test and report back. Wolf
ExSport
Post by ExSport »
Root cause is:
There should be no ","
I supposed v3.1.2 fixed it but supposedly not 8-)
Does this one fix it?
D-Kalck
Post by D-Kalck »
Nope, and here is the log :
TRACE 2013-11-26 08:38:18.732 [New I/O server boss #17] Creating new pipeline
TRACE 2013-11-26 08:38:18.733 [New I/O worker #1] Opened request handler on socket /192.168.10.30:50132
TRACE 2013-11-26 08:38:18.733 [New I/O worker #1] Request: HTTP/1.0 : HEAD : get/0$9$1$23$4/Very+Bad+Trip+3.m2ts
TRACE 2013-11-26 08:38:18.733 [New I/O worker #1] Matched media renderer "PlayStation 3" based on address /192.168.10.30
TRACE 2013-11-26 08:38:18.733 [New I/O worker #1] Received on socket: Accept-Encoding: identity
TRACE 2013-11-26 08:38:18.733 [New I/O worker #1] Received on socket: Cache-Control: no-cache
TRACE 2013-11-26 08:38:18.733 [New I/O worker #1] Received on socket: Connection: close
TRACE 2013-11-26 08:38:18.733 [New I/O worker #1] Received on socket: Host: 192.168.10.10:5001
TRACE 2013-11-26 08:38:18.733 [New I/O worker #1] Received on socket: User-Agent: PLAYSTATION 3
TRACE 2013-11-26 08:38:18.733 [New I/O worker #1] Recognized media renderer: PlayStation 3
TRACE 2013-11-26 08:38:18.733 [New I/O worker #1] HTTP: get/0$9$1$23$4/Very+Bad+Trip+3.m2ts / 0-0
TRACE 2013-11-26 08:38:18.733 [New I/O worker #1] discover 0 refresh forced: false
TRACE 2013-11-26 08:38:18.733 [New I/O worker #1] discover 0$9 refresh forced: false
TRACE 2013-11-26 08:38:18.733 [New I/O worker #1] discover 0$9$1 refresh forced: false
TRACE 2013-11-26 08:38:18.733 [New I/O worker #1] discover 0$9$1$23 refresh forced: false
TRACE 2013-11-26 08:38:18.733 [New I/O worker #1] Asked stream chunk : TimeRange [start=null, end=null] of Very Bad Trip 3.m2ts and player MEncoder
DEBUG 2013-11-26 08:38:18.734 [New I/O worker #1] Starting transcode/remux of Very Bad Trip 3.m2ts with media info: container: mkv, bitrate: 11347150, size: 8523162003, video codec: h264, duration: 01:40:09,00, width: 1920, height: 800, frame rate: 23.976, thumb size : 11135, muxing mode: null, mime type: video/x-matroska
	Audio track id: 0, lang: fr, flavor: french ac3 640, audio codec: AC3, sample frequency:48000, number of channels: 6, bits per sample: 16, artist: , album: , song name: , year: 0, track: 0
	Audio track id: 1, lang: en, flavor: english dts 1509, audio codec: DTS, sample frequency:48000, number of channels: 6, bits per sample: 24, artist: , album: , song name: , year: 0, track: 0
	Subtitle track id: 0, type: SUBRIP, flavor: french_forced, lang: fr, externalFileCharacterSet: null
	Subtitle track id: 1, type: SUBRIP, flavor: french, lang: fr, externalFileCharacterSet: null
TRACE 2013-11-26 08:38:18.734 [New I/O worker #1] Looking for an audio track with lang: fre
TRACE 2013-11-26 08:38:18.734 [New I/O worker #1] Matched audio track: id: 0, lang: fr, flavor: french ac3 640, audio codec: AC3, sample frequency:48000, number of channels: 6, bits per sample: 16, artist: , album: , song name: , year: 0, track: 0
TRACE 2013-11-26 08:38:18.734 [New I/O worker #1] Searching for a match for: fr with fr and off
TRACE 2013-11-26 08:38:18.734 [New I/O worker #1]  Disabled the subtitles: id: 0, type: UNKNOWN, flavor: null, lang: off, externalFileCharacterSet: null
TRACE 2013-11-26 08:38:18.737 [New I/O worker #1] Forcing preferred subtitles : fr/french_forced
TRACE 2013-11-26 08:38:18.737 [New I/O worker #1] Forced subtitles track : id: 0, type: SUBRIP, flavor: french_forced, lang: fr, externalFileCharacterSet: null
TRACE 2013-11-26 08:38:18.737 [New I/O worker #1] channels=6
DEBUG 2013-11-26 08:38:18.743 [New I/O worker #1] Creating pipe \\.\pipe\mencoder1385451498743
TRACE 2013-11-26 08:38:18.760 [New I/O worker #1] Successfully initialized buffer to 52 428 800 bytes.
TRACE 2013-11-26 08:38:18.761 [Timer-30] buffered: 0 bytes / inputs: 0
DEBUG 2013-11-26 08:38:18.761 [mencoder.exe-30] Starting "D:\Image & Video (x86)\Universal Media Server\win32\mencoder.exe" -ss 0 "G:\The.Hangover.Part.III.2013.MULTi.TRUEFRENCH.1080p.BluRay.x264-LOST .mkv" -msglevel statusline=2 -oac copy -of mpeg -mpegopts format=mpeg2:muxrate=500000:vbuf_size=1194:abuf_size=64 -ovc lavc -channels 6 -lavdopts debug=0:threads=4 -lavcopts autoaspect=1:vcodec=mpeg2video:acodec=ac3:abitrate=640:threads=8:keyint=25:vqscale=1:vqmin=2:vqmax=3:vrc_maxrate=499000:vrc_buf_size=7000 -ass -ass-color ffffff00 -ass-border-color 00000000 -ass-font-scale 1.4 -font C:\Windows\Fonts\Arial.ttf -ass-force-style FontName=C:\Windows\Fonts\Arial.ttf,Outline=1,Shadow=1,MarginV=10 -fontconfig -aid 0 -noautosub -sid 0 -ofps 24000/1001 -lavdopts fast -mc 0 -noskip -o \\.\pipe\mencoder1385451498743
DEBUG 2013-11-26 08:38:18.761 [Thread-137] Waiting for pipe connection \\.\pipe\mencoder1385451498743
TRACE 2013-11-26 08:38:18.761 [UPNPHelper] Receiving a NOTIFY from [192.168.10.10:57355]
TRACE 2013-11-26 08:38:18.762 [UPNPHelper] Receiving a NOTIFY from [192.168.27.14:43997]
DEBUG 2013-11-26 08:38:18.764 [mencoder.exe-30] Reading pipe: \\.\pipe\mencoder1385451498743
DEBUG 2013-11-26 08:38:18.764 [mencoder.exe-30] Attaching thread: mencoder.exe-30
DEBUG 2013-11-26 08:38:18.779 [Thread-141] MEncoder SB53 (C) 2000-2013 MPlayer Team
DEBUG 2013-11-26 08:38:18.779 [Thread-141] Custom build by SubJunk, http://www.spirton.com
TRACE 2013-11-26 08:38:18.781 [UPNPHelper] Receiving a NOTIFY from [192.168.10.10:57356]
TRACE 2013-11-26 08:38:18.782 [UPNPHelper] Receiving a NOTIFY from [192.168.27.14:43997]
DEBUG 2013-11-26 08:38:18.782 [Thread-141] success: format: 0  data: 0x0 - 0xfc052193
DEBUG 2013-11-26 08:38:18.782 [Thread-141] libavformat version 55.21.100 (internal)
DEBUG 2013-11-26 08:38:18.785 [Thread-141] libavformat file format detected.
DEBUG 2013-11-26 08:38:18.792 [Thread-141] [lavf] stream 0: video (h264), -vid 0
DEBUG 2013-11-26 08:38:18.792 [Thread-141] [lavf] stream 1: audio (ac3), -aid 0, -alang fre, French AC3 640
DEBUG 2013-11-26 08:38:18.792 [Thread-141] [lavf] stream 2: audio (dca), -aid 1, -alang eng, English DTS 1509
DEBUG 2013-11-26 08:38:18.792 [Thread-141] [lavf] stream 3: subtitle (subrip), -sid 0, -slang fre, French_forced
DEBUG 2013-11-26 08:38:18.792 [Thread-141] [lavf] stream 4: subtitle (subrip), -sid 1, -slang fre, French
DEBUG 2013-11-26 08:38:18.792 [Thread-141] VIDEO:  [H264]  1920x800  0bpp  23.976 fps    0.0 kbps ( 0.0 kbyte/s)
DEBUG 2013-11-26 08:38:18.792 [Thread-141] [V] filefmt:44  fourcc:0x34363248  size:1920x800  fps:23.976  ftime:=0.0417
DEBUG 2013-11-26 08:38:18.792 [Thread-137] Result of \\.\pipe\mencoder1385451498743 : true
DEBUG 2013-11-26 08:38:18.793 [Thread-141] PACKET SIZE: 2048 bytes, deltascr: 884
DEBUG 2013-11-26 08:38:18.793 [Thread-141] libavcodec version 55.41.100 (internal)
DEBUG 2013-11-26 08:38:18.793 [Thread-141] Opening video filter: [ass auto=1]
DEBUG 2013-11-26 08:38:18.793 [Thread-141] [ass] auto-open
TRACE 2013-11-26 08:38:18.802 [UPNPHelper] Receiving a NOTIFY from [192.168.10.10:57357]
TRACE 2013-11-26 08:38:18.803 [UPNPHelper] Receiving a NOTIFY from [192.168.27.14:43997]
DEBUG 2013-11-26 08:38:18.810 [Thread-141] ==========================================================================
DEBUG 2013-11-26 08:38:18.810 [Thread-141] Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
DEBUG 2013-11-26 08:38:18.811 [Thread-141] Selected video codec: [ffh264] vfm: ffmpeg (FFmpeg H.264)
DEBUG 2013-11-26 08:38:18.811 [Thread-141] ==========================================================================
DEBUG 2013-11-26 08:38:18.812 [Thread-141] audiocodec: framecopy (format=2000 chans=6 rate=48000 bits=0 B/s=80000 sample-0)
DEBUG 2013-11-26 08:38:18.812 [Thread-140] Limiting audio preload to 0.4s.
DEBUG 2013-11-26 08:38:18.812 [Thread-140] Increasing audio density to 4.
TRACE 2013-11-26 08:38:18.822 [UPNPHelper] Receiving a NOTIFY from [192.168.10.10:57358]
TRACE 2013-11-26 08:38:18.823 [UPNPHelper] Receiving a NOTIFY from [192.168.27.14:43997]
DEBUG 2013-11-26 08:38:18.825 [Thread-141] Movie-Aspect is undefined - no prescaling applied.
DEBUG 2013-11-26 08:38:18.828 [Thread-141] videocodec: libavcodec (1920x800 fourcc=3267706d [mpg2])
DEBUG 2013-11-26 08:38:18.828 [Thread-141] [VE_LAVC] Using constant qscale = 1.000000 (VBR).
TRACE 2013-11-26 08:38:18.842 [UPNPHelper] Receiving a NOTIFY from [192.168.10.10:57359]
TRACE 2013-11-26 08:38:18.843 [UPNPHelper] Receiving a NOTIFY from [192.168.27.14:43997]
DEBUG 2013-11-26 08:38:18.849 [Thread-141] Writing header...
DEBUG 2013-11-26 08:38:18.849 [Thread-141] INITV: 0.200, 0.158, fps: 23.976
INFO  2013-11-26 08:38:18.861 [StartPlaying Event] Started playing Very Bad Trip 3.m2ts on your PlayStation 3
DEBUG 2013-11-26 08:38:18.862 [StartPlaying Event] The full filename of which is: G:\The.Hangover.Part.III.2013.MULTi.TRUEFRENCH.1080p.BluRay.x264-LOST .mkv and the address of the renderer is: 192.168.10.30
TRACE 2013-11-26 08:38:18.863 [UPNPHelper] Receiving a NOTIFY from [192.168.10.10:57360]
TRACE 2013-11-26 08:38:18.864 [UPNPHelper] Receiving a NOTIFY from [192.168.27.14:43997]
TRACE 2013-11-26 08:38:18.885 [UPNPHelper] Receiving a NOTIFY from [192.168.10.10:57361]
TRACE 2013-11-26 08:38:18.886 [UPNPHelper] Receiving a NOTIFY from [192.168.27.14:43997]
TRACE 2013-11-26 08:38:18.908 [UPNPHelper] Receiving a NOTIFY from [192.168.10.10:57362]
TRACE 2013-11-26 08:38:18.910 [UPNPHelper] Receiving a NOTIFY from [192.168.27.14:43997]
TRACE 2013-11-26 08:38:18.930 [UPNPHelper] Receiving a NOTIFY from [192.168.10.10:57363]
TRACE 2013-11-26 08:38:18.932 [UPNPHelper] Receiving a NOTIFY from [192.168.27.14:43997]
TRACE 2013-11-26 08:38:18.945 [New I/O worker #1] Matched support line f:mpegps     v:mpeg1|mpeg2|mp4|h264   a:ac3|lpcm           m:video/mpeg
TRACE 2013-11-26 08:38:18.946 [New I/O worker #1] Ready to Stop: true
TRACE 2013-11-26 08:38:18.946 [New I/O worker #1] Sent to socket: Accept-Ranges: bytes
TRACE 2013-11-26 08:38:18.946 [New I/O worker #1] Sent to socket: Connection: keep-alive
TRACE 2013-11-26 08:38:18.946 [New I/O worker #1] Sent to socket: Content-Type: video/mpeg
TRACE 2013-11-26 08:38:18.946 [New I/O worker #1] Sent to socket: Server: Windows_7-amd64-6.1, UPnP/1.0, UMS/3.1.3
TRACE 2013-11-26 08:38:18.950 [New I/O server boss #17] Creating new pipeline
TRACE 2013-11-26 08:38:18.951 [New I/O worker #2] Opened request handler on socket /192.168.10.30:50131
TRACE 2013-11-26 08:38:18.951 [New I/O worker #2] Request: HTTP/1.0 : GET : get/0$9$1$23$4/Very+Bad+Trip+3.m2ts
TRACE 2013-11-26 08:38:18.951 [UPNPHelper] Receiving a NOTIFY from [192.168.10.10:57364]
TRACE 2013-11-26 08:38:18.951 [New I/O worker #2] Matched media renderer "PlayStation 3" based on address /192.168.10.30
TRACE 2013-11-26 08:38:18.951 [New I/O worker #2] Received on socket: Accept-Encoding: identity
TRACE 2013-11-26 08:38:18.951 [New I/O worker #2] Received on socket: Cache-Control: no-cache
TRACE 2013-11-26 08:38:18.951 [New I/O worker #2] Received on socket: Connection: close
TRACE 2013-11-26 08:38:18.951 [New I/O worker #2] Received on socket: Host: 192.168.10.10:5001
TRACE 2013-11-26 08:38:18.951 [New I/O worker #2] Received on socket: User-Agent: PLAYSTATION 3
TRACE 2013-11-26 08:38:18.951 [New I/O worker #2] Recognized media renderer: PlayStation 3
TRACE 2013-11-26 08:38:18.951 [New I/O worker #2] HTTP: get/0$9$1$23$4/Very+Bad+Trip+3.m2ts / 0-0
TRACE 2013-11-26 08:38:18.951 [New I/O worker #2] discover 0 refresh forced: false
TRACE 2013-11-26 08:38:18.951 [New I/O worker #2] discover 0$9 refresh forced: false
TRACE 2013-11-26 08:38:18.951 [New I/O worker #2] discover 0$9$1 refresh forced: false
TRACE 2013-11-26 08:38:18.951 [New I/O worker #2] discover 0$9$1$23 refresh forced: false
TRACE 2013-11-26 08:38:18.951 [New I/O worker #2] Asked stream chunk : TimeRange [start=null, end=null] of Very Bad Trip 3.m2ts and player MEncoder
TRACE 2013-11-26 08:38:18.952 [New I/O worker #2] Ready to Stop: false
TRACE 2013-11-26 08:38:18.952 [UPNPHelper] Receiving a NOTIFY from [192.168.27.14:43997]
TRACE 2013-11-26 08:38:18.972 [UPNPHelper] Receiving a NOTIFY from [192.168.10.10:57365]
TRACE 2013-11-26 08:38:18.974 [UPNPHelper] Receiving a NOTIFY from [192.168.27.14:43997]
TRACE 2013-11-26 08:38:18.993 [UPNPHelper] Receiving a NOTIFY from [192.168.10.10:57366]
TRACE 2013-11-26 08:38:18.994 [UPNPHelper] Receiving a NOTIFY from [192.168.27.14:43997]
TRACE 2013-11-26 08:38:19.015 [UPNPHelper] Receiving a NOTIFY from [192.168.10.10:57367]
TRACE 2013-11-26 08:38:19.016 [UPNPHelper] Receiving a NOTIFY from [192.168.27.14:43997]
TRACE 2013-11-26 08:38:19.036 [UPNPHelper] Receiving a NOTIFY from [192.168.10.10:57368]
TRACE 2013-11-26 08:38:19.037 [UPNPHelper] Receiving a NOTIFY from [192.168.27.14:43997]
TRACE 2013-11-26 08:38:19.057 [UPNPHelper] Receiving a NOTIFY from [192.168.10.10:57369]
TRACE 2013-11-26 08:38:19.059 [UPNPHelper] Receiving a NOTIFY from [192.168.27.14:43997]
TRACE 2013-11-26 08:38:19.075 [New I/O worker #2] Matched support line f:mpegps     v:mpeg1|mpeg2|mp4|h264   a:ac3|lpcm           m:video/mpeg
TRACE 2013-11-26 08:38:19.076 [New I/O worker #2] Suspend Read: readCount=0 / writeCount=155648
TRACE 2013-11-26 08:38:19.079 [UPNPHelper] Receiving a NOTIFY from [192.168.10.10:57370]
TRACE 2013-11-26 08:38:19.080 [UPNPHelper] Receiving a NOTIFY from [192.168.27.14:43997]
TRACE 2013-11-26 08:38:19.082 [New I/O server boss #17] Creating new pipeline
TRACE 2013-11-26 08:38:19.082 [New I/O worker #3] Opened request handler on socket /192.168.10.30:50130
TRACE 2013-11-26 08:38:19.082 [New I/O worker #3] Request: HTTP/1.1 : GET : get/0$9$1$23$4/Very+Bad+Trip+3.m2ts
TRACE 2013-11-26 08:38:19.082 [New I/O worker #3] Matched media renderer "PlayStation 3" based on address /192.168.10.30
TRACE 2013-11-26 08:38:19.082 [New I/O worker #3] Received on socket: Accept-Encoding: identity
TRACE 2013-11-26 08:38:19.082 [New I/O worker #3] Received on socket: Connection: Keep-Alive
TRACE 2013-11-26 08:38:19.082 [New I/O worker #3] Received on socket: Host: 192.168.10.10:5001
TRACE 2013-11-26 08:38:19.082 [New I/O worker #3] Received on socket: TimeSeekRange.dlna.org: npt=0.000-
TRACE 2013-11-26 08:38:19.082 [New I/O worker #3] Received on socket: transferMode.dlna.org: Streaming
TRACE 2013-11-26 08:38:19.082 [New I/O worker #3] Received on socket: User-Agent: PLAYSTATION 3
TRACE 2013-11-26 08:38:19.082 [New I/O worker #3] Received on socket: X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment"; mn="PLAYSTATION 3"; mv="1.0";
TRACE 2013-11-26 08:38:19.083 [New I/O worker #3] Recognized media renderer: PlayStation 3
TRACE 2013-11-26 08:38:19.083 [New I/O worker #3] HTTP: get/0$9$1$23$4/Very+Bad+Trip+3.m2ts / 0-0
TRACE 2013-11-26 08:38:19.083 [New I/O worker #3] discover 0 refresh forced: false
TRACE 2013-11-26 08:38:19.083 [New I/O worker #3] discover 0$9 refresh forced: false
TRACE 2013-11-26 08:38:19.083 [New I/O worker #3] discover 0$9$1 refresh forced: false
TRACE 2013-11-26 08:38:19.083 [New I/O worker #3] discover 0$9$1$23 refresh forced: false
TRACE 2013-11-26 08:38:19.083 [New I/O worker #3] Asked stream chunk : TimeRange [start=0.0, end=null] of Very Bad Trip 3.m2ts and player MEncoder
TRACE 2013-11-26 08:38:19.100 [UPNPHelper] Receiving a NOTIFY from [192.168.10.10:57371]
TRACE 2013-11-26 08:38:19.102 [UPNPHelper] Receiving a NOTIFY from [192.168.27.14:43997]
TRACE 2013-11-26 08:38:19.121 [UPNPHelper] Receiving a NOTIFY from [192.168.10.10:57372]
TRACE 2013-11-26 08:38:19.123 [UPNPHelper] Receiving a NOTIFY from [192.168.27.14:43997]
TRACE 2013-11-26 08:38:19.143 [UPNPHelper] Receiving a NOTIFY from [192.168.10.10:57373]
TRACE 2013-11-26 08:38:19.144 [UPNPHelper] Receiving a NOTIFY from [192.168.27.14:43997]
TRACE 2013-11-26 08:38:19.154 [New I/O worker #3] Matched support line f:mpegps     v:mpeg1|mpeg2|mp4|h264   a:ac3|lpcm           m:video/mpeg
TRACE 2013-11-26 08:38:19.155 [New I/O worker #3] Suspend Read: readCount=0 / writeCount=155648
TRACE 2013-11-26 08:38:19.164 [UPNPHelper] Receiving a NOTIFY from [192.168.10.10:57374]
TRACE 2013-11-26 08:38:19.165 [UPNPHelper] Receiving a NOTIFY from [192.168.27.14:43997]
TRACE 2013-11-26 08:38:19.185 [UPNPHelper] Receiving a NOTIFY from [192.168.10.10:57375]
TRACE 2013-11-26 08:38:19.186 [UPNPHelper] Receiving a NOTIFY from [192.168.27.14:43997]
TRACE 2013-11-26 08:38:19.207 [UPNPHelper] Receiving a NOTIFY from [192.168.10.10:57376]
TRACE 2013-11-26 08:38:19.208 [UPNPHelper] Receiving a NOTIFY from [192.168.27.14:43997]
TRACE 2013-11-26 08:38:19.228 [UPNPHelper] Receiving a NOTIFY from [192.168.10.10:57377]
TRACE 2013-11-26 08:38:19.228 [UPNPHelper] Receiving a NOTIFY from [192.168.27.14:43997]
TRACE 2013-11-26 08:38:19.249 [UPNPHelper] Receiving a NOTIFY from [192.168.10.10:57378]
TRACE 2013-11-26 08:38:19.250 [UPNPHelper] Receiving a NOTIFY from [192.168.27.14:43997]
TRACE 2013-11-26 08:38:19.270 [UPNPHelper] Receiving a NOTIFY from [192.168.10.10:57379]
TRACE 2013-11-26 08:38:19.271 [UPNPHelper] Receiving a NOTIFY from [192.168.27.14:43997]
TRACE 2013-11-26 08:38:19.291 [UPNPHelper] Receiving a NOTIFY from [192.168.10.10:57380]
TRACE 2013-11-26 08:38:19.293 [UPNPHelper] Receiving a NOTIFY from [192.168.27.14:43997]
TRACE 2013-11-26 08:38:19.312 [UPNPHelper] Receiving a NOTIFY from [192.168.10.10:57381]
TRACE 2013-11-26 08:38:19.313 [UPNPHelper] Receiving a NOTIFY from [192.168.27.14:43997]
TRACE 2013-11-26 08:38:19.333 [UPNPHelper] Receiving a NOTIFY from [192.168.10.10:57382]
TRACE 2013-11-26 08:38:19.335 [UPNPHelper] Receiving a NOTIFY from [192.168.27.14:43997]
TRACE 2013-11-26 08:38:19.355 [UPNPHelper] Receiving a NOTIFY from [192.168.10.10:57383]
TRACE 2013-11-26 08:38:19.356 [UPNPHelper] Receiving a NOTIFY from [192.168.27.14:43997]
TRACE 2013-11-26 08:38:19.376 [UPNPHelper] Receiving a NOTIFY from [192.168.10.10:57384]
TRACE 2013-11-26 08:38:19.378 [UPNPHelper] Receiving a NOTIFY from [192.168.27.14:43997]
TRACE 2013-11-26 08:38:19.576 [New I/O worker #2] Resume Read: readCount=0 / writeCount=1523712
TRACE 2013-11-26 08:38:19.576 [New I/O worker #2] Sent to socket: Accept-Ranges: bytes
TRACE 2013-11-26 08:38:19.576 [New I/O worker #2] Sent to socket: Connection: keep-alive
TRACE 2013-11-26 08:38:19.576 [New I/O worker #2] Sent to socket: Content-Type: video/mpeg
TRACE 2013-11-26 08:38:19.576 [New I/O worker #2] Sent to socket: Server: Windows_7-amd64-6.1, UPnP/1.0, UMS/3.1.3
TRACE 2013-11-26 08:38:19.577 [New I/O worker #2] Ready to Stop: true
TRACE 2013-11-26 08:38:19.655 [New I/O worker #3] Ready to Stop: false
TRACE 2013-11-26 08:38:19.655 [New I/O worker #3] Resume Read: readCount=0 / writeCount=1523712
TRACE 2013-11-26 08:38:19.655 [New I/O worker #3] Sent to socket: Accept-Ranges: bytes
TRACE 2013-11-26 08:38:19.655 [New I/O worker #3] Sent to socket: Connection: keep-alive
TRACE 2013-11-26 08:38:19.655 [New I/O worker #3] Sent to socket: Content-Type: video/mpeg
TRACE 2013-11-26 08:38:19.655 [New I/O worker #3] Sent to socket: Server: Windows_7-amd64-6.1, UPnP/1.0, UMS/3.1.3
TRACE 2013-11-26 08:38:19.655 [New I/O worker #3] Sent to socket: TimeSeekRange.dlna.org: npt=00:00:00.00-01:40:09,00/01:40:09,00
TRACE 2013-11-26 08:38:19.655 [New I/O worker #3] Sent to socket: TransferMode.DLNA.ORG: Streaming
TRACE 2013-11-26 08:38:19.655 [New I/O worker #3] Sent to socket: X-Seek-Range: npt=00:00:00.00-01:40:09,00/01:40:09,00
TRACE 2013-11-26 08:38:19.676 [New I/O worker #3] Suspend Read: readCount=524288 / writeCount=1523712
TRACE 2013-11-26 08:38:20.176 [New I/O worker #3] Resume Read: readCount=524288 / writeCount=4292608
TRACE 2013-11-26 08:38:20.761 [Timer-30] buffered: 6 993 919 bytes / inputs: 1
TRACE 2013-11-26 08:38:22.024 [New I/O worker #3] Ready to Stop: true
TRACE 2013-11-26 08:38:22.025 [New I/O server boss #17] Creating new pipeline
TRACE 2013-11-26 08:38:22.025 [New I/O worker #4] Opened request handler on socket /192.168.10.30:50126
TRACE 2013-11-26 08:38:22.025 [New I/O worker #4] Request: HTTP/1.1 : GET : get/0$9$1$23$4/Very+Bad+Trip+3.m2ts
TRACE 2013-11-26 08:38:22.025 [New I/O worker #4] Matched media renderer "PlayStation 3" based on address /192.168.10.30
TRACE 2013-11-26 08:38:22.025 [New I/O worker #4] Received on socket: Accept-Encoding: identity
TRACE 2013-11-26 08:38:22.025 [New I/O worker #4] Received on socket: Connection: Keep-Alive
TRACE 2013-11-26 08:38:22.025 [New I/O worker #4] Received on socket: Host: 192.168.10.10:5001
TRACE 2013-11-26 08:38:22.025 [New I/O worker #4] Received on socket: TimeSeekRange.dlna.org: npt=0.000-
TRACE 2013-11-26 08:38:22.025 [New I/O worker #4] Received on socket: transferMode.dlna.org: Streaming
TRACE 2013-11-26 08:38:22.025 [New I/O worker #4] Received on socket: User-Agent: PLAYSTATION 3
TRACE 2013-11-26 08:38:22.025 [New I/O worker #4] Received on socket: X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment"; mn="PLAYSTATION 3"; mv="1.0";
TRACE 2013-11-26 08:38:22.025 [New I/O worker #4] Recognized media renderer: PlayStation 3
TRACE 2013-11-26 08:38:22.025 [New I/O worker #4] HTTP: get/0$9$1$23$4/Very+Bad+Trip+3.m2ts / 0-0
TRACE 2013-11-26 08:38:22.025 [New I/O worker #4] discover 0 refresh forced: false
TRACE 2013-11-26 08:38:22.025 [New I/O worker #4] discover 0$9 refresh forced: false
TRACE 2013-11-26 08:38:22.025 [New I/O worker #4] discover 0$9$1 refresh forced: false
TRACE 2013-11-26 08:38:22.025 [New I/O worker #4] discover 0$9$1$23 refresh forced: false
TRACE 2013-11-26 08:38:22.025 [New I/O worker #4] Asked stream chunk : TimeRange [start=0.0, end=null] of Very Bad Trip 3.m2ts and player MEncoder
TRACE 2013-11-26 08:38:22.026 [New I/O worker #4] Ready to Stop: false
TRACE 2013-11-26 08:38:22.108 [New I/O worker #4] Matched support line f:mpegps     v:mpeg1|mpeg2|mp4|h264   a:ac3|lpcm           m:video/mpeg
TRACE 2013-11-26 08:38:22.109 [New I/O worker #4] Sent to socket: Accept-Ranges: bytes
TRACE 2013-11-26 08:38:22.109 [New I/O worker #4] Sent to socket: Connection: keep-alive
TRACE 2013-11-26 08:38:22.109 [New I/O worker #4] Sent to socket: Content-Type: video/mpeg
TRACE 2013-11-26 08:38:22.109 [New I/O worker #4] Sent to socket: Server: Windows_7-amd64-6.1, UPnP/1.0, UMS/3.1.3
TRACE 2013-11-26 08:38:22.109 [New I/O worker #4] Sent to socket: TimeSeekRange.dlna.org: npt=00:00:00.00-01:40:09,00/01:40:09,00
TRACE 2013-11-26 08:38:22.109 [New I/O worker #4] Sent to socket: TransferMode.DLNA.ORG: Streaming
TRACE 2013-11-26 08:38:22.109 [New I/O worker #4] Sent to socket: X-Seek-Range: npt=00:00:00.00-01:40:09,00/01:40:09,00
TRACE 2013-11-26 08:38:22.876 [Timer-30] buffered: 11 243 519 bytes / inputs: 1
DEBUG 2013-11-26 08:38:24.159 [UPNP-AliveMessageSender] Sending ALIVE...
TRACE 2013-11-26 08:38:24.207 [UPNP-AliveMessageSender] Sending message from multicast socket on network interface: name:null
TRACE 2013-11-26 08:38:24.208 [UPNP-AliveMessageSender] Multicast socket is on interface: /0.0.0.0
TRACE 2013-11-26 08:38:24.208 [UPNP-AliveMessageSender] Socket Timeout: 0
TRACE 2013-11-26 08:38:24.208 [UPNP-AliveMessageSender] Socket TTL: 32
TRACE 2013-11-26 08:38:24.208 [UPNPHelper] Receiving a NOTIFY from [192.168.10.10:57387]
TRACE 2013-11-26 08:38:24.209 [UPNPHelper] Receiving a NOTIFY from [192.168.27.14:43997]
TRACE 2013-11-26 08:38:24.211 [UPNPHelper] Receiving a NOTIFY from [192.168.27.14:43997]
TRACE 2013-11-26 08:38:24.212 [UPNPHelper] Receiving a NOTIFY from [192.168.27.14:43997]
TRACE 2013-11-26 08:38:24.213 [New I/O server boss #17] Creating new pipeline
TRACE 2013-11-26 08:38:24.876 [Timer-30] buffered: 18 989 055 bytes / inputs: 1
TRACE 2013-11-26 08:38:25.411 [New I/O server boss #17] Creating new pipeline
TRACE 2013-11-26 08:38:25.412 [New I/O worker #6] Opened request handler on socket /192.168.10.30:50125
TRACE 2013-11-26 08:38:25.412 [New I/O worker #6] Request: HTTP/1.1 : GET : description/fetch
TRACE 2013-11-26 08:38:25.412 [New I/O worker #6] Matched media renderer "PlayStation 3" based on address /192.168.10.30
TRACE 2013-11-26 08:38:25.412 [New I/O worker #6] Received on socket: Date: Tue, 26 Nov 2013 07:38:29 GMT
TRACE 2013-11-26 08:38:25.412 [New I/O worker #6] Received on socket: Host: 192.168.10.10:5001
TRACE 2013-11-26 08:38:25.412 [New I/O worker #6] Received on socket: User-Agent: UPnP/1.0
TRACE 2013-11-26 08:38:25.412 [New I/O worker #6] Received on socket: X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment Inc."; mn="PLAYSTATION 3"; mv="1.0";
TRACE 2013-11-26 08:38:25.412 [New I/O worker #6] Recognized media renderer: PlayStation 3
TRACE 2013-11-26 08:38:25.412 [New I/O worker #6] HTTP: description/fetch / 0-0
TRACE 2013-11-26 08:38:25.413 [New I/O worker #6] Sent to socket: Accept-Ranges: bytes
TRACE 2013-11-26 08:38:25.413 [New I/O worker #6] Sent to socket: Cache-Control: no-cache
TRACE 2013-11-26 08:38:25.413 [New I/O worker #6] Sent to socket: Connection: keep-alive
TRACE 2013-11-26 08:38:25.413 [New I/O worker #6] Sent to socket: Content-Length: 2957
TRACE 2013-11-26 08:38:25.413 [New I/O worker #6] Sent to socket: Content-Type: text/xml; charset="utf-8"
TRACE 2013-11-26 08:38:25.413 [New I/O worker #6] Sent to socket: Expires: 0
TRACE 2013-11-26 08:38:25.413 [New I/O worker #6] Sent to socket: Server: Windows_7-amd64-6.1, UPnP/1.0, UMS/3.1.3
TRACE 2013-11-26 08:38:26.878 [Timer-30] buffered: 26 613 759 bytes / inputs: 1
TRACE 2013-11-26 08:38:28.010 [Thread-137] Successfully grown buffer from 52 428 800 bytes to 209 715 200 bytes.
TRACE 2013-11-26 08:38:28.878 [Timer-30] buffered: 36 169 727 bytes / inputs: 1
TRACE 2013-11-26 08:38:29.055 [UPNPHelper] Receiving a M-SEARCH from [192.168.10.10:52100]
TRACE 2013-11-26 08:38:29.096 [UPNPHelper] Receiving a M-SEARCH from [192.168.10.10:52100]
TRACE 2013-11-26 08:38:29.096 [UPNPHelper] Sending this reply [192.168.10.10:52100]: HTTP/1.1 200 OK<CRLF>CACHE-CONTROL: max-age=1200<CRLF>DATE: Tue, 26 Nov 2013 07:38:29 GMT<CRLF>LOCATION: http://192.168.10.10:5001/description/fetch<CRLF>SERVER: Windows_7-amd64-6.1, UPnP/1.0, UMS/3.1.3<CRLF>ST: urn:schemas-upnp-org:device:MediaServer:1<CRLF>EXT: <CRLF>USN: uuid:cf939cd0-d1e8-47a1-8ed9-223ec5ba8dae::urn:schemas-upnp-org:device:MediaServer:1<CRLF>Content-Length: 0<CRLF><CRLF>
TRACE 2013-11-26 08:38:29.137 [UPNPHelper] Receiving a M-SEARCH from [192.168.10.10:52100]
TRACE 2013-11-26 08:38:29.181 [UPNPHelper] Receiving a M-SEARCH from [192.168.10.10:52100]
TRACE 2013-11-26 08:38:29.222 [UPNPHelper] Receiving a M-SEARCH from [192.168.10.10:52100]
TRACE 2013-11-26 08:38:29.222 [UPNPHelper] Sending this reply [192.168.10.10:52100]: HTTP/1.1 200 OK<CRLF>CACHE-CONTROL: max-age=1200<CRLF>DATE: Tue, 26 Nov 2013 07:38:29 GMT<CRLF>LOCATION: http://192.168.10.10:5001/description/fetch<CRLF>SERVER: Windows_7-amd64-6.1, UPnP/1.0, UMS/3.1.3<CRLF>ST: urn:schemas-upnp-org:device:MediaServer:1<CRLF>EXT: <CRLF>USN: uuid:cf939cd0-d1e8-47a1-8ed9-223ec5ba8dae::urn:schemas-upnp-org:device:MediaServer:1<CRLF>Content-Length: 0<CRLF><CRLF>
TRACE 2013-11-26 08:38:29.264 [UPNPHelper] Receiving a M-SEARCH from [192.168.10.10:52100]
TRACE 2013-11-26 08:38:30.878 [Timer-30] buffered: 36 732 927 bytes / inputs: 1
TRACE 2013-11-26 08:38:31.515 [New I/O worker #4] Ready to Stop: true
TRACE 2013-11-26 08:38:32.148 [New I/O server boss #17] Creating new pipeline
TRACE 2013-11-26 08:38:32.149 [New I/O worker #7] Opened request handler on socket /192.168.10.30:50124
TRACE 2013-11-26 08:38:32.149 [New I/O worker #7] Request: HTTP/1.1 : GET : get/0$9$1$23$4/thumbnail0000Very+Bad+Trip+3.m2ts
TRACE 2013-11-26 08:38:32.149 [New I/O worker #7] Matched media renderer "PlayStation 3" based on address /192.168.10.30
TRACE 2013-11-26 08:38:32.149 [New I/O worker #7] Received on socket: Accept-Encoding: identity
TRACE 2013-11-26 08:38:32.149 [New I/O worker #7] Received on socket: Connection: Keep-Alive
TRACE 2013-11-26 08:38:32.149 [New I/O worker #7] Received on socket: Host: 192.168.10.10:5001
TRACE 2013-11-26 08:38:32.149 [New I/O worker #7] Received on socket: transferMode.dlna.org: Interactive
TRACE 2013-11-26 08:38:32.149 [New I/O worker #7] Received on socket: User-Agent: PLAYSTATION 3
TRACE 2013-11-26 08:38:32.149 [New I/O worker #7] Received on socket: X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment"; mn="PLAYSTATION 3"; mv="1.0";
TRACE 2013-11-26 08:38:32.149 [New I/O worker #7] Recognized media renderer: PlayStation 3
TRACE 2013-11-26 08:38:32.149 [New I/O worker #7] HTTP: get/0$9$1$23$4/thumbnail0000Very+Bad+Trip+3.m2ts / 0-0
TRACE 2013-11-26 08:38:32.149 [New I/O worker #7] discover 0 refresh forced: false
TRACE 2013-11-26 08:38:32.150 [New I/O worker #7] discover 0$9 refresh forced: false
TRACE 2013-11-26 08:38:32.150 [New I/O worker #7] discover 0$9$1 refresh forced: false
TRACE 2013-11-26 08:38:32.150 [New I/O worker #7] discover 0$9$1$23 refresh forced: false
INFO  2013-11-26 08:38:32.150 [New I/O worker #7] <XBMCLog> - Thumb : The.Hangover.Part.III.2013.MULTi.TRUEFRENCH.1080p.BluRay.x264-LOST -poster.jpg
TRACE 2013-11-26 08:38:32.170 [New I/O worker #7] Available Content-Length: 15227
TRACE 2013-11-26 08:38:32.171 [New I/O worker #7] Sent to socket: Accept-Ranges: bytes
TRACE 2013-11-26 08:38:32.171 [New I/O worker #7] Sent to socket: Connection: keep-alive
TRACE 2013-11-26 08:38:32.171 [New I/O worker #7] Sent to socket: Content-Length: 15227
TRACE 2013-11-26 08:38:32.171 [New I/O worker #7] Sent to socket: Content-Type: image/jpeg
TRACE 2013-11-26 08:38:32.171 [New I/O worker #7] Sent to socket: Expires: Sat, 22 Mar 2014 01:25:12 GMT
TRACE 2013-11-26 08:38:32.171 [New I/O worker #7] Sent to socket: Server: Windows_7-amd64-6.1, UPnP/1.0, UMS/3.1.3
TRACE 2013-11-26 08:38:32.171 [New I/O worker #7] Sent to socket: TransferMode.DLNA.ORG: Interactive
TRACE 2013-11-26 08:38:32.885 [Timer-30] buffered: 69 597 184 bytes / inputs: 0
DEBUG 2013-11-26 08:38:34.016 [Buffered IO End Checker] Stopping process: mencoder.exe-30
TRACE 2013-11-26 08:38:34.016 [Buffered IO End Checker] Destroying buffer
TRACE 2013-11-26 08:38:34.018 [Thread-137] EOF
TRACE 2013-11-26 08:38:34.030 [mencoder.exe-30] EOF
INFO  2013-11-26 08:38:35.517 [StopPlaying Event] Stopped playing Very Bad Trip 3.m2ts on your PlayStation 3
DEBUG 2013-11-26 08:38:35.518 [StopPlaying Event] The full filename of which is: G:\The.Hangover.Part.III.2013.MULTi.TRUEFRENCH.1080p.BluRay.x264-LOST .mkv and the address of the renderer is: 192.168.10.30
DEBUG 2013-11-26 08:38:35.518 [StopPlaying Event] add MapFile [name=Very Bad Trip 3.m2ts, id=null, format=MKV, children=[]] to last played  [id=23, name=V, full path=0$9$1$23, ext=null, discovered=true] RecentlyPlayed [id=1, name=Recently Played, full path=0$1, ext=null, discovered=false]
INFO  2013-11-26 08:38:35.518 [StopPlaying Event] Exception in thread "StopPlaying Event" java.lang.NullPointerException
INFO  2013-11-26 08:38:35.518 [StopPlaying Event] 	at net.pms.dlna.RecentlyPlayed.add(RecentlyPlayed.java:107)
INFO  2013-11-26 08:38:35.519 [StopPlaying Event] 	at net.pms.dlna.RootFolder.stopPlaying(RootFolder.java:1324)
INFO  2013-11-26 08:38:35.519 [StopPlaying Event] 	at net.pms.dlna.DLNAResource.internalStop(DLNAResource.java:3183)
INFO  2013-11-26 08:38:35.519 [StopPlaying Event] 	at net.pms.dlna.DLNAResource.access$400(DLNAResource.java:68)
INFO  2013-11-26 08:38:35.519 [StopPlaying Event] 	at net.pms.dlna.DLNAResource$2$1.run(DLNAResource.java:2194)
INFO  2013-11-26 08:38:35.520 [StopPlaying Event] 	at java.lang.Thread.run(Unknown Source)
The line ExSport talked about is in the same format.
EDIT : it's fixed in 3.1.2.1 ! Thanks a lot !
Thanks for confirming the fix :)
Samonosuke
Post by Samonosuke »
The "vfolders" configuration does not seem to be working.
It worked pretty fine in 2.x versions but since 3.x it does not work anymore. I already looked at the code and can't find any change in the definition of a "vfolders.conf" - except of tumbnails.
Here is my virtual folder definition in json format - can somebody tell me what is wrong?
	"name":"HD-Movies",
	"thumbnailIcon":"",
	"files":["G:\\HD-Movies_2","I:\\HD_Movies","K:\\HD_Movies","L:\\Filme","M:\\"]
	"name":"Movies",
	"thumbnailIcon":"",
	"files":["I:\\MOVIES","K:\\Movies","G:\\Movies_2"]
