All files on PS3 say "The data type is not supported."
KiyoshiSenpai
Post by KiyoshiSenpai »
Streaming from UMS to PS3, every single file I attempt holds the black loading screen for a few long seconds, then says "The data type is not supported."
It used to work just fine in the past, not sure what happened. I tried it on a specific file I had working in the past for the bug log attached.
Thanks for any assistance.
(470.69 KiB) Downloaded 492 times
