I have problem with 4k streaming.
I want to stream from PC to 49RU8002 Sonic.the.Hedgehog.2020.2160p but i got attached bug, i can't see error in log file, attachet tc config file too.
Thx for help.
Thx for help.
Samsung-UHD-2019.conf
- (9.22 KiB) Downloaded 302 times
- debug.zip
- (10.88 KiB) Downloaded 291 times
Re: I have problem with 4k streaming.
We need full trace logs to help, follow link in red section above.
But from what I can see is the file is not streaming but being transcoded.
Transcoding 4k is resource intensive so needs a high end pc and a fast network, if ether of these cannot keep up the renderer will get errors and close the connection, which is what appears to be happening
That file may play without transcoding, try the #-TRANSCODE-# folder and select no transcoding. If it works the config will need to be tweaked but need the logs to see the decision making process.
