[Solved] Wich render config file?
kimsamsara
Post by kimsamsara »
I need the config file for Belgium Telenet Decoder and for the Yamaha R-N303D ?
Anyone got a solution?
Thanks !
Re: Wich render config file?
Hi kimsamsara, if I make you configs for those devices, can you test and give feedback on them?
kimsamsara
Offcourse
Great, please place the attached file into the renderers folder and try it
Yamaha-RN303.conf
(951 Bytes) Downloaded 379 times
kimsamsara
Works fine !
Thanks, that will be in the next version of UMS :)
