2 Audio files language 'eng' but the default track flag is ignored
ChroMe55555
Post by ChroMe55555 »
I have a MKV file with 2 audio files embedded:
1) Type = DTS // Language = ENG // Default Track Flag = YES ===> Real audio of the movie
2) Type = AC3 // Language = ENG // Default Track Flag = NO ==> Commentary of the director(s)
Now UMS keeps taking audio stream 2 (directors commentary) as the default, so it ignores the 'Default Track' flag which can be seen in MKVMerge GUI.
Any idea how to fix this in the settings of UMS / UMS.conf file?
valib
Re: 2 Audio files language 'eng' but the default track flag is ignored
Post by valib »
Please follow instructions written in read above an send the log.
ChroMe55555
UMS freezes when trying to 'Zip selected files'... => After a very long time the zip was there...
UPDATE: Zip in attachment
ums_dbg_2020-11-14-11-59.zip
(154.51 KiB) Downloaded 500 times
The PS4 mediaplayer does not support DTS audio so it is picking the next available supported track which happens to be the commentary in AC3.
UMS is detecting that DTS is not supported, but as there is a second supported track it allows the file to be streamed and leaves the PS4 to select what it can play.
This is one of the rare instances where the format matching does not give the required result so you will have to force transcoding using the TRANSCODE folder to select the audio track you want.
valib
Post by valib »
Thnks mik_s this is exactly what I would write.
ChroMe55555
So there isn't any setting to force DTS transcoding by default?
Yes there is, but that's not the issue here. The issue here is that there are two "qualifying" (language wise) audio tracks, one of which don't need transcoding. UMS has no way of knowing that it's not actually the audio for the video. If it was, so that the content of the two were the same, you'd want UMS' current behavior instead of enforcing transcoding just because one of the tracks aren't supported.
It's one of those situations where both options will benefit some situations, and you simply have to pick the one you think will be most beneficial. Thus, making the choice manually in the "transcode" folder is the correct thing here.
ChroMe55555
Thanks for the replies already!!
And isn't there a way to keep in mind the 'Default Track' flag? Because that flag is set to YES for the real audio and to NO for the commentary. (I checked that in the tool "MKV Merge")
I don't quite see how that would make any difference. Often videos come with a "main"/"default" track in DTS or AC3, and then a "secondary" track in AAC or MP3. If the renderer can't play the "main" track, it's better to play the existing one in a supported codec than to transcode the surround track to e.g AAC or MP3.
This isn't about what's possible, but what's desirable most often. The automatic behavior can only do one thing, so one has to choose. Unless you have a large number of videos with this particular situation, I don't see why using the "transcode" folder for such rare cases should be a problem.
ChroMe55555
I have several files with this situation, so for me, my problems would be solved if UMS would automatically pick the audio stream with the 'Default Track' flag.
