3.3.0 VirtualFolders broken
When using virtual folders, by virtual_folders
when correct format is NAME|/path/sub1,/path/sub2;NAME2|/path2/sub1;
I get error with parsing "/path/sub2;NAME2|"
When using virtual folders from VirtualFolders.conf
I end up with root '/" added to virtual folders, but when changing to (like Sub said) replace / with \\ i get:
Because linux use "/" and not "\" like windows
So main problem is that "/" root is added and UMS scan it from top to bottom. Other Virtual Folders from conf are correct
WARN 2013-12-11 18:56:16.012 [New I/O worker #4] Can't read directory: /home/sapsa/ums-3.3.0/\mnt\sdb1\movies
server: C2D [email protected] 3GB RAM
network: wired 1000MB/s
OS: Linux 13.10 64bit
