Version 10.4.0 released
General:
This release allows renderers like Samsung TVs to disable our resume feature if they have their own one, as well as improves transcoding speed, memory use, and more!
Download:
Downloads for Windows, macOS and Linux, and commands for Docker and Homebrew are available on our download page or from our official mirrors.
Changes since 10.3.0:
  • General:
    • Added renderer config setting DisableUmsResume for renderers with their own resume support, like Samsung TVs
    • Improved speed of transcoding to H.264 by up to 3x
    • Fixed MEncoder crashing when trying to downmix 7.1 AAC to 5.1 AC-3
    • Fixed renderer SupportedVideoBitDepths setting
    • Improved memory use and speed when resume is disabled
    • Fixed renderer resolution and bitrate limiting
    • Fixed broken transcoding for some users since the previous release
  • Renderers:
    • Improved support for VC1 codec on Sony Blu-ray UBP-X800M2 (thanks, thechrisgregory!)
    • Improved support for many filetypes on Kodi (thanks, thechrisgregory!)
    • Improved support for 12-bit video on VLC
    • Estonian (24%) (thanks, Tanel K!)
    • Japanese (97%) (thanks, Katsuhide.M!)
    • Russian (91%) (thanks, Dmitry Lavrentev!)
  • Dependencies:
    • Bump git-commit-id-plugin from 4.0.3 to 4.0.4
    • Rolled back FFmpeg
Operating system support:
  • Windows 7+, and limited support for Windows XP and Vista
  • macOS 10.10+
  • Docker
chickyboom
Re: Version 10.4.0 released
Post by chickyboom »
On the Navigation Settings tab, I already have "Enable video resuming" turned off.
Does this new "DisableUmsResume" setting do something more? Does it go in a custom config file?
KONTROLMASTER
Contact:
Post by KONTROLMASTER »
Unfortunately, have the same result like previous version for DVDRemux for ex., "800288E1" error. Happens with transcoding or without. Can't play .mkv, .mpg & else.
Maybe it's connected not only with FFMpeg, but with some settings for the last new versions?
Last edited by KONTROLMASTER on Wed Mar 24, 2021 11:46 pm, edited 3 times in total.
pipin
Post by pipin »
Thanks for the release.
Working fine so far for me.
Did some updates on the german language via crowdin.
Regards,
Jens
KONTROLMASTER
Contact:
Tested it just a few times ago with clean install option and deleted the remaining files manually, the result is the same.
chickyboom wrote: Sun Mar 21, 2021 11:32 pm On the Navigation Settings tab, I already have "Enable video resuming" turned off.
The user setting you have used is still respected, so you don't have to change anything. This is a renderer-level setting, that allows renderer configs to disable our resume feature if it is enabled.
KONTROLMASTER wrote: Wed Mar 24, 2021 4:34 am Unfortunately, have the same result like previous version for DVDRemux for ex., "800288E1" error. Happens with transcoding or without. Can't play .mkv, .mpg & else.
Can you please provide logs for this? We might have already fixed it in the upcoming version but logs will let me be sure about that
pipin wrote: Wed Mar 24, 2021 7:54 pm Thanks for the release.
Thanks!
KONTROLMASTER
Contact:
KONTROLMASTER wrote: Thu Mar 25, 2021 11:16 am Yeah, sure! https://mega.nz/file/5I5UmRaa#PDJwwpeF7 ... PNWqAp7DPo
I can only see an attempt to play on Edge in those logs. I thought the problem was on PS3?
KONTROLMASTER
Contact:
Sorry, updated my post. The first link is for the "Web Interface", just looked it, the second for Ps3!
KONTROLMASTER wrote: Fri Mar 26, 2021 4:10 am Sorry, updated my post. The first link is for the "Web Interface", just looked it, the second for Ps3!
Cool, yes that is fixed in the version I'm starting to release now
