Installer doesn't open!
doug123
Post by doug123 »
Hi, I'm trying to install the UMS but when I double click the installer nothing happens.
I'm using Windows 10 with the last updates.
I tried previous version but it's the same.
I can only install the old Ps3 media server.
What can I do to install this application?
Thanks....
Re: Installer doesn't open!
Hi doug123, sorry you're having that problem. Where are you downloading the file from? Do you have any firewalls/antivirus installed?
