How can I tell UMS to start streaming <insert MKV name here>
Hi, so I forced an IP and a port to UMS, I connect to it through my web browser on the TV, UMS detects it as a Renderer, and then? What should I do to make UMS stream to my TV ?
Re: How can I tell UMS to start streaming <insert MKV name h
If in UMS you added your media folder where the mkv resides...then on your TV in the input menu select UMS and it should be there and play it.
what kind of TV do you have?
did UMS detect it as a render device on the main page of ums?
did it come up as unknown?
if so then follow the steps in my sig to capture log files to see if we can see any errors
Sent from my SM-N900T Using ForumTouch for Android
