Couldn't parse any supported protocols
I get this error on startup. Using version 11.6.0. First time user, old version because of network share bug. Any idea what the problem could be?
DEBUG 2023-02-23 16:48:26.928 [main] Checking transcoding engine AviSynth/FFmpeg
WARN 2023-02-23 16:48:26.999 [main] Couldn't parse any supported protocols for "C:\Program Files (x86)\Universal Media Server\win32\ffmpeg64.exe"
INFO 2023-02-23 16:48:27.000 [main] Transcoding engine "AviSynth/FFmpeg" is available
Re: Couldn't parse any supported protocols
I'm not sure what that means either but I get that warning too on 13.2.0 when UMS starts up.
It must be just UMS checking to see what the transcoding engines are available and some might report they support a specific protocol but FFmpeg does not report anything.
It should not cause any problems though
Well I'm an idiot, I forgot the code is available on GitHub.
FFMpegVideo.java#L1832
Get rid of the bang before "protocols.isEmpty()" I'll leave it as an exercise to the reader to update the unit test
And you're correct, it currently means there is no problem.
List<String> protocols = FFmpegOptions.getSupportedProtocols(executableInfo.getPath());
fFmpegExecutableInfoBuilder.protocols(protocols);
if (!protocols.isEmpty()) {
LOGGER.warn("Couldn't parse any supported protocols for \"{}\"", executableInfo.getPath());
} else {
LOGGER.debug("{} supported protocols: {}", executableInfo.getPath(), protocols);
You should open an issue on GitHub to report this if it is an easy fix. I'm not a coder but I think I follow the logic in that part and it seems to be inverted.
