Wrong network interface on Linux
j0rge1523
Post by j0rge1523 »
I just installed ums on Linux and I can't load the web interface on other devices. I think that it is using the wrong network interface. I want to change that, but I can't find settings. There is no "settings" item in the hamburger icon menu
Screenshot from 2023-10-13 12-16-15.png (5.59 KiB) Viewed 2352 times
Here is my log file
umslog.txt
(92.4 KiB) Downloaded 212 times
Re: Wrong network interface on Linux
The web interface is on http://localhost:9001/ and the standalone player on http://localhost:9002/
Looking at your log the web GUI is not able to start
Failed to start web graphical user interface server (/0.0.0.0:9001) : Address already in use
which is causing this error
INFO  2023-10-13 12:04:04.037 [Web GUI browser] Launching the graphical interface on a browser
INFO  2023-10-13 12:04:04.037 [Web GUI browser] Exception in thread "Web GUI browser" java.lang.NullPointerException: Cannot invoke "String.length()" because "this.input" is null
INFO  2023-10-13 12:04:04.037 [Web GUI browser] 	at java.base/java.net.URI$Parser.parse(Unknown Source)
INFO  2023-10-13 12:04:04.037 [Web GUI browser] 	at java.base/java.net.URI.<init>(Unknown Source)
INFO  2023-10-13 12:04:04.037 [Web GUI browser] 	at net.pms.platform.PlatformUtils.browseURI(PlatformUtils.java:147)
INFO  2023-10-13 12:04:04.037 [Web GUI browser] 	at net.pms.PMS$2.run(PMS.java:644)
but the web player is working.
Web player is available at: http://172.17.0.1:9002
I don't know enough about Linux or networking to give any specific help but it must be something to do with how you have the network configured, as both web player and web GUI should be on the same IP just different ports.
UMS may also be using the wrong network interface when starting but I could not see much as your logs weren't in trace mode.
As you cannot launch the GUI to change logging modes you can add
log_level =TRACE
to UMS.conf and restart it.
j0rge1523
Post by j0rge1523 »
Yes, I'm already using port 9001 for something else. Is there a way to change the web GUI port?
boss
Post by boss »
You can edit the UMS.conf file to change that.
/Username/.config/UMS/UMS.conf
Change:
# Web gui port
# The port that the web gui can be accessed by.
# Example: 7000, which means the web gui is at localhost:7000
# Default: 9001
web_gui_port =
to a port of your choice.
EG: web_gui_port = 8001
