Two Playstation 3s, UMS not able to access on both
I'm running into an issue with using UMS and my two Playstation 3s. Once the UMS starts, I am successfully able to access via my main PS3, or my second PS3, depending which I try to access first. After I'm finished, I go upstairs to my bedroom and decide to watch something via my second PS3. When I try to access the UMS, it does not even display as being available. I then have to go back downstairs, manually restart UMS, then go back upstairs and I am now able to see it on the screen for access. My two PS3s have different IP Addresses, different hostnames, etc. I'm running a Gbit Network run to PS3 #1 (too bad the PS3 is only 100Mb), and the PS3 #2 upstairs is running over a Powerline 100Mb hardwire network run.
I never had this problem when using the PMS prior to giving UMS a try a couple of days ago. I was able to stream to many devices at once, and in the least, see the PMS available for access on all of my devices. Is there some sort of setting in UMS that will allow me to access UMS without having to manually restart every time, or maybe even allow access at the same time?
I am using v3.4.0 of UMS.
Re: Two Playstation 3s, UMS not able to access on both
Has anyone else experienced this problem, or have any corrective action to take?
Working well for me. Check UMS logs to see if it doesnt complain of any blocked port or so.
same here, actually streaming to 2 PS3's ( which in fact, is not 100MB only..as far as I know...),
also, often streaming to either a LG or Sony TV. So, 3 clients at the same time = no issue unless off course
if everyone tries transcoding something at the same time....
So, a clean install or a thorough look through the debug file.
UMS itself shouldn't have a problem with the 2 PS3's.
