UMS does not open on my Freebox
mapomme1108
Post by mapomme1108 »
I am french and my internet provider is Free.
I've had a Freebox Revolution Light.
I would like to share my videos located on my laptop with Windows 10
I installed Univeral Media Server on the pc.
The server is detected by the Freebox
but if I open the server, the Freebox does not stop running and does not display the shared media.
I would like to know what to do so that they appear and I can read them.
Thanks if you can help me.
Re: UMS does not open on my Freebox
I don't know anything about this Freebox, just that it was a combined router and media player, but as long as it uses DNLA/UPnP it should work as if it can detect UMS.
Most times when a device can see UMS but not play anything it is usually a network configuration or firewall problem.
I'm not sure what you mean with this though.
mapomme1108 wrote: Sun Jul 21, 2024 9:16 pm Freebox does not stop running
To be of any help I will need to see your logs. See the red section above.
