MovieInfo causing hung process until runs out of memory
danielt
Post by danielt »
I have version 3.4.1 (also saw same behavior in 3.3).
When MovieInfo is accessed the first time, no issues.
When Movieinfo is accessed a second time, javaw.exe will fully saturate one core for several minutes, the committed memory will steadily grow, and then after 4-5minutes, it dies and goes back to normal.
Looking at the log, there is a error 'max memory exceeeded' when it dies. The GUI is still up and server response goes back to normal.
If I look up multiple movies in a short time period, it will eventually choke UMS and it quits responding.
The logs are attached for 2 MovieInfo accesses until the 2nd one finally clears.
Hope this helps!
log files
(69.17 KiB) Downloaded 583 times
danielt
Re: MovieInfo causing hung process until runs out of memory
Post by danielt »
FYI, still seeing this with 3.4.2
