Trouble with UMS 14.9.0-x88_64
Today My UMS ceased to funktion. I do not have any Ide why. Hence, I do need assistance, please. The log file is included.
MO1
MO1
- ums_dbg_2025-01-22-20-30.zip
- (69.91 KiB) Downloaded 627 times
Re: Trouble with UMS 14.9.0-x88_64
I saw this error but don't see what caused it.
It may have something to do with the forced IP address you have set as this happens just before the error.
Try setting this back to default so it can be automatically assigned, just deleting that option should work but if you cannot get in the web UI you should be able to do it in the old GUI by right clicking the tray icon.
I see you had previous issues with this but you never followed up if started working after trying the things I mentioned. Was it working before? anything changed or updated recently?
ERROR 2025-01-22 20:30:11.342 [main] net.pms.PMS A serious error occurred during Universal Media Server initialization: Cannot invoke "java.net.NetworkInterface.isUp()" because "tmpNetworkInterface" is null
DEBUG 2025-01-22 20:30:11.339 [main] net.pms.network.configuration.NetworkConfiguration Using forced address: 192.168.0.15
Hi
Thanks for the advice. It did not help. After uninstalling the UMS 14.9.0-x88_64 and cleaning the remnats I installed the UMS 14.6.0. It does not stream to my TV. However, the web version does function as it should.
I attach the debug log. Please help.
MO1
MO1
- ums_dbg_2025-01-23-11-30.zip
- (76.16 KiB) Downloaded 607 times
Yes, after your advice last summer everything run smoothly till Tuesday.
MO1.
MO1.
Hi
My UMS 14.6.0 started suddenly function. Thanks for the advice. However, it will take a while for me to install the UMS 14.9.0-x88_64.
MO1
MO1
