Ps4 streaming Not working after upgrading to Mac OS Sequoia
milkartist
Post by milkartist »
I recently upgraded my MacBook to Mac OS Sequoia and afterwards I noticed that I could no longer stream movies that I have downloaded to my MacBook to the PS4 . I have the latest version of universal media server and I'm looking for some answers if any thank you
Re: Ps4 streaming Not working after upgrading to Mac OS Sequoia
Could you post your logs? See the section in red above.
milkartist
Basically, what's happening is when I go on my PS4 and I try to navigate through the files. It will not let me go past the file I have chosen and does not recognize any playable media.
Without logs I don't know what is happening.
milkartist
** Log text removed **
Reason: Log text removed
What you posted was just the initialisation and was in the wrong mode so had no useful information.
At a glance there seems to be some exception errors but as it was not in trace mode there is no context and is not in a format I can analyse in my log viewer.
I will remove the logs you posted.
Please follow the instructions in the red section above and attach the zip file created.
