How can i log in into web interface?
Emanuel85
Post by Emanuel85 »
maybe a stupid question but i can't login to webinterface. I need a username and a password. I have registered on the UMS website but the login data doenst work with the app. Please help. Thank you :)
Re: How can i log in into web interface?
When you first run UMS it will ask you to create a user or disable authentication. This has nothing to do with the UMS website as it is local to your computer.
If you forgot the login details you set you can delete "C:\ProgramData\UMS\database\USERS.mv.db" to reset it and it will ask you to crate a new user next time you access the web interface.
