Keep losing wireless connection
dwooderson
Post by dwooderson »
I am using UMS on a Mac Mini (2,53 GHz Intel Core 2 Duo, 8 GB 1067 MHz DDR3, OS X 10.9.2) and a Samsung Blu-ray-Player with a wireless connection (static IP).
Everything works fine but the wireless connection gets lost after 10 to 50 minutes (see end of log). Or the video stops playing but I think the disconnecting of the wireless causes this. Any ideas how to prevent this? Thanks.
(9.43 KiB) Downloaded 471 times
DeFlanko
Contact:
Re: Keep losing wireless connection
Post by DeFlanko »
Hardwire it and see if the issue continues...
if the issue goes away its your wireless thats causing the issue.
Remember its always [HOST] --> [AP] --> [Renderer], not [HOST] --> [Renderer]
Try to reduce the amount of wifi interference (change Wifi Channels from the standard channels [1, 6, 11] to something thats not so flooded) if you have an android device -- using Wifi Analyzer for Android to determine which channel in your environment is more "open"
