FFMpeg Expertise needed
Hi.
I might stretch some rule on double posting in multiple threads but in this case I need Windows experience on FFMpeg to solve my Linux FFMPeg problem.
So my problem is that I cannot find a pre-compiled FFMPeg binary for Ubuntu which works for both mkv embedded subtitles and for HLS/HTTP web streaming. I can find binaries that works for either but not both.
So now I have decided to try to build one myself which is complicated enough but before even doing that i would like help to know what libraries and build options that are included/set in a Window build of ffmpeg (since that build obviously works for the 99.9% of UMS users that are using Windows). Is it a standard build or is it a dll bundled with UMS?
So, is there anyone that can help out?
Pen
The Ubuntu problem is handled in the following thread - but note that I'm not asking for Ubuntu expertise here (trying to justify my double post):
viewtopic.php?f=10&t=1671
Pen
Re: FFMpeg Expertise needed
No claim to "expertise" here
and I don't know whether it solves your specific MKV woes, but I follow the ffmpeg wiki using this configure line (extra libs highlighted):
![Smile :)](./images/smilies/icon_e_smile.gif)
you may need to install these in addition to the packages listed on the wiki:../configure --enable-gpl --enable-libass --enable-libfaac --enable-libfdk-aac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libspeex --enable-librtmp --enable-libtheora --enable-libvorbis --enable-x11grab --enable-libx264 --enable-nonfree --enable-version3 --enable-libfreetype --enable-fontconfig --enable-libv4l2 --enable-openssl
sudo apt-get install rtmpdump libfreetype6-dev libfontconfig1-dev
Thanks alot Infidel. It works after some work!
This is what I succeded with:
It's a mix of the Ubuntu build proposal and your proposal. It includes all the blue ones except libv4l2. The following were not able to compile (missing libs):
libfaac
libopencore-amrnb
libopencore-amrwb
libspeex
libv4l2
Q1: What would I miss by not including them - in particular libv4l2 which you indicated as blue?
Note that it is a headless server so I'm not going to watch movies on it.
My guess is that amr is only for old mobile phones (not Android?)
Q2: What about the libs that I have included but was not in your list - can they negatively interfere?
I plan to write a howto in the Linux section once I get everything to work.
Pen
./configure --extra-libs="-ldl" --enable-static \
--disable-shared --enable-gpl --enable-libass --enable-libfdk-aac --enable-libmp3lame \
--enable-librtmp --enable-libopus \
--enable-libtheora --enable-libvorbis --enable-libvpx --enable-libx264 --enable-nonfree --enable-version3 \
--enable-libfreetype --enable-fontconfig --enable-openssl
libfaac
libopencore-amrnb
libopencore-amrwb
libspeex
libv4l2
Pen
- Optimus_prime
pen, i do commend you on helping out the UMS community and sharing your results. We may have to attempt to get it into a release ![Smile :)](./images/smilies/icon_e_smile.gif)
Glad it worked
You're probably fine without them. I added libv4l2 at one point because of a device capture / screencast script I was working on. My particular list is "historic", most of it from earlier incarnations of the ffmpeg wiki page (it used to be a thread in the ubuntuforums), so I would go with the UMS ffmpeg options plus the current ffmpeg wiki proposal plus the blues.pen wrote:Q1: What would I miss by not including them - in particular libv4l2 which you indicated as blue?
Imo there's no really good reason to do a static build in linux, which just makes things more brittle and complicated. Even a static build of ffmpeg isn't usually truly static (use 'ldd path/to/your/ffmpeg' to see any shared deps). Some libs (e.g. openssl) won't link statically. I wouldn't include --enable-static in a wiki.pen wrote:--enable-static
Highly doubtfulpen wrote:Q2: What about the libs that I have included but was not in your list - can they negatively interfere?
