UMSBuilderV2: build any UMS branch
infidel
Post by infidel »
Setup:
  • Windows:
  • Linux:
    • Install the git and curl packages for your distro, e.g. on ubuntu/debian:
      sudo apt-get install git curl
    • Get UMSBuilder for linux.
    • Put buildv2.sh in your UMSBuilder top folder, run it and follow the menus.
  • To build other branches select one of:
    • Choose another branch
    • Choose a pull request
    • Show all - (shows every branch known to git, including old pull requests)
    • Rebuild - (fast-forward and rebuild already existing branches)
    • Specify a commit or tag - (enter a commit or tag when prompted, e.g. 1338a57 or 4.1.3-WindowsLinux-Java8)
    UMSBuilderV2.8.zip
    (4.52 KiB) Downloaded 1493 times
    Changelog:
    • V2.8 - support new git-for-windows paths
    • V2.7 - support new ums build changes + linux fixes
    • V2.6 - fix problem chars in pr titles on Windows + ensure entire 'Show all' list is visible.
    • V2.5a - build specific commits/tags + add 'compile' option to platform menu
    • V2.4 - fix pull requests, add rebuild + linux + quick-compile support.
    • V2.3 - compatible with all versions of UMSBuilder
    • V2.2 - show github view of branches and pull requests + fast-forward existing branches (h/t Wolf)
    • V2.1 - compatible with UMSBuilder 1.7 or 1.6
DeFlanko
Contact:
Re: UMSBuilderV2: build any UMS branch
Post by DeFlanko »
Awesome!
Wolfgan
Post by Wolfgan »
I second that feeling, impressive work. Thanks a lot!
infidel
Post by infidel »
Update: V2.2 - show github view of branches and pull requests in menu.
Wolfgan
Post by Wolfgan »
infidel wrote:Update: V2.2 - show github view of branches and pull requests in menu.
Thank you for the update. While trying to update the latest 4.0.0 branch, I receive a message:
Switched to branch '4.0.0'
Your branch is behind 'origin/4.0.0' by 101 commits, and can be fast-forwarded.
  (use "git pull" to update your local branch)
Is there any way to integrate the required "git pull" into the batch as an option? (ie if local repository is behind origin, ask the user if s/he wants to update the repository before building)
Wolf
infidel
Post by infidel »
Wolfgan wrote:Is there any way to integrate the required "git pull" into the batch as an option?
I added
git pull --ff-only
after the branch checkout, please re-download and let me know if it works :).
Wolfgan
Post by Wolfgan »
I added
git pull --ff-only
Yep, it works perfectly now. Thanks for the quick update! Wolf
infidel
Post by infidel »
Update: V2.3 - compatible with all versions of UMSBuilder.
Wolfgan
Post by Wolfgan »
infidel wrote:Update: V2.3 - compatible with all versions of UMSBuilder.
Thanks for the update. I understand you're referring to this viewtopic.php?f=3&t=2131 announcement?
infidel
Post by infidel »
Yes, Maven was updated so its directory name is different. As of this version the batch file discovers the Maven+JDK dirs via wildcards so it shouldn't be a problem going forward.
