UMS To WAN
xLuckless
UMS To WAN
Post by xLuckless »
I want to make this possible is there any way? (see image)
SharkHunter
Re: UMS To WAN
Post by SharkHunter »
We are working in WEB based interface which could solve this. That said I have had a "DLNA everywhere" kind of technology in SHB before. Maybe that can be readded to UMS.
xLuckless
Re: UMS To WAN
Post by xLuckless »
That would even be better! Thank you for your answer!
sliu01
Re: UMS To WAN
Post by sliu01 »
Is that the reason why UMS doesn't work when I access it from outside the LAN? I am using the UPnP Player on Android phone. Tried port mapping (on router) and SSH port forwarding (ConnectBot). With both ways, I have no problem navigating through the video folders, or even expanding the DVD images (into tracks). It just doesn't play any video. When I switch to LAN access, it has no problem. The bandwidth is enough (Cable Modem, Starbucks wifi etc).
Wish to get some help or answer. Appreciate!
SharkHunter
Re: UMS To WAN
sliu01 wrote:Is that the reason why UMS doesn't work when I access it from outside the LAN? I am using the UPnP Player on Android phone. Tried port mapping (on router) and SSH port forwarding (ConnectBot). With both ways, I have no problem navigating through the video folders, or even expanding the DVD images (into tracks). It just doesn't play any video. When I switch to LAN access, it has no problem. The bandwidth is enough (Cable Modem, Starbucks wifi etc).
WIthout going into to much techno I would say that if browse works then stream should work. Or maybe I need to add the old DLNA anywhere.
To start with pls upload some logs when you do this (viewtopic.php?f=9&t=556)
sliu01
Re: UMS To WAN
Post by sliu01 »
Thanks for your response. Attached is the log generated while the issue was replicated.
In the test, I first connected to the server in LAN, played a little bit for each of the two videos. Then I exited the UPnPlay
from phone, connected to Starbucks wifi. I was doing "tail -f" on the log file. It prints when I navigate through the folders, but it did
not response to my video playing request, which eventually timed out with error "this video cannot be played". I tried a couple of times, going back and forth with folders.
Finally, I connected back to my wifi (LAN), playing back was working again!
Hope this helps and I appreciate your time!
log & conf file
(33.17 KiB) Downloaded 481 times
SharkHunter
Re: UMS To WAN
First if you could redo the thing but
1) Turn off any other render you might have (like a TV)
2) Only do the Starbucks access test.
and put up new logs.
I think that you might be a victim of the UMS reindexing too. After the above test try out the 4.1.0 branch where the support remote controls should be better...
sliu01
Re: UMS To WAN
Post by sliu01 »
As per your request, redone log file uploaded.
Downloaded 4.10 source code. How do I compile it? Is there a builder script?
Thanks!
(11.31 KiB) Downloaded 470 times
