web interface - access control?
perler
Post by perler »
for the very nice web interface (is it new in 4.0?) - is there some form of access control planned? I would like to have something like subsonic has for it's mp3 server..
SharkHunter
Re: web interface - access control?
Post by SharkHunter »
It has a built in access control already. First you must enable it. This is done by setting
web_authenticate=true
in your UMS.conf (no GUI option here).
Then you must add users. Simplest way to do that is to use the GUI and go in to the "Plugin" tab.
At the bottom you'll have a credential section were you either via the GUI can add lines or you can open the raw file.
To the file (or add one entry at the time using the GUI) add lines of format:
web.<tag>=usr,pwd
where the
.<tag>
is optional.
The tag can be whatever but view it as a group. All users with the same tag will be treated the same. If no tag is supplied the user is considered to belong to the group of himself.
Groups can then be used to differentiate rootfolders etc.
Once your done with all this you probably need to restart UMS and the off you go.
ExSport
Post by ExSport »
Nice to have all these hidden options defined in UMS.conf, like many renderer options are already defined in PS3.conf 8-)
SharkHunter
ExSport wrote:Nice to have all these hidden options defined in UMS.conf, like many renderer options are already defined in PS3.conf 8-)
Well GUI and documenting isn't my strong/best side. I documented here right? :)
The web would benefit from a complete tab in the GUI (with it's options) but thats on the todo list. I wanted the function out the door. And then add more functions that needs more config which isn't documented either :)
ExSport
Post by ExSport »
Totally understand 8-)
Only wanted to say we have so many cool hidden settings but no one know about them and it is impossible to find all of them here in the forum and maintaining them on one place :mrgreen:
Keep up great work.
ExSport
SharkHunter
One way to find out about new cool config options is to look in this file https://github.com/UniversalMediaServer ... ation.java
All constants at the start of the file shows you which keywords can be put into the UMS.conf
(....KEY_ALTERNATE_SUBTITLES_FOLDER = "alternate_subtitles_folder") the keyword is whats between the "
what the value should be can sometimes be deduced from the name (web_enable,max_bitrate) or by searching for that uppercase crap in that file.
All are used in a function returning one out of String,int,boolean.
The new undocumented stuff added by me are mostly just boolean or int options.
You don't need to be a java wizard (or even a programmer) to make a good guess of what to put there. For boolean options it's simply on(=true) or off(=false).
ExSport
Post by ExSport »
Yes I know where to look at 8-) I already did the same for hidden renderer config options and pulled the change officially.
Problem is another. You need to read many code around what exactly the hidden settings does and in most cases it is quite hard work to imagine what which settings probably should do :mrgreen:
It is time consuming and requires some programming skills 8-) Not problem for me but can be impossible for others. When I will have more time I wil try sum them up, but the time, free time.... :cry:
inovatech
Post by inovatech »
Hello!
i don´t understand the (complicate) procedure:
what means in (Plugins) the Owner & Tag ?
i only want to authenticate the webserver with an user and password - not more - not less.
e.g. i want to login: alex and PW: test
what is to enter to work it right ?
confusing: if i set in in the config file the "web_authenticate =true" than he promts me on the browser for a user and a password - but i have it never set :?
Thank you for your help!
