Anyway to set the framerate/Hz?
CappySpectrum
Post by CappySpectrum »
Streaming films from the hard drive ends up 1080p/50Hz according to the Blu-Ray player. Is there a way to set it to the same as a Blu-Ray disc? 1080p/24Hz.
CappySpectrum
Re: Anyway to set the framerate/Hz?
No entry at all for the *.conf? Been looking through them all and can't find anything or the PS3.conf.
As playback says 1080p / 50Hz on the Panasonic player. Yet the files are saying, video codec: h264, frame rate: 23.976 yet I'm seeing a faint hint of judder on very slow motion parts like the camera panning over a desk with paper.
Optimus_prime
Post by Optimus_prime »
There is a section within Transcode Settings, MEncoder, Expert Settings that talks about framerate settings. I've never played around with it before but give it a try and see if that helps :)
CappySpectrum
When people stream/encoded from their storage/computer to player, does the mode normally switch to 24Hz mode? Or is that a disc detection?
DEBUG 2014-08-18 19:45:12.765 [ffmpeg-1-2] Input #0, lavfi, from 'nullsrc=s=720x480:d=1:r=1':
DEBUG 2014-08-18 19:45:12.765 [ffmpeg-1-2] Duration: N/A, start: 0.000000, bitrate: N/A
DEBUG 2014-08-18 19:45:12.765 [ffmpeg-1-2] Stream #0:0: Video: rawvideo (I420 / 0x30323449), yuv420p, 720x480 [SAR 1:1 DAR 3:2], 1 tbr, 1 tbn, 1 tbc
DEBUG 2014-08-18 19:45:12.765 [ffmpeg-1-2] [Parsed_ass_0 @ 0x103101de0] Added subtitle file: 'DummyInput.ass' (6 styles, 1 events)
DEBUG 2014-08-18 19:45:12.765 [ffmpeg-1-2] Output #0, dvd, to 'pipe:':
DEBUG 2014-08-18 19:45:12.765 [ffmpeg-1-2] Metadata:
DEBUG 2014-08-18 19:45:12.765 [ffmpeg-1-2] encoder : Lavf55.48.100
DEBUG 2014-08-18 19:45:12.765 [ffmpeg-1-2] Stream #0:0: Video: mpeg2video, yuv420p, 720x480 [SAR 1:1 DAR 3:2], q=2-31, 6000 kb/s, 29.97 fps, 90k tbn, 29.97 tbc
DEBUG 2014-08-18 19:45:12.766 [ffmpeg-1-2] encoder : Lavc55.69.100 mpeg2video
DEBUG 2014-08-18 19:45:12.766 [ffmpeg-1-2] Stream mapping:
DEBUG 2014-08-18 19:45:12.766 [ffmpeg-1-2] Stream #0:0 -> #0:0 (rawvideo (native) -> mpeg2video (native))
DEBUG 2014-08-18 19:45:12.766 [ffmpeg-1-2] Press [q] to stop, [?] for help
DEBUG 2014-08-18 19:45:12.766 [ffmpeg-1-2] frame= 1 fps=0.0 q=1.6 Lsize= 8kB time=00:00:00.03 bitrate=1964.1kbits/s
DEBUG 2014-08-18 19:45:12.766 [ffmpeg-1-2] video:5kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 51.227615%
DEBUG 2014-08-18 19:45:39.914 [ffmpeg-5-2] Metadata:
DEBUG 2014-08-18 19:45:39.914 [ffmpeg-5-2] encoder : libebml v1.3.0 + libmatroska v1.4.0
DEBUG 2014-08-18 19:45:39.914 [ffmpeg-5-2] creation_time : 1970-01-01 00:00:02
DEBUG 2014-08-18 19:45:39.914 [ffmpeg-5-2] Duration: 03:02:31.36, start: 0.000000, bitrate: 12157 kb/s
DEBUG 2014-08-18 19:45:39.914 [ffmpeg-5-2] Stream #0:0(eng): Video: h264 (High), yuv420p, 1920x800, SAR 1:1 DAR 12:5, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
DEBUG 2014-08-18 19:45:39.914 [ffmpeg-5-2] title : The.Hobbit.An.Unexpected.Journey.2012.Extended.Edition
DEBUG 2014-08-18 19:45:39.915 [ffmpeg-5-2] Stream #0:1(eng): Audio: dts (DTS), 48000 Hz, 5.1(side), fltp, 1536 kb/s (default)
DEBUG 2014-08-18 19:45:39.915 [ffmpeg-5-2] Metadata:
DEBUG 2014-08-18 19:45:39.915 [ffmpeg-5-2] title : dts-core 1536k eng
DEBUG 2014-08-18 19:45:39.915 [ffmpeg-5-2] Output #0, h264, to 'pipe:':
DEBUG 2014-08-18 19:45:39.915 [ffmpeg-5-2] encoder : Lavf55.48.100
DEBUG 2014-08-18 19:45:39.915 [ffmpeg-5-2] Stream #0:0(eng): Video: h264, yuv420p, 1920x800 [SAR 1:1 DAR 12:5], q=2-31, 23.98 fps, 23.98 tbn, 23.98 tbc (default)
DEBUG 2014-08-18 19:45:39.915 [ffmpeg-5-2] title : The.Hobbit.An.Unexpected.Journey.2012.Extended.Edition
DEBUG 2014-08-18 19:45:40.679 [tsMuxeR-8] Attaching thread: tsMuxeR-8
DEBUG 2014-08-18 19:45:40.683 [Thread-54] SmartLabs tsMuxeR. Version 1.10.6 http://www.smlabs.net
DEBUG 2014-08-18 19:45:40.683 [tsMuxeR-8] Unix process ID (/Applications/Universal Media Server.app/Contents/Resources/Java/osx/tsMuxeR): 42036
DEBUG 2014-08-18 19:45:40.683 [Thread-54] Decoding H264 stream (track 1): Profile: [email protected] Resolution: 1920:800p Frame rate: 23.976
DEBUG 2014-08-18 19:45:40.683 [Thread-54] Change H264 level from 4.1 to 4.1
DEBUG 2014-08-18 19:45:40.683 [Thread-54] H.264 stream does not contain fps field. Muxing fps=23.976
DEBUG 2014-08-18 19:45:40.684 [Thread-54] 100.0% complete
DEBUG 2014-08-18 19:45:40.684 [Thread-54] H264 bitstream changed: insert nal unit delimiters
DEBUG 2014-08-18 19:45:40.684 [Thread-54] H264 bitstream changed: insert pict timing and buffering period SEI units
DEBUG 2014-08-18 19:45:40.684 [Thread-54] Decoding AC3 stream (track 2): Bitrate: 640Kbps Sample Rate: 48KHz Channels: 6
DEBUG 2014-08-18 19:45:40.684 [Thread-54] B-pyramid level 1 detected. Shift DTS to 2 frames
DEBUG 2014-08-18 19:45:41.056 [Thread-54] 100.0% complete
I'm a little puzzled with this for my own config. It appears I've sorted my judder problem. Needed 4 cores set instead of 2.
Is there any way to rectify the user agent? Only just started dabbling with the configuration files and see why the Panasonic DMP-BDT330 tied into the VizioSmartTV.conf.
UserAgentSearch = IPI/1.0 UPnP/1.0 DLNADOC/1.50
CappySpectrum
What does this mean?
[swscaler @ 0x103800600] Warning: data is not aligned! This can lead to a speedloss
