LG TV WebOS LB6500
raprop
LG TV WebOS LB6500
Post by raprop »
Hi!!!!
This TV i not detected, but work with nero media or plex server. How need to work!?
Thx.
Wolfgan
Re: LG TV WebOS LB6500
Post by Wolfgan »
raprop wrote:Hi!!!!
Thx.
I suggest you follow guidance at http://www.universalmediaserver.com/faq ... erSupport1
raprop
Post by raprop »
dont work :(
another method????
Wolfgan
Post by Wolfgan »
raprop wrote:dont work :(
another method????
"Don't work" won't let us help you much... is the renderer detected in the logs at least?
raprop
Post by raprop »
hi1
tv dont detect UMS and UMS dont detect TV
i try with developers ttols for uPNP but i dont known how...
u.u
Wolfgan
Post by Wolfgan »
raprop wrote:hi1
u.u
Most likely a network config issue thou...
raprop
Post by raprop »
nero home work fine, plex work fine, another TV work fine...
raprop
Post by raprop »
HI!!!!
now is detect but LG6200 but dont show subs, support subs ASS and SUBRIP, but conf added to render dont work.
is detect useragent like
HTTP User-Agent: Linux/3.10.19-32.angeles.1 UPnP/1.0 LGE WebOS TV LGE_DLNA_SDK/1.6.0/04.00.13 DLNADOC/1.50
some help to fix!?
We are adding improved support for LG WebOS in version 4.2.1 :)
fjrial
Post by fjrial »
raprop wrote:HI!!!!
some help to fix!?
I am using version 4.0.0 with LG webos TV with only a minor problem about subtitles support, but fixed with next steps
Profile detected and using is LG LA6200.. but my tv is LG 42 LB650v
Edited the mentioned profile and added this line
SupportedSubtitlesFormats = SUBRIP,ASS
This allow the SRT subtitles to be shown on the tv
Other minor problems:
-problems resuming videos: if I resume a video, the video does not reach to the end.. finish on some point randomly previous to the end..
-after playing more than 200 videos, some of them, a few dont play.. doesn´t check/review the video/codec etc..
