Cant post?
Cant post?
I'm logged in, but every time I try to start a new topic in the mac os x area, it says I have to be logged in to post and sends me to the login screen again? Whats up with that?
- Optimus_prime
Re: Cant post?
If you have too, post it this forum, pm me and i'll move it to the correct forum. Not sure why its do that as if you can post here you have access to post in the OS-X forum
Re: Cant post?
If I try to upload the file it logs me out..But here's the post with out the zip file, see if this works:
I have a denon receiver (aka streamium) and a sony blue ray play accessing UMS-4.0.3 on MacOS X 10.9.4. Neither can play any music file. The denon receiver navigates the folders and shows the music files, but says "Connection Lost" when I select any file. The sony player navigates to the folders but says no playable files instead of showing any files.
the debug zip has a denonavre400.conf, its just a renamed streamium.conf with a new icon to make things pretty.
Ideas?
its just when I try to upload the debug zip that I can't post, any other way to get you the information? And unfortunately I haven't be registered long enough to pm. I'm going to try to repost this w/out the zip to the mac os board.
Ideas?
