Google Music plugin
SharkHunter
Re: Google Music plugin
Post by SharkHunter »
Pls upload some logs and we'll take it from there. Works for me.
Edit. Could be a Admin rights issue. But that will be shown in the logs.
SharkHunter
New GoogleMusic (0.20) https://github.com/downloads/SharkHunte ... in_020.jar
No real revoultion under the hood. But A-Z folder on "All Songs"
keit
Post by keit »
Hello!
I am a new user and tried this 0.20 Version.
My problem is, that I don´t see any songs at all.
I have empty folders a,b,c,...
Some containing a folder "more", which is empty, too.
I can see my playlist, but it has no songs it.
Any Ideas?
Greetings from Germany
Keit
SharkHunter
keit wrote:Hello!
Any Ideas?
Keit
Can you pls upload the log?
And then just try and restart UMS. I've seen this some times and a restart normally helps. But FIRST upload the log!!
jacoby
Post by jacoby »
I am having similar issues to others that have posted previously:
After some difficulty I got the plugin to recognize and load when UMS starts up.
"GoogleMusic" now appears as one of my selections. If I choose it, I get "all songs" or "playlists." My created playlists do appear as folders when I chose the playlist folder, and the a-z folders appear in 'all music,' some with an additional folder 'more.' But no music appears in anyone. There is only two entries in my log mentioning this plugin:
INFO  2012-12-11 08:06:03.857 [main] Found plugin: net.sharkhunter.gmusic.Gm_plugin
and (yea, I've got a bunch of drives)
INFO  2012-12-11 08:06:24.116 [New I/O server worker #1-2] Node (net.sharkhunter.gmusic.GmRoot) already has an ID (0$10), which is overriden now. The previous parent node was: RootFolder[[MapFile [name=C:\ [Terra], id=0$1, format=null, children=[]], MapFile [name=D:\ [New Volume], id=0$2, format=null, children=[]], MapFile [name=E:\ [New Volume], id=0$3, format=null, children=[]], MapFile [name=F:\ [NV_GFX560TI_SETUP], id=0$4, format=null, children=[]], MapFile [name=H:\ [HP_PAVILION], id=0$5, format=null, children=[]], MapFile [name=J:\ [SKYRIM_EN], id=0$6, format=null, children=[]], MapFile [name=M:\ [NewDrive], id=0$7, format=null, children=[]], MapFile [name=X:\ [New Volume], id=0$8, format=null, children=[]], VirtualFolder [id=9, name=Web, full path=0$9, ext=null, discovered=false]]]
After trying different things for a while I almost got it to work. I removed the latest version (020) and installed the original build (011) this version gave me an error in the log when I tried to view the songs. I felt this was an improvement. So I tried 012 and now it actually listed the tracks! But when I tried to play them, nothing played. So I tried the latest again, and the same result. At this point I tried to shut down UMS, but found that it would not shut down entirely for some reason the javaw process did not stop, so I ended the process. When I restarted UMS, once again the googlemusic folder shows up completely empty.
vedius
Post by vedius »
I am getting nothing out of it at present.
Here is what if find in the log
03-25 09:36:54 Starting Universal Media Server 2.5.2.2
03-25 09:36:54 Based on PS3 Media Server by shagrath, copyright 2008-2013
03-25 09:36:54 http://www.universalmediaserver.com
03-25 09:36:54
03-25 09:36:54 Build: d758100b0 (2013-03-20)
03-25 09:36:54 Java: 1.7.0_17-Oracle Corporation
03-25 09:36:54 OS: Windows 7 64-bit 6.1
03-25 09:36:54 Encoding: UTF-8
03-25 09:36:54 Memory: 742 MB
03-25 09:36:54
03-25 09:36:54 Working directory: C:\Program Files (x86)\Universal Media Server
03-25 09:36:54 Temp directory: C:\Users\<user>\AppData\Local\Temp\universalmediaserver
03-25 09:36:54 Logging config file: C:\Program Files (x86)\Universal Media Server\logback.xml
03-25 09:36:54 debug.log: C:\Program Files (x86)\Universal Media Server\debug.log
<snip>
3-25 09:36:54 Searching for plugins in C:\Program Files (x86)\Universal Media Server\plugins
03-25 09:36:54 Found plugin: net.sharkhunter.gmusic.Gm_plugin
<snip>
03-25 09:36:56 gm exceptiuon java.io.IOException: Server returned HTTP response code: 403 for URL: https://www.google.com/accounts/ClientLogin
03-25 09:36:56 gm exceptiuon java.io.IOException: Server returned HTTP response code: 403 for URL: https://www.google.com/accounts/IssueAuthToken
<snip>
SharkHunter
vedius - Have you added your credentials to UMS.cred? Otherwise logging in will not work.
vedius
Post by vedius »
Here is what is in the UMS.cred file I have verified the user/pass via browser login
CODE:SELECT ALL
gmusic=[email protected],password
SharkHunter
vedius
Post by vedius »
Had to do a clean install to get this to work right.
Clean install then added google creds.
(12.68 KiB) Downloaded 437 times
