[Solved] 4.1.2 won't autostart
damada_21
Post by damada_21 »
I am currently using the java 8 version of UMS 4.1.2 on Windows 8 and it won't autostart with windows. I have tried setting the start with windows options in UMS itself, and also placing it in the startup folder. I used process monitor to monitor the boot and it appears that UMS does try to start but then closes. I've attached the bootlog relating to the UMS launch.
Logfile.CSV
(33.32 KiB) Downloaded 293 times
I have also installed a number of previous versions and the problem still exists.
I should add that the program starts fine when I run it after startup and operates normally. I have not attached the log as the problem occurs outside of UMS operation.
Re: 4.1.2 won't autostart
Maybe try setting the memory to a lower value when you install the program?
damada_21
Post by damada_21 »
Tried that and still didn't seem to work. I then installed UMS to my SSD instead of my HDD and that seemed to solve the problem. Thanks for the help
damada_21 wrote:Tried that and still didn't seem to work. I then installed UMS to my SSD instead of my HDD and that seemed to solve the problem. Thanks for the help
Strange issue, but glad it's not happening anymore!
