FFMPEG on Windows ...
How do I install FFMPEG so that it can be used by UMS?
I have installed it and I can use it from a command line but UMS does not see it ...
Thanks a lot!
Thanks a lot!
- SharkHunter
- Developer
Re: FFMPEG on Windows ...
ffmpeg is normally part of an UMS install. If you want' custom ffmpeg just put the exe file in the win32 dir of your UMS install. This is normally c:\program\UniVersal Media Server\win32
(or similar)
(or similar)
