[Solved] Since 4.1.3 all folder names end with " | JPG"
jj123
Post by jj123 »
This is resolved in version 4.4.0
Since upgrading to UMS 4.1.3 all folder names are being displayed with an additional " | JPG" at the end of the name.
This makes browsing folders look a little ugly, for example in 4.1.2 folders would look like:
Films
--> Science Fiction
--> Action
In 4.1.3 folders now show as:
Films | JPG
--> Science Fiction | JPG
--> Action | JPG
I don't know if this is linked to the new blue folder icon that was introduced in 4.1.3?
Is there anyway in config to turn off either the " | JPG" being appended to the folder names or to disable the new style folder icon?
jj123
Re: Since 4.1.3 all folder names end with " | JPG"
Post by jj123 »
Hi, Please can anyone confirm if they have the same issue?
jj123
Post by jj123 »
Please find attached logs from 4.1.2 (Which works fine, folders show as "Test Folder A")
and logs from 4.1.3 (Which has the issue, folders show as "Test Folder A | JPG")
ums_dbg_folder_issue_4.1.3.zip
Logs from 4.1.3 with folder issue
(25.34 KiB) Downloaded 519 times
ums_dbg_folder_issue_4.1.2.zip
Logs from working 4.1.2
(23.84 KiB) Downloaded 529 times
huulio
Re: [Solved] Since 4.1.3 all folder names end with " | JPG"
Post by huulio »
Hi. I just started using 5 beta and I still get the 'jpg' added. The title says its solved.. do I have to do anything or will I just wait for a new version? Thanks
jj123
Post by jj123 »
No It's still an open issue, please see the issue tracker for the current status:
https://github.com/UniversalMediaServer ... issues/404
huulio
Post by huulio »
Thanks. Good to know its being worked on.
