UMS connects sometimes, but never shows on Xbox 360
I've played around trying to get this to work for a few days now with no luck, here is my log:
INFO 2014-10-20 21:42:16.670 [main] Starting PS3 Media Server 1.90.1
INFO 2014-10-20 21:42:16.671 [main] by shagrath / 2008-2013
INFO 2014-10-20 21:42:16.671 [main] http://ps3mediaserver.org
INFO 2014-10-20 21:42:16.671 [main] https://github.com/ps3mediaserver/ps3mediaserver
INFO 2014-10-20 21:42:16.671 [main] Build: 3a4304c72 (2013-08-17)
INFO 2014-10-20 21:42:16.672 [main] Java: Java HotSpot(TM) 64-Bit Server VM 1.7.0_25 by Oracle Corporation
INFO 2014-10-20 21:42:16.672 [main] OS: Mac OS X x86_64 10.9.4
INFO 2014-10-20 21:42:16.672 [main] Encoding: UTF-8
INFO 2014-10-20 21:42:16.702 [main] Memory: 742 MB
INFO 2014-10-20 21:42:16.702 [main] Working directory: /Applications/PS3 Media Server.app/Contents/Resources/Java
INFO 2014-10-20 21:42:16.713 [main] Temp directory: /var/folders/2h/x_twtmx51pb4hk783wdwkpc80000gn/T/ps3mediaserver
INFO 2014-10-20 21:42:16.714 [main] Logging config file: /Applications/PS3 Media Server.app/Contents/Resources/Java/logback.xml
INFO 2014-10-20 21:42:16.715 [main] debug.log: /Users/Sherry/Library/Application Support/PMS/debug.log
INFO 2014-10-20 21:42:16.715 [main] Profile directory: /Users/Sherry/Library/Application Support/PMS
INFO 2014-10-20 21:42:16.716 [main] Profile directory permissions: rw
INFO 2014-10-20 21:42:16.716 [main] Profile path: /Users/Sherry/Library/Application Support/PMS/PMS.conf
INFO 2014-10-20 21:42:16.716 [main] Profile permissions: rw
INFO 2014-10-20 21:42:16.718 [main] Profile name: ss-macbook-pro.local
INFO 2014-10-20 21:42:16.718 [main] Web conf path: /Users/Sherry/Library/Application Support/PMS/WEB.conf
INFO 2014-10-20 21:42:16.718 [main] Web conf permissions: file not found
INFO 2014-10-20 21:42:18.053 [main] Checking shared folder: /Users/Sherry/Downloads
INFO 2014-10-20 21:42:19.162 [main] Loading MediaInfo library
INFO 2014-10-20 21:42:19.271 [main] Loaded MediaInfoLib - v0.7.61
INFO 2014-10-20 21:42:19.290 [main] Loading renderer configurations from /Applications/PS3 Media Server.app/Contents/Resources/Java/renderers
INFO 2014-10-20 21:42:19.292 [main] Loading configuration file: AirPlayer.conf
INFO 2014-10-20 21:42:19.298 [main] Loading configuration file: Android.conf
INFO 2014-10-20 21:42:19.304 [main] Loading configuration file: BlackBerryPlayBook-KalemSoftMP.conf
INFO 2014-10-20 21:42:19.312 [main] Loading configuration file: Bravia4500.conf
INFO 2014-10-20 21:42:19.317 [main] Loading configuration file: Bravia5500.conf
INFO 2014-10-20 21:42:19.324 [main] Loading configuration file: BraviaEX.conf
INFO 2014-10-20 21:42:19.331 [main] Loading configuration file: BraviaEX620.conf
INFO 2014-10-20 21:42:19.338 [main] Loading configuration file: BraviaHX.conf
INFO 2014-10-20 21:42:19.347 [main] Loading configuration file: BraviaW.conf
INFO 2014-10-20 21:42:19.354 [main] Loading configuration file: DLinkDSM510.conf
INFO 2014-10-20 21:42:19.357 [main] Loading configuration file: DirecTVHR.conf
INFO 2014-10-20 21:42:19.362 [main] Loading configuration file: FreeboxHD.conf
INFO 2014-10-20 21:42:19.365 [main] Loading configuration file: FreecomMusicPal.conf
INFO 2014-10-20 21:42:19.368 [main] Loading configuration file: Kuro.conf
INFO 2014-10-20 21:42:19.372 [main] Loading configuration file: LGST600.conf
INFO 2014-10-20 21:42:19.377 [main] Loading configuration file: N900.conf
INFO 2014-10-20 21:42:19.380 [main] Loading configuration file: NetgearNeoTV.conf
INFO 2014-10-20 21:42:19.422 [main] Loading configuration file: OPPOBDP83.conf
INFO 2014-10-20 21:42:19.425 [main] Loading configuration file: OPPOBDP93.conf
INFO 2014-10-20 21:42:19.428 [main] Loading configuration file: OnkyoTX-NR717.conf
INFO 2014-10-20 21:42:19.430 [main] Loading configuration file: PS3.conf
INFO 2014-10-20 21:42:19.449 [main] Loading configuration file: Panasonic.conf
INFO 2014-10-20 21:42:19.457 [main] Loading configuration file: Philips.conf
INFO 2014-10-20 21:42:19.462 [main] Loading configuration file: PhilipsPFL.conf
INFO 2014-10-20 21:42:19.472 [main] Loading configuration file: PopcornHour.conf
INFO 2014-10-20 21:42:19.485 [main] Loading configuration file: Realtek.conf
INFO 2014-10-20 21:42:19.488 [main] Loading configuration file: SMP-N100.conf
INFO 2014-10-20 21:42:19.491 [main] Loading configuration file: Samsung-SMT-G7400.conf
INFO 2014-10-20 21:42:19.495 [main] Loading configuration file: SamsungAllShare.conf
INFO 2014-10-20 21:42:19.498 [main] Loading configuration file: SamsungWiseLink.conf
INFO 2014-10-20 21:42:19.499 [main] Loading configuration file: SharpAquos.conf
INFO 2014-10-20 21:42:19.502 [main] Loading configuration file: Showtime3.conf
INFO 2014-10-20 21:42:19.506 [main] Loading configuration file: Showtime4.conf
INFO 2014-10-20 21:42:19.512 [main] Loading configuration file: SonyBluray.conf
INFO 2014-10-20 21:42:19.515 [main] Loading configuration file: SonyHomeTheatreSystem.conf
INFO 2014-10-20 21:42:19.519 [main] Loading configuration file: Streamium.conf
INFO 2014-10-20 21:42:19.521 [main] Loading configuration file: TelstraTbox.conf
INFO 2014-10-20 21:42:19.524 [main] Loading configuration file: VideoWebTV.conf
INFO 2014-10-20 21:42:19.527 [main] Loading configuration file: VizioSmartTV.conf
INFO 2014-10-20 21:42:19.531 [main] Loading configuration file: WDTVLive.conf
INFO 2014-10-20 21:42:19.535 [main] Loading configuration file: WMP.conf
INFO 2014-10-20 21:42:19.538 [main] Loading configuration file: XBMC.conf
INFO 2014-10-20 21:42:19.546 [main] Loading configuration file: XBOX360.conf
INFO 2014-10-20 21:42:19.549 [main] Loading configuration file: YamahaRXA1010.conf
INFO 2014-10-20 21:42:19.562 [main] Loading configuration file: YamahaRXV3900.conf
INFO 2014-10-20 21:42:19.565 [main] Loading configuration file: YamahaRXV671.conf
INFO 2014-10-20 21:42:19.567 [main] Loading configuration file: iPad-iPhone.conf
INFO 2014-10-20 21:42:19.569 [main] Checking MPlayer font cache. It can take a minute or so.
INFO 2014-10-20 21:42:19.683 [main] Done!
INFO 2014-10-20 21:42:19.694 [main] Searching for plugins in /Applications/PS3 Media Server.app/Contents/Resources/Java/plugins
INFO 2014-10-20 21:42:19.695 [main] No plugins found
INFO 2014-10-20 21:42:19.727 [main] Registering transcoding engine: FFmpeg Audio
INFO 2014-10-20 21:42:19.733 [main] Registering transcoding engine: MEncoder Video
INFO 2014-10-20 21:42:19.733 [main] Registering transcoding engine: FFmpeg
INFO 2014-10-20 21:42:19.735 [main] Registering transcoding engine: VLC Video
INFO 2014-10-20 21:42:19.773 [main] Registering transcoding engine: FFmpeg Web Video
INFO 2014-10-20 21:42:19.774 [main] Registering transcoding engine: FFmpeg Web Audio
INFO 2014-10-20 21:42:19.775 [main] Registering transcoding engine: MEncoder Web Video
INFO 2014-10-20 21:42:19.775 [main] Registering transcoding engine: VLC Web Video
INFO 2014-10-20 21:42:19.777 [main] Registering transcoding engine: tsMuxeR
INFO 2014-10-20 21:42:19.777 [main] Registering transcoding engine: Audio High Fidelity
INFO 2014-10-20 21:42:19.778 [main] Registering transcoding engine: VLC Web Audio (Legacy)
INFO 2014-10-20 21:42:19.778 [main] Registering transcoding engine: VLC Web Video (Legacy)
INFO 2014-10-20 21:42:19.779 [main] Registering transcoding engine: dcraw Thumbnailer
INFO 2014-10-20 21:42:19.899 [main] Using forced address 10.0.0.2
INFO 2014-10-20 21:42:19.901 [main] Created socket: /10.0.0.2:5001
INFO 2014-10-20 21:42:20.085 [main] Using the following UUID configured in PMS.conf: e328112f-f1e3-486c-a938-74819aa205a8
INFO 2014-10-20 21:42:20.341 [main] The server should now appear on your renderer
INFO 2014-10-20 21:42:45.889 [UPNPHelper] No IP filter specified, access granted to /10.0.0.13
- Optimus_prime
Re: UMS connects sometimes, but never shows on Xbox 360
Sorry but we only deal with UMS and your log is for PS3 Media server
