UMS 5.0.0-a1 (Bugs)
Echuir
UMS 5.0.0-a1 (Bugs)
Post by Echuir »
Unable to get subtitles in this version even tho they are in the mkv file and work fine on Plex.
Vallimar
Re: UMS 5.0.0-a1 (Bugs)
Post by Vallimar »
Subs are working fine for me. Tested several files with ffmpeg and mencoder.
Hi Echuir, please include logs so we can see what's going wrong :)
Thanks Vallimar :)
Madoka
Post by Madoka »
Setting web_enable = false
results in an:
10-24 21:05:44  Enabled 1 configurations, listed in order of loading priority:
10-24 21:05:44  :   PlayStation 3
10-24 21:05:44  A serious error occurred during PMS init
	at net.pms.PMS.getWebServer(PMS.java:1194) [ums.jar:5.0.0-a1]
	at net.pms.network.UPNPHelper.getHttpControlHandler(UPNPHelper.java:110) ~[ums.jar:5.0.0-a1]
	at net.pms.network.UPNPHelper.init(UPNPHelper.java:104) ~[ums.jar:5.0.0-a1]
	at net.pms.PMS.init(PMS.java:578) [ums.jar:5.0.0-a1]
	at net.pms.PMS.createInstance(PMS.java:1066) [ums.jar:5.0.0-a1]
	at net.pms.PMS.main(PMS.java:1168) [ums.jar:5.0.0-a1]
Also, perhaps if web_enable = false, the Menu Item "Web Interface" could be hidden as well?
Edit: Maybe it's intentional, but the estimated speed is shown with about 10 decimal places, like 277.13216565431.
(15.13 KiB) Downloaded 8304 times
Echuir
Post by Echuir »
Ok I have included a debug log.
debug.log
(82.77 KiB) Downloaded 8020 times
Madoka
Post by Madoka »
5.0.0 a1 does not defer to MEncoder for files with embedded fonts, unlike 4.2.1.
(70.92 KiB) Downloaded 8332 times
Madoka wrote:Setting web_enable = false
results in an:
Thanks for this, we will hopefully have that fixed soon :)
Echuir wrote:Ok I have included a debug log.
Thanks for that :) But we need it to be a trace log, please follow the instructions in my signature.
Madoka wrote:5.0.0 a1 does not defer to MEncoder for files with embedded fonts, unlike 4.2.1.
Thanks for pointing this out, I've reproduced it and will attempt to fix it :)
This is fixed now :)
Madoka
Post by Madoka »
Thanks, SJ!!
Also, I wasn't clear above. The error I mentioned earlier with web_enable = false occurs when you chose the Web Interface menu option, not just in starting UMS.
Looking forward to a2!
Madoka wrote:Thanks, SJ!!
Oh ok, it happens for me on startup too, weird :)
