UMS works on Yosemite as long as I don't install plugins
Hi there!
Installed UMS for the first time yesterday without any problem (iMac 2010, OS X Yosemite 10.10)!
However, when I installed the 'Channels' plugin through the UMS interface I noticed it downloaded the .jar file but lasted forever in loading the file so I relaunched UMS. What happens then is that I get a message saying: "Uncaught exception in main method: java.lang.UnsupportedClassVersionError: com/sharkhunter/channel/CH_plugin : Unsupported major.minor version 51.0" and the application quit.
Went to the JavaApp in "UMS > Contents > Mac OS" to get a log which I've attached below. Unfortunately I'm not able to read these things but I hope anyone out there might have a solution to this.
The best,
Q
The best,
Q
--------- LOG ----------
Last login: Sat Oct 25 08:27:10 on ttys000
xxxxxs-iMac:~ xxxxx$ /Applications/Universal\ Media\ Server.app/Contents/MacOS/JavaApplicationStub ; exit;
08:28:40.787 [main] DEBUG o.a.c.c.ConfigurationUtils - ConfigurationUtils.locate(): base is null, name is /Users/xxxxx/Library/Application Support/UMS/UMS.conf
08:28:40.790 [main] DEBUG o.a.c.c.DefaultFileSystem - Could not locate file /Users/xxxxx/Library/Application Support/UMS/UMS.conf at null: no protocol: /Users/xxxxx/Library/Application Support/UMS/UMS.conf
08:28:40.790 [main] DEBUG o.a.c.c.ConfigurationUtils - Loading configuration from the absolute path /Users/xxxxx/Library/Application Support/UMS/UMS.conf
08:28:40.790 [main] DEBUG o.a.c.c.PropertiesConfiguration - Base path set to file:///Users/xxxxx/Library/Application%20Support/UMS/UMS.conf
08:28:40.801 [main] DEBUG o.a.c.c.PropertiesConfiguration - FileName set to UMS.conf
08:28:40.801 [main] DEBUG o.a.c.c.PropertiesConfiguration - Base path set to /Users/xxxxx/Library/Application Support/UMS
08:28:40,877 |-INFO in ch.qos.logback.core.joran.action.DefinePropertyAction - About to instantiate property definer of type [net.pms.logging.DebugLogPathDefiner]
08:28:40,879 |-INFO in ch.qos.logback.core.joran.action.DefinePropertyAction - Popping property definer for property named [debugLogPath] from the object stack
08:28:40,880 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [net.pms.logging.FrameAppender]
08:28:40,880 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [traces]
08:28:40,900 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.core.ConsoleAppender]
08:28:40,900 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [console]
08:28:40,903 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.core.FileAppender]
08:28:40,905 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [debug.log]
08:28:40,907 |-INFO in ch.qos.logback.core.FileAppender[debug.log] - File property is set to [/Users/xxxxx/Library/Application Support/UMS/debug.log]
08:28:40,909 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.core.rolling.RollingFileAppender]
08:28:40,909 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [debug.log.10MB]
08:28:40,918 |-INFO in ch.qos.logback.core.rolling.FixedWindowRollingPolicy@794e113b - Will use zip compression
08:28:40,924 |-INFO in ch.qos.logback.core.rolling.RollingFileAppender[debug.log.10MB] - Active log file name: /Users/xxxxx/Library/Application Support/UMS/debug.log
08:28:40,924 |-INFO in ch.qos.logback.core.rolling.RollingFileAppender[debug.log.10MB] - File property is set to [/Users/xxxxx/Library/Application Support/UMS/debug.log]
08:28:40,924 |-INFO in ch.qos.logback.classic.joran.action.LoggerAction - Setting level of logger [org.apache] to WARN
08:28:40,924 |-INFO in ch.qos.logback.classic.joran.action.LoggerAction - Setting level of logger [httpclient.wire] to WARN
08:28:40,925 |-INFO in ch.qos.logback.classic.joran.action.RootLoggerAction - Setting level of ROOT logger to DEBUG
08:28:40,925 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [traces] to Logger[ROOT]
08:28:40,925 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [console] to Logger[ROOT]
08:28:40,925 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [debug.log] to Logger[ROOT]
08:28:40,925 |-INFO in ch.qos.logback.classic.joran.action.ConfigurationAction - End of configuration.
08:28:40,925 |-INFO in ch.qos.logback.classic.joran.JoranConfigurator@58e41bc3 - Registering current configuration as safe fallback point
INFO 2014-10-25 08:28:40.941 [main] Starting Universal Media Server 4.2.0
INFO 2014-10-25 08:28:40.941 [main] Based on PS3 Media Server by shagrath, copyright 2008-2014
INFO 2014-10-25 08:28:40.941 [main] http://www.universalmediaserver.com
INFO 2014-10-25 08:28:40.942 [main] Build: f7d443b36 (2014-10-16)
INFO 2014-10-25 08:28:40.942 [main] Java: Java HotSpot(TM) 64-Bit Server VM 1.6.0_65 64-bit by Apple Inc.
INFO 2014-10-25 08:28:40.942 [main] OS: Mac OS X 64-bit 10.10
INFO 2014-10-25 08:28:40.942 [main] Encoding: UTF-8
INFO 2014-10-25 08:28:40.951 [main] Memory: 759 MB
INFO 2014-10-25 08:28:40.952 [main] Language: sv
INFO 2014-10-25 08:28:40.952 [main] Working directory: /Applications/Universal Media Server.app/Contents/Resources/Java
INFO 2014-10-25 08:28:40.953 [main] Temp directory: /var/folders/2n/nyfrtfmx3gs0_vcjhzjrp9cc0000gn/T/universalmediaserver
INFO 2014-10-25 08:28:40.953 [main] Logging config file: /Applications/Universal Media Server.app/Contents/Resources/Java/logback.xml
INFO 2014-10-25 08:28:40.954 [main] debug.log: /Users/xxxxx/Library/Application Support/UMS/debug.log
INFO 2014-10-25 08:28:40.954 [main] Profile directory: /Users/xxxxx/Library/Application Support/UMS
INFO 2014-10-25 08:28:40.955 [main] Profile directory permissions: rw
INFO 2014-10-25 08:28:40.955 [main] Profile path: /Users/xxxxx/Library/Application Support/UMS/UMS.conf
INFO 2014-10-25 08:28:40.955 [main] Profile permissions: rw
INFO 2014-10-25 08:28:40.955 [main] Profile name: xxxxxs-iMac.local
INFO 2014-10-25 08:28:40.956 [main]
INFO 2014-10-25 08:28:40.956 [main] Web conf path: /Users/xxxxx/Library/Application Support/UMS/WEB.conf
INFO 2014-10-25 08:28:40.956 [main] Web conf permissions: file not found
INFO 2014-10-25 08:28:42.226 [main] Checking shared folder: /Users/xxxxx/Documents/Filmer
INFO 2014-10-25 08:28:42.420 [main] Loading MediaInfo library
INFO 2014-10-25 08:28:42.469 [main] Loaded MediaInfoLib - v0.7.58
INFO 2014-10-25 08:28:42.491 [main] Loading renderer configurations from /Applications/Universal Media Server.app/Contents/Resources/Java/renderers
INFO 2014-10-25 08:28:42.651 [main] Enabled 67 configurations, listed in order of loading priority:
INFO 2014-10-25 08:28:42.652 [main] : Panasonic VT60
INFO 2014-10-25 08:28:42.653 [main] : Panasonic TV
INFO 2014-10-25 08:28:42.653 [main] : Samsung HT-E3 Series
INFO 2014-10-25 08:28:42.653 [main] : Samsung LED TV
INFO 2014-10-25 08:28:42.654 [main] : Xbox One
INFO 2014-10-25 08:28:42.654 [main] : AirPlayer
INFO 2014-10-25 08:28:42.655 [main] : Android
INFO 2014-10-25 08:28:42.655 [main] : Azur BD
INFO 2014-10-25 08:28:42.656 [main] : D-Link DSM-510
INFO 2014-10-25 08:28:42.656 [main] : DirecTV HR
INFO 2014-10-25 08:28:42.657 [main] : Freebox HD
INFO 2014-10-25 08:28:42.657 [main] : Freecom MusicPal
INFO 2014-10-25 08:28:42.657 [main] : iPad / iPhone
INFO 2014-10-25 08:28:42.658 [main] : KalemSoft Media Player
INFO 2014-10-25 08:28:42.658 [main] : LG 42LA644V
INFO 2014-10-25 08:28:42.659 [main] : LG LA6200
INFO 2014-10-25 08:28:42.659 [main] : LG LA644V
INFO 2014-10-25 08:28:42.660 [main] : LG LM620
INFO 2014-10-25 08:28:42.660 [main] : LG Smart TV Upgrader
INFO 2014-10-25 08:28:42.661 [main] : Netgear NeoTV
INFO 2014-10-25 08:28:42.661 [main] : Nokia N900
INFO 2014-10-25 08:28:42.662 [main] : Onkyo TX-NR717
INFO 2014-10-25 08:28:42.662 [main] : OPPO BDP
INFO 2014-10-25 08:28:42.662 [main] : OPPO BDP-83
INFO 2014-10-25 08:28:42.663 [main] : Panasonic TX-L32V10E
INFO 2014-10-25 08:28:42.663 [main] : Panasonic U30Z
INFO 2014-10-25 08:28:42.664 [main] : Philips Aurea
INFO 2014-10-25 08:28:42.664 [main] : Philips TV
INFO 2014-10-25 08:28:42.665 [main] : Pioneer Kuro
INFO 2014-10-25 08:28:42.665 [main] : PlayStation 3
INFO 2014-10-25 08:28:42.666 [main] : Popcorn Hour
INFO 2014-10-25 08:28:42.666 [main] : Realtek
INFO 2014-10-25 08:28:42.666 [main] : Samsung AllShare
INFO 2014-10-25 08:28:42.667 [main] : Samsung AllShare C/D
INFO 2014-10-25 08:28:42.667 [main] : Samsung D7000
INFO 2014-10-25 08:28:42.668 [main] : Samsung Mobile
INFO 2014-10-25 08:28:42.668 [main] : Samsung SMT-G7400
INFO 2014-10-25 08:28:42.669 [main] : Samsung WiseLink
INFO 2014-10-25 08:28:42.669 [main] : Sharp Aquos
INFO 2014-10-25 08:28:42.670 [main] : Showtime 3
INFO 2014-10-25 08:28:42.671 [main] : Showtime 4
INFO 2014-10-25 08:28:42.671 [main] : Sony Blu-ray
INFO 2014-10-25 08:28:42.671 [main] : Sony Bravia 4500
INFO 2014-10-25 08:28:42.672 [main] : Sony Bravia 5500
INFO 2014-10-25 08:28:42.672 [main] : Sony Bravia BX305
INFO 2014-10-25 08:28:42.673 [main] : Sony Bravia EX
INFO 2014-10-25 08:28:42.673 [main] : Sony Bravia EX620
INFO 2014-10-25 08:28:42.674 [main] : Sony Bravia HX
INFO 2014-10-25 08:28:42.674 [main] : Sony Bravia W
INFO 2014-10-25 08:28:42.675 [main] : Sony Bravia XBR
INFO 2014-10-25 08:28:42.675 [main] : Sony Home Theatre System
INFO 2014-10-25 08:28:42.676 [main] : Sony SMP-N100
INFO 2014-10-25 08:28:42.677 [main] : Sony STR-DA5800ES
INFO 2014-10-25 08:28:42.677 [main] : Sony Xperia Z/ZL/ZQ/Z1/Z2
INFO 2014-10-25 08:28:42.678 [main] : Streamium
INFO 2014-10-25 08:28:42.679 [main] : Telstra T-Box
INFO 2014-10-25 08:28:42.679 [main] : Unknown renderer
INFO 2014-10-25 08:28:42.680 [main] : VideoWeb TV
INFO 2014-10-25 08:28:42.680 [main] : Vizio Smart TV
INFO 2014-10-25 08:28:42.681 [main] : WD TV Live
INFO 2014-10-25 08:28:42.681 [main] : WMP
INFO 2014-10-25 08:28:42.682 [main] : XBMC
INFO 2014-10-25 08:28:42.682 [main] : Xbox 360
INFO 2014-10-25 08:28:42.683 [main] : Yamaha RX-A1010
INFO 2014-10-25 08:28:42.683 [main] : Yamaha RX-V3900
INFO 2014-10-25 08:28:42.684 [main] : Yamaha RX-V671
INFO 2014-10-25 08:28:42.684 [main] : Android/Chromecast
INFO 2014-10-25 08:28:42.685 [main] Checking the fontconfig cache, this can take two minutes or so.
INFO 2014-10-25 08:28:42.870 [main] Searching for plugins in /Applications/Universal Media Server.app/Contents/Resources/Java/plugins
INFO 2014-10-25 08:28:42.872 [main] Found plugin: com.sharkhunter.channel.CH_plugin
INFO 2014-10-25 08:28:42.873 [main] [LaunchRunner Error] net.pms.PMS.main(String[]) threw an exception:
INFO 2014-10-25 08:28:42.874 [main] java.lang.UnsupportedClassVersionError: com/sharkhunter/channel/CH_plugin : Unsupported major.minor version 51.0
INFO 2014-10-25 08:28:42.875 [main] at java.lang.ClassLoader.defineClass1(Native Method)
INFO 2014-10-25 08:28:42.876 [main] at java.lang.ClassLoader.defineClassCond(ClassLoader.java:637)
INFO 2014-10-25 08:28:42.876 [main] at java.lang.ClassLoader.defineClass(ClassLoader.java:621)
INFO 2014-10-25 08:28:42.877 [main] at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:141)
INFO 2014-10-25 08:28:42.877 [main] at java.net.URLClassLoader.defineClass(URLClassLoader.java:283)
INFO 2014-10-25 08:28:42.878 [main] at java.net.URLClassLoader.access$000(URLClassLoader.java:58)
INFO 2014-10-25 08:28:42.878 [main] at java.net.URLClassLoader$1.run(URLClassLoader.java:197)
INFO 2014-10-25 08:28:42.878 [main] at java.security.AccessController.doPrivileged(Native Method)
INFO 2014-10-25 08:28:42.879 [main] at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
INFO 2014-10-25 08:28:42.879 [main] at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
INFO 2014-10-25 08:28:42.880 [main] at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
INFO 2014-10-25 08:28:42.881 [main] at net.pms.external.ExternalFactory.loadJAR(ExternalFactory.java:215)
INFO 2014-10-25 08:28:42.881 [main] at net.pms.external.ExternalFactory.loadJARs(ExternalFactory.java:171)
INFO 2014-10-25 08:28:42.882 [main] at net.pms.external.ExternalFactory.lookup(ExternalFactory.java:404)
INFO 2014-10-25 08:28:42.882 [main] at net.pms.PMS.init(PMS.java:648)
INFO 2014-10-25 08:28:42.883 [main] at net.pms.PMS.createInstance(PMS.java:1047)
INFO 2014-10-25 08:28:42.883 [main] at net.pms.PMS.main(PMS.java:1139)
INFO 2014-10-25 08:28:42.884 [main] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
INFO 2014-10-25 08:28:42.884 [main] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
INFO 2014-10-25 08:28:42.885 [main] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
INFO 2014-10-25 08:28:42.885 [main] at java.lang.reflect.Method.invoke(Method.java:597)
INFO 2014-10-25 08:28:42.885 [main] at apple.launcher.LaunchRunner.run(LaunchRunner.java:116)
INFO 2014-10-25 08:28:42.886 [main] at apple.launcher.LaunchRunner.callMain(LaunchRunner.java:51)
INFO 2014-10-25 08:28:42.886 [main] at apple.launcher.JavaApplicationLauncher.launch(JavaApplicationLauncher.java:52)
logout
Re: UMS works on Yosemite as long as I don't install plugins
You might try installing Java 8 and using the Java 8 version of UMS. That error is related to loading Java classes compiled on later versions of Java, that your older version of Java (6) doesn't support.
You can delete the "Channels" plugin by:
going into your Applications folder
right-click on UMS
click on Show Package Contents in the menu
navigate to Contents/Resources/Java/plugins
Delete "tv_plug_222.jar"
This solved the problem for me.
right-click on UMS
