Help us improve support for your devices
Re: Help us improve support for your devices
Dear Developers,
While trying to access the "Universal Media Server" from the list of all available DLNA servers from my new Sony BRAVIA KD-43XE7077, I am getting the following message:
"Cannot access the server. Please check the server settings."
It seems that the XE series are not supported by the UMS.
Would be very grateful to get support for my "SMART TV", looking forward to donate.
Please find attached the TRACE log made according the "How to ask for support" thread.
- (40.58 KiB) Downloaded 768 times
It is strange. The TV is correctly recognized as Sony Bravia XD/XE and communicates with the UMS. Please try to change in the Sony-BraviaXD.conf line to and test it again.
CreateDLNATreeFaster = true
CreateDLNATreeFaster = false
The good news: I have made the change in the config file and suddenly it made the server accessible, the message was gone.
The bad news: While trying to list and play the movie files on the TV every action is very slow and after a while the TV shows the message "Playback is not available" while trying to play a movie. Also, from time to time, it happens to the TV to get completely unresponsive and should be restarted by using the power plug. The creation of the movie thumbnails on the fly option is disabled too.
Having in mind that the config file is tailored for the Sony XD series only, please check if it is correct for my TV which is XE series. The name of the config file is associated with both series but inside the config file everything associates on the XD series.
Thanks in advance.
Thanks in advance.
Hello every body.
I tried to read a movie in x265 10 bits on my tablet teclast 16Xplus (1920*1080) but i have a lot of freeze. Someone can help me ?
The server pc is a intel core 2 duo E8400 8goram 660gtx.
Thanks a lot for your awesome work.
- (241.37 KiB) Downloaded 724 times
Hello, I would like buy this Sound System (Denon) but i don't think it's supported by UMS.
Hi everyone,
Thanks for the great work you guys are doing, UMS really is a great piece of software and fits my needs perfectly!
I'd like to contribute my new TV's profile: Sony Bravia KD-85XF8596. The trace log is attached. If you need anything else or if you'd like me to test anything, feel free to reach out
Best regards and keep up the good work,
Mike
Mike
- (18.64 KiB) Downloaded 735 times
Hi all
Thanks for providing UMS!
After I did a clean install with v7.4 I noticed that my TV's are not working as before. So I was forced to have a look at the render config files. Quite a bit complicated...
But I got it working, happy to share here
What I did:
TV: UE55MU7000 (Samsung)
- I copied config file from 8-series and changed to UpnpDetailsSearch = UE55MU7000
Samsung-CD.conf
- added: SeekByTime = true
Receiver Yamaha RXV681
- added Yamaha-RXV681.conf based on Yamaha-RXV671.conf
- probably possible to merge into 1 config, but I am not the master for this
Hope this helps
cheers
Patrick
What I did:
Samsung-CD.conf
Hope this helps
cheers
Patrick
- Yamaha-RXV681.conf
- new based on 671
- (484 Bytes) Downloaded 724 times
- Samsung-CD.conf
- added seektime = true
- (2.22 KiB) Downloaded 740 times
- Samsung-7series.conf
- new based on 8 series
- (4.42 KiB) Downloaded 742 times
Hi all and THANK You for this excellent server
However, i have problems with streaming some files to my Samsung ue75mu6170uxzg
Should i try here or open new thread?
Ill be quick:
Webrip and some MKV streams just ok, subtitles work, everything is ok...
but when i try to stream 4k ( 10 bits or 8 bits.... don't really know what those means, but tried both)... i usually get 2 errors on my TV: Please check Your network OR error: an error has occurred...it shows loading icon and after few seconds i get those errors.
I tried ALL Samsung configs, i created new, edited them, read all threads for Samsung, been on github, tried various combinations and advises from people ..... but still nothing
PS: ALL those files plays OK from USB...
I hope i attached good logs
EDIT: when i go : CAST TO DEVICE, via win10 context menu, all those files plays OK, but i need them with external subtitles
Thanks in advance
hope someone will find where i am mistaken
Ill be quick:
Thanks in advance
- (480.27 KiB) Downloaded 722 times
A few months ago I bought a Samsung UE55MU6105KXXC. After discovering this DLNA thing I installedy UMS as it seems the perfect solution to see my media on the TV. So far it works for some videos, but there are some videos that are not playing via UMS but via USB without problem. I also tried simpleDLNA and those videos play ok. I peeked the renderer config to see if I could add some supported video codecs by my self but I don't understand how it works exactly. I found a section in the manual of my tv with the supported video codecs, maybe someone can helpme to create a custom rederer conf.
- (109.22 KiB) Downloaded 706 times
- Supported_video_codecs.PNG (50.15 KiB) Viewed 17683 times
Hi guys,
Thanks for UMS
My father just bought a Samsung HT-J5500W (Home Theater 5.1).
He can play DLNA / UPNP.
It don't work with Samsung-J55XX.conf, however I juste created a conf file that work.
Samsung-HT-J5500W.conf (attachment).
FYI :
The HT-J5500W's manual is here
It recence the codecs.
Thanks guys
Pierre
Thanks for UMS
FYI :
Thanks guys
Pierre
- Samsung-HT-J5500W.conf
- (1.55 KiB) Downloaded 673 times
