Version 4.2.1 is released
General:
This release adds and improves support for many renderers, increases transcoding speed, improves file support and more!
Upgrade note for Linux users: We have renamed many of the renderer configuration files so we recommend clearing the "renderers" folder before updating to this version.
Changes since 4.2.0:
  • General:
    • Increased speed of FFmpeg transcoding to H.264
    • Updated UMS.conf
    • Improved filename prettifying
    • Re-added "Force default renderer" option to the GUI
    • Minor GUI fixes and improvements
    • Fontconfig caches are not generated if subtitles are disabled
    • Renamed most renderer config files
    • Fixed special characters in folder names not displaying correctly
  • Renderers:
    • Added support for LG WebOS TVs
    • Added support for Panasonic SC-BTT Blu-ray Disc Home Theater Sound Systems
    • Added support for Samsung ES8000 TVs
    • Added support for Samsung F5900 Blu-ray Disc players
    • Added support for Technisat S1+
    • Improved detection of Windows Media Player
    • Improved support for H.264 videos on some renderers
    • Improved support for Cambridge Audio Azur BD players
    • Improved support for Samsung WiseLink renderers
    • Improved support for subtitles on Sony Bravia EX TVs (thanks, master-nevi!)
    • Improved support for Panasonic TVs
    • Improved support for Xbox One
    • Fixed seeking on Samsung E+ Series TVs
  • Languages:
    • Updated French translation (thanks, Kirvx!)
  • External Components:
    • Updated MPlayer/MEncoder for Windows to SB60, which:
      • Improves H.264 transcoding
      • Improves H.265 support
      • Improves support for many containers and codecs
      • Fixes bugs
N3phastus
Re: Version 4.2.1 is released
Post by N3phastus »
Hey !
I've a Yamaha Receiver RXV-2065, and it shows up in UMS as Philips Aurea TV.
Is it fixable to get the right equipment showing up ?
Regards and keep the good work ! I'm using your software for almost 3 years !
gatty
Post by gatty »
hi,
This version plays well with ext-sub on iPad using MEncoder. However, Vietnamese subtitles cannot be played correctly (Vietnamese characters are shown as square box), I guess it could be some settings about font encode or something else. this is a sample subtitle for reference. Please help by showing me how to config correctly
https://www.dropbox.com/s/06tdvd82xovra ... D.srt?dl=0
https://www.dropbox.com/s/o6o1jmzpxbtsd ... g.zip?dl=0
thanks
raprop
Post by raprop »
Hi
now detect fine WebOS TV, but the externat sub failed... buffer overrun, only work fine if include SupportedExternalSubtitlesFormats = ASS,SUBRIP
if mkv hace a subt include how to disable this!?
thx.
N3phastus wrote:Hey !
In 5.0.0-a1 we have added new ways of identifying renderers, so please give us logs from that version so we can do that for you :)
gatty wrote:hi,
thanks
Can you please also upload the file "/var/folders/x4/62mr6ztd28zbkknzhnp1f4jc0000gn/T/universalmediaserver/utf8_House.M.D.S05E01.Dying.Changes.Everything.720p.WEB-DL.DD5.1.h.264-TjHD.srt"?
raprop wrote:Hi
thx.
Please make logs for this (link in my signature)
shaina
Post by shaina »
this release is still not recognizing my lg pb6600 plasma properly but 5.0.0-a1 works great for it and not the xbox360 it would be great if there is a way to fix the lg pb6600 plasma on this release
thanks
sma76928
Post by sma76928 »
thx.
Hi SubJunk, i copnfirm that the webos tv is not suported for transcoding. now it buffers for a while, then some sound can be heard and a little bit of image as well, but at the end everything freeze
here is the log
https://drive.google.com/file/d/0B1YgMb ... sp=sharing
best regards
shaina wrote:this release is still not recognizing my lg pb6600 plasma properly but 5.0.0-a1 works great for it and not the xbox360 it would be great if there is a way to fix the lg pb6600 plasma on this release
thanks
Sorry but I think you'll have to wait until the next 5.0.0 release, since we added a new detection method in 5.0.0 that isn't in version 4. We will hopefully do our next 5.0.0 release soon!
sma76928 wrote:Hi SubJunk, i copnfirm that the webos tv is not suported for transcoding. now it buffers for a while, then some sound can be heard and a little bit of image as well, but at the end everything freeze
here is the log
best regards
Hi sma76928, thanks for the logs, but they need to be trace logs (instructions in my signature) :)
gatty
Post by gatty »
gatty wrote:hi,
thanks
hi SubJunk,
where can I locate the file?
thx
gatty
Post by gatty »
