[Implemented] watch FullHD 1080p video 60Hz in real-time
ulyong23
Post by ulyong23 »
Is there any options or feature that can make a GPU acceleration and allows to watch FullHD 1080p-video recalculated to 60Hz in real-time using a mid-range CPU?
just like this player http://www.svp-team.com/
SVP allows you to watch any video on your PC using frame interpolation (as it is available on high-end TVs and projectors). It increases the frame rate by generating intermediate animation frames between existing frames in order to produce very smooth, fluid and clear motion. The technology is pretty well-known for a while ("TrimensionDNM", "Motion Plus", "Motionflow" and others), but now it becomes available to PC users for free using a simple GUI and a couple of mouse clicks.
any ideas?
Re: watch FullHD 1080p video 60Hz in real-time
Hi ulyong23, we use SVP with our AviSynth engines and we call it True Motion :) It can be slow though since we have to transcode to the renderer - which is an extra step that SVP doesn't need to do - so it may not be doable at 1080p on a mid-range CPU. However it might be, give it a try :)
kanedagr
Re: [Implemented] watch FullHD 1080p video 60Hz in real-time
Post by kanedagr »
Can you play a file with true motion with subtitles on?
