[Implemented] New UI For Renderers List
- AYColumbia
I just installed the latest 4.3.1 and wow, the renderers list dialog is unwieldy now. Heck, it's almost larger than the main UI.
If you can please modify the renderers list so it's a reasonable sized modal dialog with a list box containing the check-able renderer items, it would be a better solution than what's currently growing out of control.
Thanks for considering the suggestion.
BTW, "Roku 3" is listed twice in the current list of renderers.
Re: New UI For Renderers List
Done in the next version
Thanks for the suggestion!
